Old 06-12-2013, 06:09 AM   #1
jacky599r
Member#: 137631
2006 WRX
Red
Default Air Conditioning Problem
Hi guys, need some help regarding an air conditioning problem.
I just did an overhaul for my car. New engine internals and associated upgrades. All is fine for the start but my air conditioning is not cold. Ot constantly blowa hot air. A check on the freon is ok. What could be the problem?
Jacky
jacky599r is offline   Reply With Quote
Old 06-12-2013, 06:31 AM   #2
Cathexis
Member#: 335445
2012 WRX - BLK STIG
Stg. 2 - 287whp/317wtq.
Have you checked the compressor for current? Relay?
Cathexis is offline   Reply With Quote
Old 06-12-2013, 11:53 AM   #3
jacky599r
Member#: 137631
2006 WRX
Red
All checked Sir
Old 06-12-2013, 01:07 PM   #4
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
When the Ac is running is the compressor pulley with the 3 knotches spinning? I was just in your same boat turns out my compressor was leaking and 1200 later i have working ac. SUCKS!
Slimsti is offline   Reply With Quote
Old 06-13-2013, 12:40 AM   #5
jacky599r
Member#: 137631
2006 WRX
Red
It is! I'm suspecting some electrical issues. Any common electrical problems associated with 2.5s that will cause the air conditioning not to work?
Old 06-13-2013, 10:40 PM   #6
jacky599r
Member#: 137631
2006 WRX
Red
There is a fault code.
P0118, Engine Coolant Temp, Sensor Circuit High input
Anyone has experienced this before?
Old 06-13-2013, 11:38 PM   #7
ryansx
Member#: 324527
2013 wrx
white
I have seen on some other makes where ECM gets high engine coolant temp reading it will command ac off
ryansx is offline   Reply With Quote
