Welcome to the North American Subaru Impreza Owners Club Sunday February 7, 2016
Old 06-11-2013, 09:25 PM   #1
HAL1
Member#: 58926
2013 WRX 5dr ISM
2011 Infiniti EX35
Default New 2013 delivered at 40 psi tire pressure
My car came new from the dealer at about 40 front and 40 rear. I know that's a bit high but I have been comfortable with it's driving characteristics.
Is this TOO high? I'm most concerned about handling and stiffness even at the expense of excessive wear. Summer in Phoenix is above 105 every day if that means anything
HAL1 is offline   Reply With Quote
Old 06-11-2013, 09:28 PM   #2
subaru3169
Member#: 55252
* pullup bar *
just dial it down then
subaru3169 is offline   Reply With Quote
Old 06-11-2013, 09:28 PM   #3
SoapBox
Member#: 204578
S54 E46, N54 E82,
N55 E84, AKA REX8
Why don't you try lower it, and see if the handling changes to the point that you don't like it?
SoapBox is online now   Reply With Quote
Old 06-11-2013, 10:24 PM   #4
HAL1
Member#: 58926
2013 WRX 5dr ISM
2011 Infiniti EX35
I meant I like the current handling but was wondering if there are compelling reasons that this 40/40 might be too high.
Old 06-11-2013, 10:59 PM   #5
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
there is NOTHING AT ALL wrong with running 40 psi in tires unless you determin through experimentation that 40psi is too much
tires are aired up at the factory for shipping so they dont flat spot in transit and so the car is 'firmer' and doesnt bounce so much
bloody hell
Old 06-12-2013, 06:32 PM   #6
dmk0210
Member#: 284114
2011 WRX Sedan
World Rally Blue
Originally Posted by Uncle Scotty View Post
there is NOTHING AT ALL wrong with running 40 psi in tires unless you determin through experimentation that 40psi is too muchl
More tire wear in the center?
The door card says 33/32
dmk0210 is offline   Reply With Quote
Old 06-12-2013, 06:41 PM   #7
sc00by4life
Member#: 97135
This is 100% specific to the tire being used.
Right, for stock sizing and tires that came with the car. Again, its subjective and all comes down to the exact setup one uses.
Old 06-12-2013, 08:41 PM   #8
Uncle Scotty
OK buy Nates beans
OOOhhhhh...you are one of those who don't know what you are talking about
OK....got it
Old 06-13-2013, 02:43 PM   #9
dmk0210
Member#: 284114
2011 WRX Sedan
World Rally Blue
The OP said the car was new from the dealer. OEM tires.
I agree that for my aftermarket wheels and tires, that info may no longer be valid.
Old 06-13-2013, 02:43 PM   #10
dmk0210
Member#: 284114
2011 WRX Sedan
World Rally Blue
OK....got it
Nice.
What I said is what it says in the owners manual.
So what is wrong with the information the OEM provides?
I mean seriously, I'm asking.
Old 06-13-2013, 03:04 PM   #11
cptplt
Member#: 22439
02 WRX
black
The OEM "recommended" pressure on the plate by the door is the minimum pressure they think most of their customers will like the best in terms of ride, handling. As long as you do not exceed the tire manufacturers MAXIMUM pressure ( which is on the sidewall) you should be safe though your ride may be a little harder at very high pressures but its all different strokes for different folks.
Better 5 over than 5 under for any tire pressure! Unless you want to be like the Ford Explorer and Firestone tire affair.
One thing which has always puzzled me is that while they always say its the cold pressure which is important. What if you do wake up in the mountains of AZ say and the pressure is just below the tire manufacturers max and then the temp rises say 4o deg F (which should be a 4psi change) over the course of the day say . Should you adjust for that?
cptplt is offline   Reply With Quote
Old 06-13-2013, 03:06 PM   #12
atomicfire
Member#: 136296
2005 STi
I've been running mine around 36-42psi for a while. Higher pressure leads to a firmer ride and slightly better wear characteristics. I found that going higher than 46 or so makes it wear the center of the tread more but again it will depend on what tire you have.
Nothing wrong at all with 40psi.
atomicfire is offline   Reply With Quote
Old 06-13-2013, 03:08 PM   #13
sc00by4life
Member#: 97135
its also based on subaru's fuel economy/comfort targets.
there is no reason you can't play around with tire pressures. 40psi in that tire might not necessarily be "over filled" which would cause excessive center wear.
Old 06-13-2013, 03:53 PM   #14
dmk0210
Member#: 284114
2011 WRX Sedan
World Rally Blue
Thanks for the intelligent answers guys.
I've always been worried about going higher than 38 or so, figuring it's going to heat and raise pressure as you drive.
My understanding is that the OEM pressures are at something like 60-70deg f. ("room temperature"). Since tires warm up as you drive, I'd think the 40deg outside air temp would be negligible.
Everything I've read says check it in the morning, but what if it's minus 10deg in the middle of the winter? I suppose you are supposed to add a few lbs if it is under room temp?
Old 06-13-2013, 10:47 PM   #15
Uncle Scotty
OK buy Nates beans
you shouldn't adjust tire pressures like that or for that...and there is no reason to be anywhere near max inflation, cold
That can be VERY bad as it can cause loss of control...for many reasons
depending on the tire, the MAX inflation should be 44-51psi.....if you start at 36psi...you wont get anywhere near that
Old 06-17-2013, 03:26 PM   #16
MorganJ
Member#: 203823
2009 WRX STI
2001 V7 JDM STI
I enjoy my STI best with 38-40 PSI of air in them.
MorganJ is offline   Reply With Quote
