Old 06-15-2013, 10:05 AM   #1
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
Default Rear galley plug pressure gauge install - Teflon, Gasket Maker or Nothing? (Pics)
Installing s Zeitronix Pressure sensor in the rear galley.
1. Do I need to use teflon tape to ensure a tight seal? Or the teflon tape will act as an insulator and I will get false readings from the sender due to it having a faulty ground? Or should I use oil-resistant silicone gasket maker?
2. There is no torque specs for NPT fittings right? It is just by feel?
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 06-15-2013, 10:19 AM   #2
Gs WRX
Member#: 151066
07 WRX Wagon
I don't know the answer, but I did want to say that I thought I read here somewhere that the thread was BSP and nut NPT. If it is the British std, don't accidentally
Gs WRX is offline   Reply With Quote
Old 06-15-2013, 10:22 AM   #3
Gs WRX
Member#: 151066
07 WRX Wagon
Hit send by accident.....just saying different thread profile so be careful.
Old 06-15-2013, 10:24 AM   #4
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Yes, I have a 1/8" NPT galley plug adapter by Autometer.
Old 06-15-2013, 11:37 AM   #5
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Make sure the MAP sensor you put in there can withstand at least 120 psi. Cold oil pressure is pretty high on start-up and at a minimum 80 psi or 5.5 Bar when the pump is on bypass. If the sensor is rated for it the 120 psi pressure spikes could destroy it.
I used anerobic thread sealing paste. Its better than teflon tape and its safe on oil, fuel, and air fittings.
Old 06-15-2013, 01:42 PM   #6
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
ok, thanks, I have a 150psi (10 bar) low profile Zeitronix.
Old 06-15-2013, 02:06 PM   #7
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Cool, I have the 150 psi AEM sensor in the same spot.
