Old 06-08-2013, 03:19 PM   #1
Rememo
Member#: 340728
2013 Impreza 5-spd
Default Door panel removal and stock speaker info. (instructions)
I finished the sound deadening of the front doors today, so I snapped some photos along the way.
First pop up the small cover in the door latch that hides the Philips head screw, and remove the screw.
Now pop up the small cover hiding the Philips head screw in the door handle, and remove the screw.
Starting at the hinge side of the door, slip your fingers inside the door panel and give it a sharp pull towards you.
You may need to slide something behind the panel to pry it up a bit. Don't scratch the paint!
You'll hear a distinct "POP" when the panel releases in that spot.
Work your way around the door counter-clockwise until the entire panel is loose. Once the panel is loose, lift it up to release it from the window area.
Here you can see that there are seven attachment points. (The white clip grommets)
Once you have lifted the panel free of the door, it will still have wires and the door latch connected to it.
To disconnect the wires, press on the release with a screwdriver and pry the plug out. Hint: Lay something soft on the ground so you don't scratch the panel while you're maneuvering it.
The drivers side has three wire connections. The passenger side has two.
Once the wires have been removed, you need to detach the door latch mechanism. Remove the two screws and the black plastic retainer. The latch will pop up and out, and the door panel will be free of the door.
You will probably see that some of the clip grommets have stayed in the door. While you can remove them using your fingers, it's much easier with the proper tool. Remove any stragglers and put them back on the door panel. Watch out for the black washers that are part of the grommet. Subaru uses two different grommet part numbers in the door, one has a washer, the other does not.
In this photo I have already removed the plastic that is attached to the door. I find it amazing that these doors can do so well in crash tests, since they are SO thin. (sorry about the blur)
Rememo is offline   Reply With Quote
Old 06-08-2013, 03:20 PM   #2
Rememo
Member#: 340728
2013 Impreza 5-spd
Many people have said that the stock speakers (non-Kicker) are OK.
When I removed the panel and saw that the speaker wasn't paper, I thought maybe I had wasted money on the Polks I purchased.
However, as soon as I removed the speaker, I knew I had to replace it.
The speaker materials may be decent, but they only weighs 8.75 ounces!!! FYI: The speakers are 4 ohm.
And there is really no magnet to speak of....
Ah... Much better
Old 06-08-2013, 03:40 PM   #3
TObject
Member#: 320185
2012 Impreza 2.0i
Awesome, man. Thank you very much for all the pictures and detailed instructions.
TObject is offline   Reply With Quote
Old 06-09-2013, 12:29 AM   #4
hanta20
Member#: 320594
Do you notice a difference in sound quality? I recently set my stock speakers to almost entirely front faded only and it tightened up the speakers tremendously. It is making me put off purchasing after market speakers a little while longer.
hanta20 is offline   Reply With Quote
Old 06-09-2013, 04:18 PM   #5
Rememo
Member#: 340728
2013 Impreza 5-spd
Yes, but part of that could be attributed to the installation of the sound deadening materials.
I was able increase the bass and midrange without distortion. They sound better than stock at higher volumes. I have loudness turned off and the EQ set to "through".
Old 06-09-2013, 08:32 PM   #6
ICE_NY
Member#: 324263
2013 Impreza Sport
Default Speakers
Hey man, great write up for the not so skilled user like "moi". I would like to know if you replaced the four speakers or only two?
Definitely thanx for the insight.
ICE_NY is offline   Reply With Quote
Old 06-09-2013, 09:30 PM   #7
Rememo
Member#: 340728
2013 Impreza 5-spd
Only two at this point. I need to save some more cash to sound deaden the rear doors. When I crack those open, I will replace the speakers, since I already have a second set of Polks sitting around.
Old 06-09-2013, 10:49 PM   #8
hanta20
Member#: 320594
What did you use to deaden sound? Is there any discernible difference since you have only done the front two doors?
Old 06-10-2013, 09:24 AM   #9
Rememo
Member#: 340728
2013 Impreza 5-spd
I placed pieces of CLD on the outer skin of the door until it no longer resonated when I tapped on it. I also placed a couple of pieces on the inner door skin. Then I hung a sheet of MLV (mass loaded vinyl), with closed cell foam glued onto it, onto the door.
The MLV is heavy. Between that and the new speakers, I probably added a couple of pounds to each door. Someone posted photos of their doors with MLV installed, but I can't find the post.
Yes, I can already notice a reduction in noise. I can't wait to tackle the floor.
Everything was purchased from:
http://www.sounddeadenershowdown.com...product-prices
Old 06-13-2013, 11:10 AM   #10
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i posted pictures, can't remember where
Old 06-13-2013, 02:28 PM   #11
Rememo
Member#: 340728
2013 Impreza 5-spd
Me either. I knew it was you, so I searched through a bunch of your posts, but I couldn't find the photos.
Old 06-13-2013, 02:44 PM   #12
BayAreaSubie
Member#: 342924
2013 Impreza Sp Lim
Satin white pearl
thanks for the write up, I think this will be my next project for the Subie.
Man, the magnets on the stockers are puny!!
BayAreaSubie is offline   Reply With Quote
Old 06-13-2013, 04:59 PM   #13
winglik
Member#: 317022
2013 Impreza Sport
Dark Grey Metallic
Thanks. Are you going to post a sound deadening guide soon?
winglik is offline   Reply With Quote
Old 06-13-2013, 08:19 PM   #14
Icculus19425
Member#: 359375
2013 Impreza Sp Prem
Gray
Thanks! this is great
Icculus19425 is offline   Reply With Quote
Old 06-13-2013, 10:55 PM   #15
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Old 06-14-2013, 11:36 AM   #16
Angelus911
Member#: 89967
2012 Impreza Sport
So you guys recommend using RAAMmat + closed cell foam + MLV? I've been looking at just getting the RAAMmat and the CCF from RAMM, but I just wonder if its worth is to get MLV for the final layer as well. I see that's basically what you did flyboy, are you happy with the results? How much did all that ish cost you?
Old 06-14-2013, 12:30 PM   #17
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Overall happy, the mlv was 80 shipped for 40sq ft. The ccf was 25 from home depot
The raammat was around 100, but I have 5 or 6 of the 11 sheets I ordered left over. I ordered way too much, you only need 1 sheet per door for it to do it's job.
I plan to do the footwells too, just haven't got around to it yet. So to clarify, the materials I bought is enough for
Hatch floor and door, all doors, front footwells, all for about 200
Ccf won't do anything by itself, it is just used as an isolator to separate the door from the mlv.
Old 06-17-2013, 07:02 AM   #18
phenryiv1
Member#: 91212
2011 WRX 5DR
Was that the frost king? And it does do a little on it's own to absorb road noise, but that is about it.
Old 06-17-2013, 08:04 AM   #19
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
No, it is a ccf for floor underlayment. I only used it to separate the mlv from the raammat/inner skin of the door. You can see what I used in the links to my picture posts above
Old 06-21-2013, 03:42 PM   #20
Angelus911
Member#: 89967
2012 Impreza Sport
^What did you use to attach the MLV to the door? Some sort of aluminum tape?
Old 06-21-2013, 07:01 PM   #21
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Exactly what I used
Old 06-24-2013, 02:40 AM   #22
cnunez13
Member#: 195460
2013 Impreza Sport
were the polk speakers "plug and play" with the stock connections? looking to upgrade the speakers on my impreza too...
anyone install a sub under their seats yet? like previous subaru models?
cnunez13 is offline   Reply With Quote
Old 06-24-2013, 08:50 AM   #23
Rememo
Member#: 340728
2013 Impreza 5-spd
No, they are not plug and play, but these will make them plug and play (assuming you also buy an adapter, or drill new holes):
Amazon.com: Metra 72-8104 Speaker Connector for Select Toyota Vehicles: ElectronicsAmazon.com: Metra 72-8104 Speaker Connector for Select Toyota Vehicles: Electronics
Old 06-24-2013, 03:28 PM   #24
phenryiv1
Member#: 91212
2011 WRX 5DR
Yes. Buy those and mounting adapters mentioned here:
You'll need some speaker spacers: http://www.subaruaudio.net/subaru-speaker-spacers/
Old 06-24-2013, 04:20 PM   #25
cnunez13
Member#: 195460
2013 Impreza Sport
Ok got it. Polk speakers, Toyota adapters, and spacers
