Old 05-16-2013, 12:20 PM   #451
Imprezzedwitsubies
Member#: 216116
2015 BRZ Limited
14' Triumph America
Originally Posted by TyConway View Post
its the design of the knuckle... theres a dust seal that the axle slides up into. The 350z axle is just too big (diameter wise) Either have to machine the axle or the knuckle... either or, not worth trying or making work.
Also my stock calipers will not bolt back onto the jdm sti knuckle.. unlike i was told by the seller.. told me they would swap with no issues. not the case... so it would have to be a ton of work and machine time, hub redrilled for correct lug pattern, caliper bracket modified or changed, then the ebrakes, depending on which caliper bracket i went with. then still have to machine the hubs so they would fit. Yea i'll just save the headache and do it the right way the first time.
So what will you do/use in this situation? Go with a GM setup and cut it to size so to speak?
Imprezzedwitsubies is offline   Reply With Quote
Old 05-19-2013, 01:54 AM   #452
TyConway
Member#: 193189
2002 wrx
Just put my stock knuckles back on, buy the drive shaft shop axles with there upgraded hubs. They will make the axles work for my new rear diff. there hubs and axles are good to 1200 hp. So bolt in and go, sets me back 2k though.
TyConway is offline   Reply With Quote
Old 05-21-2013, 08:33 AM   #453
02WRX<3
Member#: 183230
2006 STi
Every morning, at work, first thing I do is check on this thread. I get little upset when I don't see an update. You sir are unbelievable. You do stuff I dream of.
P.S. I've been stalking this thread since day one. Can't wait to see it finished.
02WRX<3 is offline   Reply With Quote
Old 05-21-2013, 06:05 PM   #454
TyConway
Member#: 193189
2002 wrx
End of the month is bill time for me. so no big parts purchases. I've been doing some little stuff. nothing worth posting really. I went caving the past weekend and been putting off fixing my g/f jeep for 2 months... it has a bad cylinder head on it, i'll finish it up this week and get it back going. then i'll try and knock some more out on the wrx. I'll get some pics up soon.
Old 05-21-2013, 10:18 PM   #455
dburgoon
Member#: 310366
03 vf37'd WRB
Bugeye
Your welds.... WOW! No other words for it. Great looking project! Not my cup of tea but its awesome!
dburgoon is offline   Reply With Quote
Old 05-22-2013, 01:41 AM   #456
TyConway
Member#: 193189
2002 wrx
Thanks, still a newbie at tig..still learning... trust me when i started... ha it was horrible.
Old 05-22-2013, 10:57 AM   #457
STMTuned
Member#: 227871
STM
00 Drag RSTi [email protected]
All of us here are admiring your welds as well.
I like the idea of the two passes for welding to the cast. The technique that some other people use has been to torch the cast until it's glowing red and then to weld - both, in theory do the same thing, but the two passes sounds like it's potentially more effective. Looking at your welds and the apparent penetration you were able to achieve, the two-pass method may be far superior.
Keep up the outstanding and uncompromising work.
STMTuned is offline   Reply With Quote
Old 05-22-2013, 02:06 PM   #458
TyConway
Member#: 193189
2002 wrx
Thanks for the compliments!
If i was mig welding cast... then yea, I would have to heat it.
Doing a fusion pass ( no filler rod) it gets the heat in the cast and deep penetration, its glowing solid red, and also gets the impurities out. Then the filler pass is just like welding any other steel, main thing is to keep the heat in the part (slow cooling) after the weld.
Old 05-24-2013, 09:59 AM   #459
Mad Ra88it
Member#: 113563
98 Unicorn
I've always just dunked the whole thing into a HUGE vat of sand and let it cool down from there. Honestly never thought of using the welding blanket, but it absolutely makes sense and might actually be a bit cleaner in the shop. haha
Amazing build, should post this up on norotors! This thing is right up there with 65imp's build.
Mad Ra88it is offline   Reply With Quote
Old 05-25-2013, 03:20 PM   #460
TyConway
Member#: 193189
2002 wrx
I haven't been on norotors in forever... since i did my rx7.
Old 05-31-2013, 10:17 PM   #461
TyConway
Member#: 193189
2002 wrx
well gonna get a few hrs in on the car tonight... I'll get a few pics of what gets done.
Old 05-31-2013, 10:30 PM   #462
grandotitat
Member#: 355259
2003 Forester XT
Looking foward for it!
grandotitat is offline   Reply With Quote
Old 06-03-2013, 11:58 AM   #463
02WRX<3
Member#: 183230
2006 STi
Old 06-06-2013, 11:06 PM   #464
mdoffroad
Member#: 356745
02 Impreza Wagon
subscribed for sure...
mdoffroad is offline   Reply With Quote
Old 06-09-2013, 02:59 PM   #465
time2shine
Member#: 358623
2000 L wagon
sedona
As a big fan of LSX motors, and Subys, I must say this is awesome.
time2shine is offline   Reply With Quote
Old 06-11-2013, 01:06 PM   #466
02WRX<3
Member#: 183230
2006 STi
I sense a big update coming up.
Old 06-11-2013, 01:47 PM   #467
3mlwhly
Member#: 217648
01 2.5rs
^I hope so
3mlwhly is offline   Reply With Quote
Old 06-12-2013, 06:46 PM   #468
TyConway
Member#: 193189
2002 wrx
Yea sorry for no updates... just getting to the point its starting to frustrate me. the axle and hub setup didn't work. Now talking with DSS and seems like they can't give me any info on there own products... Never would of thought it would be so hard to get some axles made. But im going to the bank at the end of the week and take 5k personal loan to finish buying parts (setting 2500 aside just for axles and driveshaft). hoping 2500 will buy the rest . but it will be cutting it close.
As for updates, just been cleaning the engine bay up, shaved a few holes and modified the firewall a little for the clutch master cylinder, Gonna try and get the bay primed and painted soon. Just had to put the car off for a little while... just aggravated with the simple stuff...like the axles.
Old 06-12-2013, 07:26 PM   #469
kaminaricelica07
Member#: 113042
2002 WRX Wagon
very impressive. this a very clean job. lots of attention to detail.
kaminaricelica07 is offline   Reply With Quote
Old 06-13-2013, 09:51 AM   #470
Imprezzedwitsubies
Member#: 216116
2015 BRZ Limited
14' Triumph America
Let it all out man, let it all out
You will figure it out I'm sure!
Old 06-13-2013, 10:46 AM   #471
brutnus
Member#: 257195
2004 WRX
2.1L
Love this build. Detail and Quality.
brutnus is offline   Reply With Quote
Old 06-13-2013, 05:31 PM   #472
TyConway
Member#: 193189
2002 wrx
After thinking about what the problem with the axles, the simple solution is to just build custom knuckles... I measured everything out today, metal is ordered.
custom knuckles are going to let me bolt the 350z unit bearings on. (modified the 350z hub to 5x100 lug pattern). And also the custom knuckles will allow room for the large 350z cv joints.
with the 350z hub modified to 5x100, I can use the stock wrx rotor and brake caliper. (ebrakes will be figured out at a later time)
350z stock axles will work, no modifications.
I really don't know why a custom knuckle wasn't in my head to begin with... lol
after thinking about my idea i did a search for custom 350Z knuckles and found these... which are a lot more complicated over how the the wrx would be designed.
Old 06-13-2013, 05:57 PM   #473
05subysti
Member#: 268190
2005 STi
I can't wait to see the custom knuckles, wish I had all your fabrication knowledge and skills!
Old 06-13-2013, 10:49 PM   #474
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
Sounds like a perfect solution and will probably cost a bit less
Rene2.5RS is offline   Reply With Quote
Old 06-13-2013, 10:52 PM   #475
TyConway
Member#: 193189
2002 wrx
But I don't remember if i mentioned I notched the frame rail on the passenger side for clearance for a 4" downpipe. After doing a few test holes with a drill bit i found the places i wanted to cut, there is inner structure inside the rail, so i cut a piece out inside of it... the added 3/16" plates inside the rail and plated the whole piece that was removed with 3/16" plate. The piece that was removed was 18 gauge sheetmetal. 2 layers. The new piece will be as strong or if not stronger than before. I had pics of everything cut out and the whole process, I just have to find my memory card and upload them. The few pics i have are after all the welds have been grinded smooth a then layer of body filler applied. Also notched the fire wall for the clutch master cylinder reservoir lid to have more clearance, and shaved a few holes, just gotta clean the rest of the bay and scuff it , then primer will be applied.
