Old 06-14-2013, 11:44 AM   #18226
nubsub
Member#: 313575
2012 Impreza 2.0i HB
Originally Posted by jsteg View Post
I don't think they did considering the article you quote states them paying over $7 for the filter! I don't even see where you see the $10 comment.
yes, it really is there and obviously a typo:
"We handled the 7,500-mile oil change ourselves. The Impreza was easy to work on, and the price was right. We spent under $10 for the DIY, while the dealer visits averaged $113."
for me, it's
$7 filter
$1 for crush washer
$25 + $2* for oil (assuming no rebate)
= $35
still a great savings over the dealer. (mine wants ~$90 "on special" for the synthetic change.
*$2 is for the 1/3 of a quart i buy which adds to the 5 qt jug.
nubsub is offline   Reply With Quote
Old 06-14-2013, 12:49 PM   #18227
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Originally Posted by nubsub View Post
$7 filter
$1 for crush washer
= $35
And what's your best price after a rebate?
I think I got the oil for $14 once after the Pennzoil Platinum $10 rebate, so I guess that oil change will be approximately $21 (I don't buy crush washers because I have a Fumoto valve).
Good price for the oil change, but nowhere near $10 for the complete service. Maybe the author was thinking that they already had the oil on hand and only had to buy the filter, but that's cheating.
Old 06-14-2013, 01:20 PM   #18228
nubsub
Member#: 313575
yeah, i got that rebate, too. (assuming it comes in) i think after sales tax, it worked out to $14 for the 5 qt jug of Pennzoil Plat. (22.97 for 5qts although someone told me that the price has since gone up to $24.97 for the 5 qt jug). i had previously paid $26.97 for Mobile 1.
so yeah, my best i think would be around $14 + $2 (0.33 qt) + $8 for filter and washer = $24
either way, much cheaper than the dealer, and i humbly think i do a more thorough job.
Old 06-14-2013, 01:34 PM   #18229
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Absolutely no doubt.
You should give the Fumoto valve a try. Less mess, and you don't have to buy crush washers anymore.
Old 06-14-2013, 02:04 PM   #18230
fistv
Member#: 350063
2013 Impreza sport
Whats with this crush washer stuff ? doesn't the drain plug just have a normal washer on it like every other car I've ever owned or one of the nylon washers like they put on the magnetic drain plug replacements.
fistv is offline   Reply With Quote
Old 06-14-2013, 02:14 PM   #18231
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
A crush washer is a washer made of soft material (like aluminum) that gets squished when tightened so that it conforms to any irregularities in the finish of the oil pan or the drain plug itself. It's a one-use washer, since once it's squished, it can't be squished again.
With the Fumoto, I just used the washer that came with it. Since the valve is installed once, there are no washers to replace with each oil change. But the best thing is that I have one of the "N" model valves with the nipple for connecting a rubber tube. This allows you do dress the tube in such a way as to drain into your drain pan without splashing and making a mess.
As you can imagine, 0W-20 oil is extremely thin when hot, and so it comes out FAST when removing the original drain plug. The Fumoto/tube combo gives you the control you need to avoid this mess. And if you ever want to submit an oil sample for analysis, the Fumoto makes it easy to take out a controlled amount of oil for testing.
Old 06-14-2013, 02:39 PM   #18232
Angelus911
Member#: 89967
2012 Impreza Sport
Has anyone else had an issue with their rear hatch latching? Mine seems like its extremely hard to latch now, and I've noticed multiple times while getting groceries/putting things in the back, that while driving away the door ajar light is on, and its always the hatch latch.
Will make an appointment sometime this summer for all of the various things that need to be done (remote start recall, driver's seak squeak fix, and this rear latch).
Old 06-14-2013, 03:31 PM   #18233
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
I reused my crush washer for my first diy oil change. No leakage. My dad says he always reuses the crush washers, but I wouldn't do it unless you had no choice.
I have since purchased the same drain valve and its awesome.
Old 06-14-2013, 03:53 PM   #18234
Haunty
Member#: 319378
2012 2.0i Sport Ltd.
That's happened to me a couple times, but it hasn't become a regular thing so far.
Haunty is offline   Reply With Quote
Old 06-14-2013, 04:01 PM   #18235
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Old 06-14-2013, 10:18 PM   #18236
foghelmut
Member#: 328414
2012 Impreza SP 5MT
obsidian pearl black
For the 19mm sway bar, did everyone reuse their hardware? I'm reading the shop manual, and it says "Be sure to use a new flange nut and self-locking nut."
foghelmut is offline   Reply With Quote
Old 06-15-2013, 08:22 AM   #18237
Angelus911
Member#: 89967
2012 Impreza Sport
I'm pretty sure everyone who had a sway bar before Reused the hardware that we had. I don't see why you couldn't as they've been on the car for less than a year. Maybe if they were rusted it would make sense
Old 06-15-2013, 09:32 AM   #18238
Zeeper
Member#: 299286
2015 WRX CVT
If I was a service manager at a dealer I would want the tech to use and bill for new parts, reduces liability for them and it costs them nothing to do this, because they pass the cost along to you. But keep in mind many times the tech will skip reaching for a torque wrench if it is easier to grab another tool.
Personally, I would reuse the hardware you have (if it isn't corroded or bent out of shape), but add locktite and use a torque wrench, using the correct tools should ensure the sway bar does not fall off.
Zeeper is online now   Reply With Quote
Old 06-15-2013, 10:36 AM   #18239
Zeeper
Member#: 299286
2015 WRX CVT
FYI: This link is for the wrong fumoto valve, you need the F108N not the F106N.
Old 06-15-2013, 10:48 AM   #18240
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Umm, are you sure about that? I'm almost positive it's the F106N that fits our cars. As I recall, Fumoto's configurator was wrong for awhile.
Old 06-15-2013, 11:43 AM   #18241
Zeeper
Member#: 299286
2015 WRX CVT
100% sure the F108N is the correct size.
Old 06-15-2013, 12:31 PM   #18242
jsteg
Member#: 329271
2012 Impreza Limited
Ice Silver Metallic
Correct...F108N is what I have installed as well. Best invention EVER for DIYers!
jsteg is offline   Reply With Quote
Old 06-15-2013, 01:08 PM   #18243
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I stand corrected. Sorry for the confusion.
Old 06-15-2013, 03:55 PM   #18244
webster354
Member#: 343343
2014 Impreza 5dr Ltd
I've noticed this is happening a lot lately as well, even when I close it firmly. The bottom trim piece on the inside door seems a little loose so I wonder if that is causing the problem.
webster354 is offline   Reply With Quote
Old 06-16-2013, 01:18 AM   #18245
stevehnm
Member#: 329526
2013 Impreza Spt cvt
Three wraps of yellow teflon tape works just fine. I've used it many times and haven't leaked a drop.
stevehnm is offline   Reply With Quote
Old 06-16-2013, 01:20 AM   #18246
scoutisimo
Member#: 315759
2014 WRX Hatch
Stop being cheap and buy the crush washer.
scoutisimo is offline   Reply With Quote
Old 06-16-2013, 08:03 AM   #18247
G2Spfld
Member#: 354284
2013 Imp Sport CVT
X2- I've always teflon'd drain plugs. I've never had an issue.
G2Spfld is offline   Reply With Quote
Old 06-17-2013, 06:27 PM   #18248
apexracer
Member#: 257754
2012 Impreza Sport P
Camilla Red Pearl
Found this on YouTube. Make your stereo sound better. Hidden features. http://youtu.be/X3wD-jHTN0E
apexracer is offline   Reply With Quote
Old 06-17-2013, 09:15 PM   #18249
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Got my wheelskins cover installed tonight. Hope I don't have to ever redo it!
Old 06-17-2013, 09:24 PM   #18250
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Are you happy with how it turned out? How long did it take? Did you use the baseball stitch?
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
