Old 05-20-2013, 09:24 PM   #1
swede_ish
Member#: 327426
Default Enkei 17x9 +45 rpf1 & bbk
A lot of people say with the flat face rpf1 on a +45 offset 9 inches wide you will barely have any brake clearance. I purchased some anyway, hoping to get away with some 3 mm spacers.
I drive a 9-2x aero with a wilwood 4 pot bbk upfront. My rpf1's came in the mail today and I'd like to say I had plenty of clearance WITHOUT a spacer. The wilwoods stick out a half inch from the wheel mating surface of the hat.
I'm not saying these will clear brembos, I know that they stick out a lot but perhaps with a small spacer they will.
Great thing is these are becoming less rare in 5x100 thanks to the brz/fr-s (which is what these will be going on in the fall along with a wilwood 4 pot kit!)
Pics:
For those interested tires are nexen n7000 235/40's
swede_ish is offline   Reply With Quote
Old 05-22-2013, 12:41 PM   #2
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
The Wilwood BBK is smaller than stock Brembos. The 17x9 +45 RPF1s definitely do NOT clear Brembos without a spacer.
Old 05-22-2013, 12:45 PM   #3
edsonmassao
Member#: 291430
2006 WRX wagon
the problem is with Brembos and Stoptechs, in my mind only Mach V 17x9 wheels clear those calipers...
but these RPF1s looks sweet, swede_ish!
edsonmassao is offline   Reply With Quote
Old 05-22-2013, 02:24 PM   #4
mav1c
Hoodbridge!
Member#: 560
The Mach V wheel definitely clears, but there are a lot of others.
http://forums.nasioc.com/forums/show....php?t=2136684
Old 05-22-2013, 02:45 PM   #5
vicious_fishes
Member#: 158864
2003 SOHC destroker
still waiting on enkei australia to get these.
yep, none in the COUNTRY.
Old 05-22-2013, 03:11 PM   #6
swede_ish
Member#: 327426
Which is what I said in my post, "not saying these will clear brembos" but they aren't a wheel to dismiss when considering a larger than stock brake kit (for wrx). And who are wanting a light wheel these are 15.9 lbs a piece w/o tire. Not to forget rpf1's with a flat face are simple but sexy.
I'm almost certain the 6 pot wilwood kit will fit under these too. Going to measure after work later.
Old 05-22-2013, 05:11 PM   #7
alakazoo22
Member#: 230730
05 FXT 18GXTR
black
spacer needed to clear 4/2 pots (wrx06-07)
5mm is required to clear 4 pots.
alakazoo22 is offline   Reply With Quote
Old 05-22-2013, 07:10 PM   #8
swede_ish
Member#: 327426
The Subaru 4 pots are that wide? That's crazy.
Old 05-22-2013, 07:20 PM   #9
SG02WRX
Member#: 151814
I not certain, but I don't think a spacer is need to to clear FHI 4pots.
SG02WRX is offline   Reply With Quote
Old 05-22-2013, 11:27 PM   #10
Gusto7873
Member#: 292785
2006 WRX wagon
Blouch 1.5XTR
I have a 06 wrx wagon. Running factory strut and cobb springs. Test fitted rpf1 17x9 +45 just now. Took some paint off the 4 pots and there is maybe 3/8 inch clearance on rear strut. Will 3mm spacers clear or 5mm minimum?
Gusto7873 is offline   Reply With Quote
Old 05-23-2013, 01:17 AM   #11
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
The issue is where they're wide. They're wide close to the hub. These are 15" / 16" wheel brakes and some 17" wheels end up with the caliper well inside of the "spoke pocket". Check your pic with the Wilwoods, even those brakes are towards the inside of the "pocket". Put that same caliper 1-2cm towards the center of the rim and it won't clear either.
The 6 pot Superlite Wilwood kits will clear just about anything. They are narrow calipers and narrow pads and are offset about as far as you can, they're good for spoke clearance. The original kit used narrow rotors too, but now they have a 332x32 kit that is much better for track work than the old 328x28 kit.
Old 05-23-2013, 03:24 AM   #12
KGwrx
Member#: 268868
I would do the 5mm, I guess the dude a couple posts up was correct
KGwrx is offline   Reply With Quote
Old 05-23-2013, 07:44 AM   #13
alakazoo22
Member#: 230730
05 FXT 18GXTR
black
if you don't put spacer, at least 3mm, you can tight the 5 bolt correctly and you can turn the wheel..
3 mm have 1 mm clearance
5 mm have better clearance for my taste.
Old 05-29-2013, 10:41 AM   #14
Tire Rack Moderator
Member#: 1215
ext. 4362
Luke@tirerack is offline   Reply With Quote
Old 05-29-2013, 10:56 AM   #15
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
i certainly didn't expect these to NOT clear the FHI (non-brembo) 4-pots. thats unfortunate.
i have the FHI 4-pots with 17x9 +44 Work CR-Kai. plenty of clearance. but i know, different wheel, different spoke design
gsrcrxsi is online now   Reply With Quote
Old 05-29-2013, 11:00 AM   #16
Tire Rack Moderator
Member#: 1215
ext. 4362
the Kosei K1 TS 17x9 ET45 5-114.3will clear big brake kits like the STi Brembo brake package.
Old 05-29-2013, 11:05 AM   #17
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
well only the STi guys will care about that. theres MANY more WRX guys that want something in this size, that clears brembos, in a 5x100 bolt pattern
Old 05-29-2013, 05:35 PM   #18
Gusto7873
Member#: 292785
2006 WRX wagon
Blouch 1.5XTR
Was finally able to fit 17X9 +45 RPF1 with 245/40/17 on the 2006 Wrx wagon. 3mm spacers all around cleared the front 4pots and the rear strut on just Cobb springs.
Old 05-29-2013, 06:05 PM   #19
dangsy
Member#: 318906
2012 SWP WRX Premium
Will the 4/2 pots clear these on a '12 wrx?
dangsy is offline   Reply With Quote
Old 05-29-2013, 07:17 PM   #20
swede_ish
Member#: 327426
That looks fantastic, now you just need some sedan fenders up front!!
Old 05-29-2013, 08:49 PM   #21
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
4eat Stage 2 Protuned
Any rear shots? Are you rolled? Coils?
eurospek is offline   Reply With Quote
Old 05-29-2013, 09:03 PM   #22
swede_ish
Member#: 327426
I would assume he needs to be rolled because I had a +42 fitment on 17x9 grids and it needed to be rolled (9-2x)
Old 05-29-2013, 09:06 PM   #23
swede_ish
Member#: 327426
I want to run my gold rpf1's on the 9-2x, but I need to save them for the frs I'm picking up !!
Old 05-30-2013, 02:36 AM   #24
newsoltsc
Member#: 357553
2005 Saab 92X
Great setup!
newsoltsc is offline   Reply With Quote
Old 05-30-2013, 01:26 PM   #25
Gusto7873
Member#: 292785
2006 WRX wagon
Blouch 1.5XTR
Thanks! Getting all four corners rolled this weekend. Just running Cobb lowering springs for now. Gonna see how she drives and rides before getting coilovers. Looking into getting the ST coilovers if I decide to go that route.
