Old 06-17-2013, 01:29 PM   #1
sexyypants
Member#: 347122
Default +12 / crosstrek traction control disabled
Found a way to dusable all traction controls! Not taking any credit but a friend told me and has a write up and a video on it if any ones interested!!
sexyypants is offline   Reply With Quote
Old 06-17-2013, 01:41 PM   #2
soobie doo
Member#: 324017
2012 Impreza 2.0i
Ice Silver Metallic
I think that you can reasonably assume that some on this board would be interested.
soobie doo is offline   Reply With Quote
Old 06-17-2013, 01:43 PM   #3
sexyypants
Member#: 347122
Old 06-17-2013, 02:37 PM   #4
Xafen
Member#: 306398
2012 Impreza Premium
Camellia Red
Great, but does it also disable all the ABS and misc related things like with the impreza? In some tests/fuse pulls, it even disabled AWD.
See: http://forums.nasioc.com/forums/show....php?t=2319132
Xafen is offline   Reply With Quote
Old 06-17-2013, 02:49 PM   #5
Zeeper
Member#: 299286
2015 WRX CVT
Does it disable the AWD electronic clutch, meaning you lose AWD along with the traction control, abs, stability control and hill assist.
Some older Subarus had a fuse for the AWD clutch, that used to be pulled so the car could be towed?
Does the owners manual or fuse box cover indicate what that fuse is for, specifically?
here is another discussion about fuses and AWD:
http://forums.nasioc.com/forums/showthread.php?t=87310
Old 06-17-2013, 02:51 PM   #6
sexyypants
Member#: 347122
When I pulled a 7.5 fuse different one it did disable the awd but the one directly underneatg in the video showed it doesnt but than again I didnt take it out on a drive to actually test this one just did it replaced than shut off. Ill talk to my buddy that found this out he will know.more
Old 06-17-2013, 03:02 PM   #7
Subie_Noob_Brian
Member#: 288037
2015 LightingRed WRX
11' WRX sold**14' XV sold
Hi guys I made this video.
I tested it out on some clay dirt roads and it seemed like the awd was working but it wasn't slippery enough to get all 148hp to spin fast enough to tell 100%
Ill get the car on a lift and test it out here soon.
Subie_Noob_Brian is offline   Reply With Quote
Old 06-17-2013, 03:23 PM   #8
Subie_Noob_Brian
Member#: 288037
AWD works just fine. I tested the car no modification and all 4 wheels spin. Took out the fuse and with all the lights on all 4 wheels spin.
Go have fun guys!
Old 07-13-2013, 11:02 AM   #9
monkeyracer
Member#: 308583
2015 Forester XT
Crystal Black Silica
Shouldn't be too hard to rig up a switch that disconnects the fuse, so you wouldn't have to pull the fuse each time. If I ever get time to play with that, I might try that out.
monkeyracer is offline   Reply With Quote
Old 08-02-2013, 11:03 PM   #10
Subie_Noob_Brian
Member#: 288037
I have done this with an Inline fuse
