Old 06-14-2013, 03:39 AM   #1
moneymike1988
Member#: 201338
2007 STI
Hello,
I have a 2007 STI, about to hit 60K miles. Just recently noticed little amounts of brown liquid at the top of my coolant and also my overflow tank is lined with blackish brown gunk.
Car is running good and still pulls strong. I changed radiatior to a Mishimoto about 4 months ago (drained coolant was clean and green) and had a compression test done 2 months ago (numbers came in at 120, 121, 124, 127). I have yet to do a leakdown test but from what I can see now, am I in trouble? Here are some pics. Any help is greatly appreciated, Thanks =\
And inside overflow tank.
moneymike1988 is offline   Reply With Quote
Old 06-15-2013, 02:00 PM   #2
cameronxt
Member#: 305971
2004 WRX STi
Wold Rally Blue
looks like carbon build up, so chances are you head gasket is letting gases into your coolant
cameronxt is offline   Reply With Quote
Old 06-16-2013, 04:04 PM   #3
SlimJim8804
Member#: 241943
2065 Magic Carpet
Swirl Rally Bleu
If this was the case, wouldn't that show up on a compression test?
SlimJim8804 is offline   Reply With Quote
Old 06-16-2013, 04:40 PM   #4
FCmaniac
Member#: 142029
2013 Forester
2008 350z, 1991 Miata BRG
Do you have any symptoms of a head gasket failure like overheating or filling up the overflow tank during WOT driving? What coolant did you put in when you swapped in the Mishi radiator? Did you put in Subaru coolant conditioner?
I'd do a hydrocarbon test on your coolant first. That should give you a good idea of what's going on.
FCmaniac is offline   Reply With Quote
Old 06-17-2013, 12:19 AM   #5
Andrewxxcarlson
Member#: 316415
2006 WRX
Ya, did ya use the conditioner? I just did my coolant 7500 miles ago with it and then my radiator just went out last weeks and there were specs and clumps of conditioner and it makes your overflow nasty.
Old 06-17-2013, 01:48 AM   #6
moneymike1988
Member#: 201338
2007 STI
Thanks for the feedback everyone. Had a leakdown test done by yimi. Cylinder 4 has 40% leakage and cylinder 2 has 20% leakage so that explains my oil consumption, glad i had that diagnosed because car was running perfect except the oil usage =[. Head gaskets turned out to be fine, my problem from my temp slightly rising and overflow tank filling and not taking back coolant was just bad caps not holding pressure.
