Old 06-16-2013, 04:05 PM   #10926
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Yeah, because I'm not fully compressing my suspension ever.
Old 06-16-2013, 04:57 PM   #10927
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Originally Posted by evanrussell View Post
Has anyone upgraded their steering wheel? I'm looking to possibly get audio controls in my 09's steering wheel
I have. It's plug and play for the OEM stereo but you will need an adapter and new harness for aftermarket.
Old 06-16-2013, 04:58 PM   #10928
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Lol. Tellin it like it is.
Maxed out crappy coilovers or a quality strut and spring setup.. No brainer for me!
Old 06-16-2013, 08:39 PM   #10929
IllwaukeeNA2.5
Member#: 330830
2010 Impreza2.5i 5dr
Obsidian Black Pearl
They aren't maxed out at all, they have plenty to go. I also have lowering springs that ride great but the ride height with them is disgusting looking to me
stock wheels obviously and springs on the top and the bottom pic is before moar low
IllwaukeeNA2.5 is offline   Reply With Quote
Old 06-17-2013, 07:09 AM   #10930
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Everyone has their own preferences. Being low is not everyones cup of tea. That being said, by lowering your vehicle significantly, will inevitably rub. Also, ride comfort will be affected. It just comes with the territory.
BSP671 is offline   Reply With Quote
Old 06-17-2013, 05:01 PM   #10931
Silver08Waggs
Member#: 283606
2008 Impreza 2.5i
Went to an autocross this weekend, here is a little video i made.
Silver08Waggs is offline   Reply With Quote
Old 06-17-2013, 06:10 PM   #10932
3043imprez
Member#: 306592
2008 Impreza 2.5i
Lightning Red
Nameless muffler-delete on the way, as well as Subaru OEM window visors and hood protector. Excited to finally start modifying my 08 LR 2.5i sedan...contemplating pursuing a set of 08 STI springs and struts I came across. Would this be worth it? My main Goal would just be to lessen wheel gap. Would this be noticeably lower than what we've got stock?
3043imprez is offline   Reply With Quote
Old 06-17-2013, 07:57 PM   #10933
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
The front struts won't fit unless you modify them. If you want a cheap upgrade get 09+ wrx springs/struts
Old 06-17-2013, 08:22 PM   #10934
s1eepR
Member#: 335330
2008 Impreza 5DR
No noticeable drop. And yes you need 09+ WRX only. Pair those with aftermarket springs and you'll get a nice, *FUNCTIONAL* drop. I'm on swift springs + 10WRX struts, about an inch drop all around. You will want a rear sway bar as well as our 08s didn't come with one. I'll be putting my WRX rear sway bar 16mm(with all needed hardware) up for sale once I get my white lines installed.
s1eepR is offline   Reply With Quote
Old 06-17-2013, 08:33 PM   #10935
3043imprez
Member#: 306592
2008 Impreza 2.5i
Lightning Red
Thanks for the insight, guys. Saved me from wasting some $$
Old 06-17-2013, 10:42 PM   #10936
evanrussell
Member#: 358520
I'm sure plenty of you have installed subs but have any of you replaced the OEM satellite speakers? I'm thinking about replacing them while I'm at it. Also considering a back seat sub rather than a trunk one
evanrussell is offline   Reply With Quote
Old 06-18-2013, 01:33 AM   #10937
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
Originally Posted by IllwaukeeNA2.5 View Post
But what size tires are you running? I have 225/45 so its a higher sidewall
225/45R17 is ALMOST the same diameter as 205/55R16 (stock).
The problem is your wheel's offset (+35)... way too low.
JourdanWithaU has 17x9 +45 (I believe)... the proper offset for Subaru.
Fendyman is offline   Reply With Quote
Old 06-18-2013, 01:38 AM   #10938
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
+1. STI's springs fit our car though & lower the front about 0.5" (even out the gaps between front & back).
Old 06-18-2013, 01:39 AM   #10939
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
What are they?
Old 06-18-2013, 03:08 AM   #10940
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
+35 can work. But you'd need an aggressive alignment. Somewhere in the range of -3* of camber in the front. Stock linkage should workout in the rear.
Old 06-18-2013, 06:24 AM   #10941
3043imprez
Member#: 306592
2008 Impreza 2.5i
Lightning Red
Yes, I've replaced the stock speakers with a pioneer component system up front and 2 ways in the rear. Modified the stock speaker to work as an adapter. Otherwise you have to buy the adapters online...
Old 06-18-2013, 10:39 AM   #10942
IllwaukeeNA2.5
Member#: 330830
I have -2 in the front and -3 in the rear, only problem is my turning radius in the front because of my tire hitting my fender liner
Old 06-18-2013, 12:25 PM   #10943
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Its all about trial and error man. Maybe you just need a bit more of a pull or play with the alignment. Or bag it haha
Old 06-18-2013, 01:09 PM   #10944
evanrussell
Member#: 358520
Gotcha. Worthwhile upgrade in your opinion?
Old 06-18-2013, 03:39 PM   #10945
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
You can even put a new head unit and it drastically improves the stock speakers lol
Old 06-18-2013, 04:47 PM   #10946
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
I wouldn't bother replacing HU without a speaker upgrade though.. Stock speakers are absolute garbage.. Just really really bad unless you have the "upgraded" stock speakers that are the two way silver looking things which I guess are pretty good from what people say.
Polk DB are a good cheap replacement, but I had them and upgraded to Alpine SPR-60 and the difference is pretty big in sound quality. For a coaxials they are pretty damn good. I have them amped with 150w RMS each up front though. I think they need an amp. If no amp, maybe the Polks would be better.
http://www.crutchfield.com/p_107DB65...io-db651s.html
BWX is offline   Reply With Quote
Old 06-18-2013, 05:14 PM   #10947
Silver08Waggs
Member#: 283606
2008 Impreza 2.5i
Any one here going to the azp track day event tomorrow?
Old 06-18-2013, 06:09 PM   #10948
evanrussell
Member#: 358520
Awesome, thanks for the info. I'll definitely look into this
Old 06-18-2013, 08:26 PM   #10949
3043imprez
Member#: 306592
2008 Impreza 2.5i
Lightning Red
Definitely worthwhile if you like your music. The component tweeters clear things up quite a bit, although I feel i might have lost a little midrange bass. Just add a 10" kicker in the trunk. That's what I did.
Old 06-18-2013, 09:41 PM   #10950
Sellars21
Member#: 304055
2008 2.5i Rallisport
UEL Headers Magnaflow CBE
Originally Posted by BSP671
The rear cambers naturally. So the lower you go, the more it gives negative camber and vice versa. You can adjust your camber through rear control arms.
I know about the natural camber. When I went in for an alignment I was told the rear could not be adjusted. I brought camber bolts with me just in case. When we got under the car the bolts didn't fit the knuckle. I said screw it and went with a little nevitive. This was over a year ago now.
But where on the controle arm can I adjust?
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 02:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
