Welcome to the North American Subaru Impreza Owners Club Thursday December 8, 2016
Old 06-04-2013, 04:46 PM   #1
Va_lgt
Member#: 308728
Default Issues logging romraider and lc-1
I need some help. I have about 20 hours into trying to get romraider, the lc-1 and the car to all play nice together and as infuriating as it is I can not get romraider to show the wideband data. The lc-gauge and logger display 7.3afr when started for a few seconds then it drops to o2 saturation. I have even called innovative and they say that the unit is working fine and they can provide no more assistance outside of that. I'm about to the point of just buying a whole different wideband ......
Any help would be greatly appreciated
Va_lgt is offline   Reply With Quote
Old 06-06-2013, 09:21 AM   #2
bebesito21
Member#: 176128
5862 ...baby boosted
I have this same issue with my buddy's car. Except his worked for a day or so then bam nothing. The gauge reads but romraider doesn't. Check ur grounds and wiring. Make sure u are using a good quality USB to serial adapter. Reinstall romraider. Make sure u have the plug in the unused mic port of the innovative harness. Reinstall your drivers. If all else fails......set it on fire...that's what I'm about to do
bebesito21 is offline   Reply With Quote
Old 06-07-2013, 05:59 AM   #3
JonnyV2889
Member#: 197384
2006 WRX Ltd
When you say drops, I'm guessing you're referring to ~22 on the gauge/logworks? Does the gauge display fine w/o your logging setup connected? Did you free air correctly? Did you check your fuel type in the LM programmer? I'd get it working on the gauge correct first before venturing into logging.
I've dicked with mine for many hours matching baud rates to cables and beyond. I can get it to work in romraider but it is a fussy little bitch, I have yet to come up with a system to replicate to get it working first try.
JonnyV2889 is offline   Reply With Quote
Old 06-07-2013, 03:34 PM   #4
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
I had to change my baud rate to 4800, and follow some specific process to a T before it would work. Can't seem to find the thread.
BeastianSTI is offline   Reply With Quote
