#1 |
Member#: 177
Vehicle:The 93 Imp W/EJ20K flat black |
howdy
so i went to change my 1.8 fuel pump to a nice used WRX one ... the 1.8 pump is huge ... and not even close to the same size as the WRX pump and they are not interchangable not even close any ideas .. i don't want to go to the junk yard .. but that may be the only way
#2 |
Member#: 3357
Vehicle:2002 WRX Black |
size the only difference?
#3 |
Member#: 177
no
the diamater and length are both differnt and the pickup sock up won't connect .. |
#4 |
Member#: 874
RMIC
Vehicle:2003 Honda S2000 2004 Mazdaspeed MX-5 |
I think the best way to do it is fabricate a jumper. The jumper would have the male clip that slides into the pump on one end and a smaller male clip that slides into the recepticle(sp?) on the tank access panel on the other end.
As for where to find these clips, I'm not too sure. I was able to find one pre-made. Good luck. |
#5 |
Member#: 145
Vehicle: Banned to Housework for Summer |
go to the Junk yard and find '92+Civic or '90+ Integra and pull out the rear seat. You will find an access cover in the center where the fuel pump is. You will need to cut the connector to use on your new fuel pump and you can also use the tubing and filter bag from it as well. There are other cars that use the same connector but they are harder to access.
You will have to splice in the new connector to your existing wiring and change out the tubing as well as fit the filter bag onto your new pump. As for securing it, I ziptied my fuel pump against the metal bracket. |
#6 |
Homicidal Maniac
Moderator Member#: 1612
Vehicle:2008 STI |
What year did Subaru switch to the compatible fuel pickup/wiring etc?
-Jon |
#7 |
Member#: 874
RMIC
I think it was 95 or 96.
#8 |
Homicidal Maniac
Vehicle:2008 STI |
Excellent...
-Jon |
| Thread Tools | |
| Display Modes | |
| How does a car idle without a fuel pump? | railguy | Built Motor Discussion | 9 | 08-05-2007 09:17 PM |
| JDM ver.7 or 8 Fuel Pump? | Smoby | Subaru Conversions | 1 | 05-06-2006 05:21 PM |
| Is the AP safe to run with stock injectors and fuel pump on an STi? | Irishman | Engine Management & Tuning | 5 | 08-30-2004 01:10 AM |
| 1.8 fuel pump | NicEJ25 | Normally Aspirated Powertrain | 2 | 04-11-2003 10:46 AM |
| how to upgrade MY96 ej25 to MY97 & up | biggreen96 | Normally Aspirated Powertrain | 2 | 06-13-2002 08:43 PM |
