Welcome to the North American Subaru Impreza Owners Club Saturday May 23, 2015
Old 04-13-2013, 10:11 AM   #51
ByeByeSRT8
Member#: 338663
2013 WRX Sedan
Just wanted to say thanks for a great thread. Did this install and the fuel pump this weekend and everything went without a hitch. Don't get me wrong, the injectors were a PITA, especially those two brackets and all the stuff you have to take off to get to the bolts. Put it all back together and no leaks. Car runs great! Now it's time to get the new tune dialed in for 93 octane and then switching to E85.
ByeByeSRT8 is offline   Reply With Quote
Old 04-15-2013, 02:10 PM   #52
Overland04
Member#: 293311
2011 Impreza WRX
Leguna Seca Blue
Great man, what size injectors did you do, 850s?
Old 04-15-2013, 03:16 PM   #53
ogboot
Member#: 170906
psm
Bump for some of the best pics i've seen on an install thread. Thanks for contributing!
ogboot is offline   Reply With Quote
Old 04-15-2013, 08:33 PM   #54
ByeByeSRT8
Member#: 338663
2013 WRX Sedan
Injector Dynamics 1000cc. It's what my tuner recommended. Got the 93 octane tune pretty dialed in. Moving on to E85 next. Can't wait!
Old 04-15-2013, 09:16 PM   #55
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
Hey Rob,
Yupp, bigger fuel pump, injectors and a new tune. The 850's will be maxed out with the stock VF-52 on e85. You need around a third more fuel to run flex fuel then standard 93 octane.
If and when I go to a bigger turbo, the 850's will have to come out and 1000 - 1300's are going to be needed.
Jason,
Where is this E85 that you plan on getting in Maine? I have never seen any around available.
Old 04-15-2013, 11:03 PM   #56
Overland04
Member#: 293311
2011 Impreza WRX
Leguna Seca Blue
Originally Posted by HeroCrank View Post
Jason,
There was talk that I heard on the local news that Maritime Farms was thinking of bringing it to Maine for on-road use. It seems they did bring it but its limited to government vehicles. I guess the plow trucks can run off it but I can't
I did find a spot that has real 93 octane, that's a plus!
Old 04-25-2013, 09:31 PM   #57
imprezarection
Member#: 240982
03 stg2wagon
red
I'm about to do some 650s on an 03 wrx are those brackets the same with the 2.0
imprezarection is offline   Reply With Quote
Old 06-15-2013, 07:49 PM   #58
SONIK1SUPRA
Member#: 118152
2007 wrx sti
black
this was a great write up just installed my ID 1000's on my 2007 sti but cant drive it yet without a tune! install was fairly straight forward except a couple of bolts.......passenger side was a breeze for me lol thanks once more!
SONIK1SUPRA is offline   Reply With Quote
Old 06-15-2013, 08:17 PM   #59
Overland04
Member#: 293311
2011 Impreza WRX
Leguna Seca Blue
Glad it work for you man, good luck with the new tune!
Happy modding
- Jason
Old 08-09-2013, 10:37 PM   #60
ocbuckeye
Member#: 269391
2011 STI
Here is the picture of the passenger side bracket; I'm showing this again now because it is helpful to see where the bolts are located before you start. It's a little different from the drives side so it may be tricky.
Hey all, I'm looking for the passenger side bracket and can't seem to find it in the catalog. If anyone knows it or has one laying around please hit me up. Im in a 2011 GR for bracket reference.
ocbuckeye is offline   Reply With Quote
Old 08-10-2013, 08:11 AM   #61
BigRob74
Member#: 305107
2012 wrx
360/386 E85
jason is e85 available up in the sticks?
Old 08-10-2013, 09:45 AM   #62
Overland04
Member#: 293311
2011 Impreza WRX
Leguna Seca Blue
Haha, never happened. There was one for government use for about a year and that is already gone
Stuck on 91 still, oh well.
Old 08-10-2013, 09:56 AM   #63
BigRob74
Member#: 305107
2012 wrx
360/386 E85
thats a bummer, getting an e85 tune was my best upgrade. you cant even get 93 up there?
Old 11-18-2013, 09:24 AM   #64
TGM2
Member#: 373923
Hello,
I'd thought I'd use my first post to congratulate you on this fantastic resource. This is what Internet forums are all about. Well done and many thanks!
I have just used this to change the injectors on my MY09 EDM Forester XT and one question I have, is to those of you that did not re-install the bracket on the drivers side. Where did you attach the ground that used to be attached to the bracket?
Cheers,
Scott
TGM2 is offline   Reply With Quote
Old 01-23-2014, 09:44 AM   #65
wgr73
Member#: 232458
2008 STi (OBP)
EFR 7670 (E85)
Great injector install!! Did E85 make it's way out for 2014?
Old 02-21-2014, 08:27 AM   #66
redwrx11
Member#: 278510
2011 WRX Hatchback
Red
When the injector is separated from the fuel rail, how much fuel should I expect to leak out?
redwrx11 is offline   Reply With Quote
Old 02-21-2014, 09:41 AM   #67
MADMIKE874
Member#: 280732
2011 STI hatch
Im pretty sure if you remove the fuel pump fuse and start the car until it stops you should not really have any fuel, I cant remember if I did that step or not but I dont recall very much fuel spilling out.
MADMIKE874 is offline   Reply With Quote
Old 02-21-2014, 10:33 AM   #68
redwrx11
Member#: 278510
2011 WRX Hatchback
Red
the battery has been out of the car for a month now. I assume the majority of the pressure has been released by now.
Old 02-25-2014, 12:43 PM   #69
redwrx11
Member#: 278510
2011 WRX Hatchback
Red
How do the injectors attached to the fuel rail?
Old 02-25-2014, 12:57 PM   #70
Overland04
Member#: 293311
2011 Impreza WRX
Leguna Seca Blue
They are lightly pressed into the rail through an o-ring, then sandwiched I between the rail and tgv housing.
Cheers!
- Jason
Old 02-25-2014, 10:23 PM   #71
redwrx11
Member#: 278510
2011 WRX Hatchback
Red
Thanks Jason.
One last question to finish the job. Does everyone reinstall the injector brackets? I understand this is a safety bracket for impacts, but my only other concern in keeping them off is the wire grounds on the drivers side. Any good place near by as a substitute ground?
Great Thread!
Old 02-26-2014, 06:37 AM   #72
Overland04
Member#: 293311
2011 Impreza WRX
Leguna Seca Blue
I always re-install the brackets. They are a pain to do but the are there for a reason so I'm not too big on suggesting alternative grounding methods.
If you decide to not install, make sure you properly extend the grounds to another clean grounding bolt with properly sized wires.
Old 02-26-2014, 07:52 AM   #73
bluemax189
Member#: 137405
20g
thanks for the writeup. I used it for my plugs and injectors this past weekend along with my new turbo install. I did find that cursing at the injector brackets helped so you might want to add that to the install directions.
bluemax189 is offline   Reply With Quote
Old 02-26-2014, 12:02 PM   #74
Asharus
Member#: 276300
2015 Ford Mustang GT
Oxford White
http://www.wrxforums.com/forums/11-s...stall-diy.html
This guy used a bolt on the intake manifold to reconnect the wire
Asharus is offline   Reply With Quote
Old 04-03-2014, 12:23 AM   #75
sebi1990
Member#: 362910
2013 Impreza WRX
NKG Iridium plug are same as stock
sebi1990 is offline   Reply With Quote
FS: DW 850cc Injectors, HyperFlow TMIC TurboWRX32 MAIC Private Classifieds 11 08-05-2009 05:03 PM
NJ:FS -Takata harness , STi TMIC , DW 850cc injectors ,Mines lip ,Defi gauges + MORE! DanTheMan23 Tri-State Area Private Classifieds 191 06-02-2009 02:23 PM
WTB:(MO) Spearco TMIC for 06 sti, DW 850cc injectors stidriver31 Private 'Wanted' Classifieds 1 04-18-2009 08:49 PM
VF43 turbo, STI TMIC, DW 850cc injectors Drac9 Engine/Power/Exhaust 26 04-12-2009 01:54 PM
TX: BRAND NEW ATP GT3076R, Perrin 3" inlet DW 850cc injectors ownnij Engine/Power/Exhaust 6 12-29-2008 01:55 AM
