Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Commercial ECU Reflashes
Old 09-05-2006, 11:51 PM   #1
waxdass
Member#: 53979
Default ECUTEK, WALBRO pump and SARD 800cc's.. PROBLEM
Hi
I have just got my car tuned, runing a walbro 500hp type in-tank fuel pump, ecutek reflash, sard 800cc injectors, FP green which has been ported, ceramic coated, angle mounted etc
a heap of supporting mods, running 25 psi...
My tuner could not tune the injectors at idle, or hardly any load... The target parameters set in ecutek were stoich, although it was running excessivly lean with even 25% correction. He also did scale the injectors, but this wouldnt help things at all...
Once there was load, it seemed it started correcting itself properly (although out to some extent).
after 500rpm the walbro was running out afr's started to go lean
So im asking - to those ppl who run ecutek and big injectors, how is your idle? And how did u manage to controll it properly? Mt tuner is suggesting that the Walbro pump i have is not supplying enough fuel pressure to atomise the fuel with the big injectors...
opinions?
thanks
waxdass is offline   Reply With Quote
Old 09-06-2006, 01:43 PM   #2
WhiteKnight
Member#: 56133
2004 Euro spec Sti
Black - Rotated gt3037s
Ask him if he set the correct parameters for Injector Battery compensation map or something similar
WhiteKnight is offline   Reply With Quote
Old 09-09-2006, 10:19 AM   #3
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
maf calibration table...
scale injectors down to ~750cc
Old 09-09-2006, 10:32 AM   #4
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Did he set the dead times?
cdvma is offline   Reply With Quote
Old 09-10-2006, 12:13 AM   #5
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
+1234
Old 09-10-2006, 03:45 AM   #6
waxdass
Member#: 53979
you cant set deadtimes on ecutek... as far a iv been told
BTW - how can i run more than 1.8 bar on ecutek without hitting boost cut! ??
Old 09-10-2006, 09:15 AM   #7
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
if ecutek can't adjust dead time, that's seriously weak, and you should spend 100 bucks, get a tactrix cable and reflash it yourself.
Old 09-10-2006, 10:39 AM   #8
waxdass
Member#: 53979
I have that cable. I'm not confident in touching the ecu - especially without a wideband afr meter
Old 09-10-2006, 11:57 PM   #9
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
With EcuTek you can adjust the Injector Latency.
This sounds like what the problem is in your case. You will need a complete re-tune when the injector latency is changed.
mick_the_ginge is offline   Reply With Quote
Old 06-09-2013, 12:08 PM   #10
Amaan_ej20
Member#: 358865
2003 2L JDM WRX STI
does anybody have the injector latencies for the sard 800cc injectors for a 2l wrx sti? i have the same problem, running lean with more than 25% correction. im running a fuel base pressure of 45psi
Amaan_ej20 is offline   Reply With Quote
FS: brand new Walbro pump and kit for Wrx and Sti FREE SHIPPING StatiK Private 'For Sale' Classifieds 4 07-13-2006 08:42 AM
Walbro pump and Injectors Mustang Raper Service & Maintenance 17 09-19-2005 12:58 AM
wtb walbro pump and injectors LatentWagen Private 'Wanted' Classifieds 1 06-26-2004 12:00 PM
FS: walbro pump and TXS BOV cre Private 'For Sale' Classifieds 11 04-02-2004 02:12 AM
