Alaskan Impreza Club
Go Back   NASIOC > NASIOC Chapters > Alaskan Impreza Club Forum -- AKIC
Old 06-06-2013, 10:18 PM   #1976
coqui2004miguel
Member#: 189901
02 WRX Bugeye
Aspen White, WRB interior
[quote=Frmrbob;39966371]
Originally Posted by coqui2004miguel View Post
Roger that. I have a Blouch 20gXT. Do you have a built 2.0L or a hybrid? I'm using a 2006 STI 2.5L shortblock (mahle pistons, scat rods, kings bearings), v6 JDM STI heads (3 angle port job, ferera springs and 1mm over retainers, STI cams).
Dam it's a 2010 WRX. Motor was rebuilt by Cobb, bored out to 100mm. CP pistons, 1000cc ID's, walbro 255 FP , Perrin FMIC, AVO turbo inlet, Cobb SF intake, Cobb BPV, 3port EBCS, STI oil cooler, Crawford AOS, Invidia catless Dp with Q300, Tomie equal length headers, Eibach sway bars, kartboy endlinks, Cobb short shifter, lol the turbo is a Tomioka TD-05 20g I'm sure I'm missing a bunch of other things trying to save up for some comp springs and coilovers just started AutoX up here and loving it
My parts list looks similar to yours lol. It makes me sick to think about the money I've spent.
Background on the car
2002 wrx sedan
Engine mods:
Blouch 20gXT Turbo welded flapper
2.5L short block swap EJ257
ARP headstuds
99.75mm Mahle pistons
Scat Rods
Kings Race bearings
V6 JDM STI 3angle ported heads
V6 JDM STI Cams
Ferrera springs, retainers, and valves (1mm over intake and exhaust)
TGV deletes topfeed
Prosport unequal length header
GT-Spec ewg up pipe with tial 38mm wastegate
Turbo Xs turbo back exhaust
APS 3" hard turbo inlet tube
Cobb short ram intake
Perrin light weight crank pulley
SS autochrome FMIC
Grimmspeed 3port BCS
Crawford Air/oil separator v1
Gates kevlar timing, alternator and accessory belts
Fuel delivery:
Witch Hunter 860cc injectors
Agency Power fuel rails
Walbro 255lph high flow pump
Suspension/Steering Mods:
17x9 DR-31 +28 wheels
Tien Flex coilovers with EDFC
Tien front and rear strut tower bars
GT-Spec subframe brace
GT-Spec rear diff brace
GT-Spec rear trunk brace
Group-N STI motor mounts, tranny mount & pitch stop
COBB 25mm front sway bar
COBB Front endlinks
Whiteline 24mm adjustable rear sway bar
Perrin Rear endlinks
Kartboy rear lockdown bolts
Drivetrain:
2004 STI transmission
Exeddy Stage 1 organic clutch
OEM flywheel
Techna fit SS clutchline
Kartboy rear shifter bushing
Kartboy tranny crossmember bushings
Exterior:
JDM Front grille
JDM SideSkirt front splats
JDM SideSkirt rear sidestrakes
JDM HID headlights
JDM v2 front lip
Brakes:
07wrx 4pot/2pot calipers w/ ebc yellow stuff pads
Goodridge SS brakelines
R1 slotted rotors
Extras:
Mishimoto 9 row Oil Cooler brand new was only mounted -
Mishimoto Radiator
Zero Sports Thermostat
Prosport Gauges- wideband, boost, egt, oil temp, oil pressure, water temp
ARC 1.3bar coolant cap
Beatrush Alternater cover
Perrin Coolant overflow bottle
Cobb Gold Oil cap
Prova Gold Brake cap
Prova Gold Clutch cap
Samco top Radiator hose
Braile 15lb battery
Kartboy shift knob
Hella Horns
coqui2004miguel is offline   Reply With Quote
Old 06-06-2013, 10:23 PM   #1977
coqui2004miguel
Member#: 189901
02 WRX Bugeye
You're on the right path tho with your setup. I plan on running the 1/4 a couple times and some auto cross out here once I retune.
Old 06-06-2013, 10:26 PM   #1978
EvolvedAK
Member#: 100354
2002 Chevy2DLevee
AKLGT's Living Accessory
Impressive amount of suspension work. I assume upgrading the injectors and pump soon for E85?
Seems to me it'll be your first restriction before running out of air.
EvolvedAK is offline   Reply With Quote
Old 06-06-2013, 10:46 PM   #1979
kayetealynn
Member#: 253304
2001 Impreza 2.5RS
Plus MOAR
Finally put them on. Sooooo much better than stock wheels.
kayetealynn is offline   Reply With Quote
Old 06-06-2013, 10:56 PM   #1980
Frmrbob
Member#: 290921
2010 Impreza WRX prm
WR Blue
Sexy :-p
Frmrbob is offline   Reply With Quote
Old 06-06-2013, 10:57 PM   #1981
Frmrbob
Member#: 290921
WR Blue
Nice ya same here still more work and mor monies :-(
Old 06-07-2013, 12:09 AM   #1982
Rookie J
Member#: 281747
2005 Legacy GT Wagon
Element Sponsored
Nice wheels.
Rookie J is offline   Reply With Quote
Old 06-07-2013, 12:15 AM   #1983
kayetealynn
Member#: 253304
2001 Impreza 2.5RS
Plus MOAR
Originally Posted by Rookie J View Post
Nice wheels.
Yeah I'm sure Chano is just waiting for me to put them up for sale... They'd look even better on a black BRZ.
Old 06-07-2013, 12:38 AM   #1984
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
Time for some MOAR low
cosseywrx is offline   Reply With Quote
Old 06-07-2013, 12:58 AM   #1985
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
Put her on dollies and turned her around to power wash the bay and get things prepped for removal.
Big-Sexy907 is offline   Reply With Quote
Old 06-07-2013, 01:15 PM   #1986
coqui2004miguel
Member#: 189901
02 WRX Bugeye
I think the walbro 255 should be ok with the e85. Im going to run a mix of 93 and e85 for now but yes, Im thinking some 1200cc injectors in the future and possibly a fuel pressure regulator when I go full e85. I havent done enough research yet on it to know for sure. I want to enjoy the car as is for a bit before swapping more parts. Im tired of working on it lol.
Old 06-07-2013, 03:22 PM   #1987
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
Lol, I have some 1300cc top feeds I'm not using lol
Old 06-07-2013, 05:09 PM   #1988
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
Those are the monies! Wheels keep getting bumped down in priority for me. Looks so good, K!
Old 06-07-2013, 08:17 PM   #1989
cosseywrx
Member#: 276443
2 of each arrived today!
Old 06-07-2013, 10:19 PM   #1990
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
What brand are those. Never saw blue ones before?
Alaskan EJ20 is offline   Reply With Quote
Old 06-07-2013, 11:14 PM   #1991
cosseywrx
Member#: 276443
Me neither! Mevotech! Was a good price on them from rockauto.com
Old 06-09-2013, 02:16 AM   #1992
EvolvedAK
Member#: 100354
2002 Chevy2DLevee
For full e85 the 255 won't be enough w/ your setup and achieving any decent numbers. You'll most likely need to upgrade to at least a 340. When you upgrade injectors I'd look into going bigger than 1200's. That way if and when you upgrade your car you won't have to immediately replace them again.
Old 06-10-2013, 12:16 AM   #1993
Racer Dubya
some old guy
Member#: 112225
1985 78 HP of Rage!
New clutch, flywheel, plugs, and removed the turbo. Finally able to drive this thing... I forgot what boost felt like.
Racer Dubya is offline   Reply With Quote
Old 06-10-2013, 03:23 AM   #1994
_davin
Member#: 260501
2003 miata SE
Blurple
Question mark.
Old 06-10-2013, 03:50 AM   #1995
Dominator
Member#: 156712
1991 Legacy SS
Pearl White
Probably his "new" LGT.
Dominator is offline   Reply With Quote
Old 06-10-2013, 04:12 AM   #1996
Racer Dubya
some old guy
Member#: 112225
1985 78 HP of Rage!
Yes, was talking about the wagon... Clutch was so bad I've been limping it around the last few weeks.
Old 06-10-2013, 11:10 AM   #1997
Ajschirack
Member#: 310489
2012 WRX
Plasma Blue Pearl
Finally got around to Plasti Dipping my rims!
[IMG][/IMG]
Ajschirack is offline   Reply With Quote
Old 06-10-2013, 02:33 PM   #1998
insane_one
Member#: 301431
2005 Evolution VIII
where did you get that color of plastidip?
insane_one is offline   Reply With Quote
Old 06-10-2013, 03:19 PM   #1999
Dominator
Member#: 156712
1991 Legacy SS
Pearl White
Wheels look great! It won't be hard to spot you around town now.
Check out the Fairbanks Subie meet group on Facebook. We try to get together once a week or so to BS and talk cars. Send a request and I'll add you to the group.
https://www.facebook.com/groups/575736269104050/
Old 06-11-2013, 01:50 AM   #2000
Akrexak
Member#: 100607
2015 DGM STI-His
'14 FXT Touring-Hers
My HVAC fan works again, only took a week to get the part in.
Akrexak is offline   Reply With Quote
