Old 06-12-2013, 01:40 PM   #26
sc00ter
Member#: 117767
2015 WRX
CWP
Look at rows 881-886 and 1460-1472. When you are WOT you are building boost all the way to 23.81psi which is WAY too high for the TD04. Especially on a stock/stage 1 map.
The good news is the only knock I'm seeing is under low load, which is fairly normal.
If I were you I'd get the car into a reputable tuner/shop ASAP. Let them take a deeper inspection and possibly fix up that tune.
sc00ter is offline   Reply With Quote
Old 06-12-2013, 01:56 PM   #27
BeardedShogun
Member#: 354456
Will do.
Thanks.
BeardedShogun is offline   Reply With Quote
Old 06-12-2013, 04:36 PM   #28
sc00ter
Member#: 117767
2015 WRX
CWP
On second thought, the first thing I'd do is go get a compression/leakdown test to make sure it's not a broken motor causing the issue. If that checks out then I'd go have a tuner dig in and re-tune.
Old 06-12-2013, 06:17 PM   #29
BeardedShogun
Member#: 354456
I've already scheduled one with a buddy of mine
Old 06-12-2013, 08:05 PM   #30
SpecBlitzed
Member#: 331188
Limp noddle mode
SpecBlitzed is offline   Reply With Quote
Old 06-14-2013, 05:12 PM   #31
BeardedShogun
Member#: 354456
Quick update.
Flashed back to stock and removed the Cobb sf, in hopes of having the car return to normal and try diagnosing the problem that way, so the car went back to stock.
Couple days driving normal like that not only am I still getting hesitation but also I start flashing a CEL, AP tells me its code; p0171 "system too lean"
even more frustrated.
Old 06-17-2013, 12:33 PM   #32
BeardedShogun
Member#: 354456
Originally Posted by SpecBlitzed View Post
Limp noddle mode
Old 06-17-2013, 01:01 PM   #33
ResidentR
Member#: 281656
2011 DGM WRX
5dr limited
I think something is up with your boost control. Looking at the logs you posted, you were seeing boost pressures significantly higher than they should have been, which can cause the p0171 since your ECU isn't tuned for it. I would make sure that all the vacuum lines for the wastegate and boost control solenoid are all intact and in place, and it might be helpful to get a boost gauge if you don't already have one.
If you don't see anything under the hood that looks suspicious to you, I'd definitely recommend taking it to someone else for a look.
ResidentR is offline   Reply With Quote
Old 06-17-2013, 01:06 PM   #34
dstroy
Member#: 283711
2012 STI sedan
Black with scratches
So, you googled p0171 and went down the checklist of things that cause that? Dirty maf, faulty o2 sensor etc. the Cobb sf uses an oiled filter, my bet is that you used too much oil or didnt ever clean/oil your air filter or maf. Try cleaning your maf with CRC maf cleaner, ONLY use a cleaner that is specifically for cleaning maf sensor.
EDIT: I missed the part where you already cleaned the maf but you still might have cooked it with oil.
Old 03-09-2015, 11:30 AM   #35
btrux0611
Member#: 319616
07 wrx
Did you ever find a solution?? I'm having similar problems with my 02 Wrx after buying it off a guy who said his son installed a new turbo and now it revs up extra slow and not past3800 rpm . also they did a auto to 5 speed swap and vehicle speed sensor wasn't wired up but now I have it wired up . any help?? I have gone over everything for months except checking for clogged up pipe maybe . no check engine light for a bit then to lean comes up .
btrux0611 is offline   Reply With Quote
Old 03-09-2015, 03:18 PM   #36
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr 427/427 JJtuned
O2 sensor.
