Old 09-01-2012, 05:00 PM   #226
drfrisker
Member#: 259920
my cables never came from ebay, i couldn't give negative feedback because i waited so long
drfrisker is offline   Reply With Quote
Old 11-03-2012, 08:15 PM   #227
Viral E
Member#: 242246
2002 Impreza WRX
So I got my VAG-COM cable in today (409.1) and the circuit board appears to be different from either of the two variations previously discovered, HOWEVER it seems to be the same circuit with a different layout on the board and perhaps an extra component.
I was wondering if anyone here like MadJax had any idea how I should MADmod this cable. My K and L lines are not quite so clear-cut so I'm not sure where to proceed. Although the pin layout for the OBDII interface still appears to make sense and I think I have the exact same op-components as well. Below are four pics of the chip so you can get a sense of what I'm talking about. ANY help is greatly appreciated.
Pics:
Front
Back
Viral E is offline   Reply With Quote
Old 12-21-2012, 09:29 AM   #228
Danthrax
Member#: 299368
2014 Impreza 2.0i
To aid anyone in their travels this is what I have found. Using the board displayed in madjax's tutorial with mad mod, test connectors and your flash block jumped you can flash to your ECU using this cable. You need ECU flash 1.32, the drivers for the cable, and your port speed set to 4800 bps. I've seen many people get it to work with bugeyes and other model WRX/STis after the mad mod. I myself tried the mad mod and broke a pin off of the IC chip
I'm ordering another cable to try again on my 02 bugeye. I'll be sure to keep up and let everyone know how it goes so this mystery can be solved.
Danthrax is offline   Reply With Quote
Old 02-15-2013, 11:26 PM   #229
drfrisker
Member#: 259920
^ you didn't say where you got it from/ post a link?
Old 05-18-2013, 03:35 PM   #230
rg3indc
Member#: 356736
I own a 2002 WRX and a BFM cable. Although I can log with romraider and use learning view, I cannot read my ROM using ecuflash.
For those with 02-03 imprezas, how are you getting this to work? What version of Ecuflash? Special drivers? What operating system are you using?
rg3indc is offline   Reply With Quote
Old 05-18-2013, 04:00 PM   #231
Madjax
Member#: 299271
2002 Forester 2.0 XT
You have to Madmod it , ecuflash 1.32 or 1.28
Madjax is offline   Reply With Quote
Old 05-18-2013, 06:55 PM   #232
rg3indc
Member#: 356736
Sorry for blabbiling, but I can't find a dedicated madmod thread, only this:
http://forums.nasioc.com/forums/show...php?p=36951245
It does not list what Ecuflash drivers to use, or anything about setting serial speeds. Can anybody link me to a thread with more information?
Old 05-19-2013, 06:34 AM   #233
quazimoto
Member#: 70395
This is the thread. Way to read the whole thing..........post #149.
http://forums.nasioc.com/forums/show...&postcount=149
Old 05-20-2013, 08:20 PM   #234
Trnc
Member#: 357022
Pics:
Front
Back
Any progress on this one? I have one of those laying around too, and im not sure if it will work:\
Can anyone tell me where to get the cable that works with the mod?
Trnc is offline   Reply With Quote
Old 05-24-2013, 05:20 PM   #235
mikeyPSF
Member#: 236475
I can't tell you which Chinese cable will best work with this hack but here's something I posted in another thread that is relevant to using EcuFlash with unsupported hardware. The question in the other thread was specific to OS support in EcuFlash, but the general idea is the same. Something to consider in the event you might ask yourself why should you consider purchasing an actual OpenPort from Tactrix.
-Mike
"Why do we do we spend timing working on OS issues? We spend time on OS issues (upcoming release has improved install for Windows Vista), new features, and new vehicle support (two addition ECUs in the works now), because supporting and creating a better product for the community is the focus of our company. Our daily work is funded by the sales of the OpenPort. We're also getting ready to hire another customer support person and eventually we'd like to add a third full time developer.
You should consider purchasing an OpenPort because it's assembled in both Washington and California, not overseas, so sales supports physical labor in two US states and two companies. Your purchase supports EcuFlash development. You receive lifetime support with our hardware & software, even if you aren't the original owner. You support the growing of a small business that works to make tools of value to this community. We think those facts make us pretty unique in this space and good reasons to consider purchasing our hardware to support US production and development of an affordable product."
mikeyPSF is offline   Reply With Quote
Old 06-08-2013, 04:22 PM   #236
robbyredneck
Member#: 346999
2003 wrx
blue
thanks so much madjax. to all you other guys. when your doing your ebay search just look for" vag com cable ftdi " if i had done that on the first try i would not have gotten the wrong chip-twice. works great on my 03
robbyredneck is offline   Reply With Quote
Old 08-08-2013, 01:17 AM   #237
moosen
Member#: 313040
2003 Wrx Hybrid
Just so you know. I was succesful and have reflashed over 80 times. Just out of curiousity is this capable of reflashing 32bit stuff or just 16bit?
moosen is offline   Reply With Quote
Old 11-22-2013, 06:08 PM   #238
Storm
Member#: 5218
96L Most Over-
Developed Beater
Bump up from the dead. My BFM cable will read, log and test write, but won't write to the ECU despite my green diagnostic plugs connected and flash block jumpered. Dreaded programming voltage too low (3.40v). My cable is like the one on the right in post #216. It's got the 6.000mHz crystal onboard. Is there a mod I can do to be able to use this cable for flashing? This is my first foray into ECUFLASH and romraider. My other project is using standalone.
BTW: 04 WRX
EJ257/EJ20 hybrid
TD04
3" catless TBE
Originally Posted by Purpose_Built View Post
My wires came loose from the board. Anyone know what order the wires attach to the board in? My board is obviously the one on the left
Thanks,
Jay
Old 11-27-2013, 08:42 PM   #239
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
I'm not familiar with the term bfm, but I have an alphabid cable for my 2005 Sti. I can do everything I need to with it. Read, write, etc without any issues. My understanding is that canbus vehicles are different though. I think that is 06+ Wrx/sti
BeastianSTI is offline   Reply With Quote
Old 11-28-2013, 12:01 PM   #240
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
No, the WRX/STi was not canbus in 06-07.
BFM is a company... Busted Finger Motorsports
My Vag-Com cable has successfully flashed an 04 FXT, 07 WRX, 05 and 07 STi, and has been used for everything other than flashing an 05 WRX.
Old 01-05-2014, 09:54 PM   #241
Storm
Member#: 5218
96L Most Over-
Developed Beater
Some sort of update here. I have the BFM cable with the board on the RIGHT in this picture:
After contacting Madjax about a madmod for this circuit and a couple emails with specifics, I wasn't really any closer to a solution.....or so I thought. I tied together OBDII plug pin #'s 9&15 and 11&16 and tried a flash cycle. Suprisingly, it worked! The map I flashed didn't run good, so I flashed it back to what it was before and had success.
I don't know if it is necessary to desolder and lift legs on component U2 and add some jumpers to U1 (of the circuit shown on the LEFT in the above pic) but from what I can see, simply applying +12vdc to the L and K pins on the OBD plug allows me to use this BFM cable.
YMMV,
Jay
Old 01-06-2014, 09:27 AM   #242
Madjax
Member#: 299271
Hi Storm,
So you've only done the 2nd part of the mod and it works ?
Pins 11 - 16 are for +12v
Pins 15 - 9 are for L line
Never apply 12v on L or K line !!!
Old 01-06-2014, 06:21 PM   #243
Storm
Member#: 5218
96L Most Over-
Developed Beater
Yeah, I ran one jumper from 9 to 15 and a separate jumper from 11 to 16. Since my board is different from the instructions, I figured I would see what happens by providing +12vdc to where it needed to be (based on previous pictures and explanations in this thread). I successfully test wrote and then flashed a ROM to my ECU (twice). If there is a way to mod this other circuit in the same manner as those shown above, I'll try that too!
My next step is to go through and build a ROM with input from someone smarter than me, in hopes that it'll run better. I'm only looking to boost my milage at this point.
Originally Posted by Madjax View Post
Hi Storm,
Thanks for all the help and work to make these off brand cables useful!!!
Jay
Old 02-01-2014, 03:52 PM   #244
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
Hey madjax will this one work? It looks almost identical but the board is shorter and uses extensions to reach the obd pins.
2gnt2wrx is offline   Reply With Quote
Old 07-05-2014, 02:48 PM   #245
mike.hutch
Member#: 395425
Jay
Hi there, I just signed up to post this, I'm in the UK, and I've been trying to get my cable to read the ECU in my 2003 blobeye WRX. I have the same cable as you have modified, I'd just like to ask which version of ecuedit you used? as I'm still having no luck.
mike.hutch is offline   Reply With Quote
Old 09-05-2014, 12:06 PM   #246
phil18_1
Member#: 400824
For whose who asked via PM: more MadMod (forget the 12v regulator, it works)
General view:
Cut one:
Unsolder and lift one:
Wire 2:
Direct Plug +12v and L line (forget the 12v regulator):
Have Fun!
Hi Guys
Ok i have have a udm wrx 2001. i have compleated the the cable mod and double checked it three times ecuflash is just not connecting to the ecu im getting:
[17:02:48.205] Version 1.32.1399
[17:02:48.205] 11 memory models read.
[17:02:48.220] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[17:02:48.361] 218 ROM metadata models scanned.
[17:02:48.361] checksum module "subarudbw" loaded.
[17:02:48.361] flashing tool "wrx02" loaded.
[17:02:48.361] flashing tool "wrx04" loaded.
[17:02:48.361] flashing tool "sti04" loaded.
[17:02:48.361] flashing tool "sti05" loaded.
[17:02:48.361] flashing tool "mitsukernel" loaded.
[17:02:48.361] flashing tool "mitsukernelocp" loaded.
[17:02:48.361] flashing tool "shbootmode" loaded.
[17:02:57.886] SSM2 read ram byte addr: 000061
[17:02:59.975] readback fail
[17:02:59.975] unable to verify test mode
[17:03:01.037] denso02_bootloader_cmd_start
[17:03:01.333] readback fail
[17:03:02.255] denso02_bootloader_cmd_start
[17:03:02.645] readback fail
[17:03:03.566] denso02_bootloader_cmd_start
[17:03:03.894] readback fail
[17:03:04.814] denso02_bootloader_cmd_start
[17:03:05.157] readback fail
[17:03:06.078] denso02_bootloader_cmd_start
[17:03:06.398] readback fail
[17:03:06.554] kernel get version
[17:03:06.741] readback fail
learning veiw connects first time so does romraider.
i have green connectors connected and i have also jumpered the white connector to. any one can help please thanks Phil
phil18_1 is offline   Reply With Quote
Old 11-29-2014, 11:33 AM   #247
bako
Member#: 226211
2002 impreza WRX JDM
blue
ok, people, lets' filter **** out of this subject.
bako is offline   Reply With Quote
Old 11-29-2014, 11:47 AM   #248
bako
Member#: 226211
blue
VAG COM CABLE KKL with FT232RL chip is working one for logging, reading and flashing.
I'm responsible for that, because right now I have 2 same cables in front of me. bot are vag com cables with blue box and silver wiring.
-one only is good for logging my 02 jdm wrx
-another one is good for logging, reading the roms and flashin as well (even for my 02 jdm wrx. do not know anything about newer ECU-s and flashing options).
the difference between them is in the chip's marking (lettering)!!!!!!!!!!!!!!!!!
one of them which can flash 02wrx ecu does have written:
FTDI
1417-C
GP070081
FT232RL
on the little chip it has a letters:
3AA29KK04
LM339
another one, which I can't make to read or flash ECU does not have any letters on the big chip, it's a noname chip!!!!!
on the little one it has the letters:
28ANSOM
LM339 G4
so the only problem is to find proper cable with blue box and silver wire, which does have chips with mentioned letters:
FTDI
1417-C
GP070081
FT232RL
3AA29KK04
LM339
Old 11-29-2014, 11:57 AM   #249
bako
Member#: 226211
blue
Originally Posted by phil18_1 View Post
Hi Guys
can you open the box of your cable and see if the big chip is FTDI branded or noname one?
Anyone try the K&N Typhoon Intake system for the WRX? BrysImpreza Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-02-2002 02:03 PM
Anyone try the Eibach springs from Subaruparts.com? BrysImpreza Brakes, Steering & Suspension 1 09-20-2001 05:53 PM
Anyone try the Forge strut tower bar? dead-eye Brakes, Steering & Suspension 2 07-30-2001 09:00 PM
Anyone try the clear Subaru fog light protectors? Arnie Technical Forum Archive 3 08-22-2000 09:59 AM
Anyone try the AVS Sports? Tim Prudence Technical Forum Archive 14 07-28-2000 12:49 AM
