Old 06-01-2013, 08:05 AM   #26
Guzzi 1
Member#: 338666
2014 Impreza Limited
SWP/Blk Leather CVT
Originally Posted by Louie View Post
Change out the head unit for a higher power one. The speakers aren't horrible. Maybe put some raammat in the doors
The speakers aren't horrible for what they are, but the magnet on the stockers are about the diameter of your thumb and maybe 3/4" long. Not much there to keep the cone in check. One of the Kicker speakers are heavier than all four of the originals by a significant amount. The stockers really are a weak link. For PNP, the Subaru upgrades are pretty decent. With adapters and a little more work, aftermarket is probably better and perhaps less expensive as well.
John
Old 06-18-2013, 04:02 PM   #27
BayAreaSubie
Member#: 342924
2013 Impreza Sp Lim
Satin white pearl
Originally Posted by Commander Keen View Post
+1. They're great, but they do take a bit of effort to install.
I rarely play the head unit louder than 28 (usually at 16-24), and that's with the rears shut off, EQ and loudness turned off, and bass at 0. The 6501s are comfortable at that power level, but the head unit doesn't have much left in reserve.
If you're listening at 30-32 with the default rollercoaster EQ, I'm surprised the speakers lasted as long as they did.
If you don't want to drill holes, chop off connectors or route wires, the Kicker pieces are it.
I just bought a pair of the Polk DB651 off Amazon. When you say "effort" what are you referring to? Is there soldering and drilling involved to install the speakers?
I plan on installing these sometime in the next few weeks with some sound deadening materials I purchased also. Thanks for any suggestions.
BayAreaSubie is offline   Reply With Quote
Old 06-18-2013, 04:14 PM   #28
Angelus911
Member#: 89967
2012 Impreza Sport
You'll need some speaker spacers: http://www.subaruaudio.net/subaru-speaker-spacers/
Old 06-18-2013, 05:54 PM   #29
Rememo
Member#: 340728
2013 Impreza 5-spd
I drilled when I installed mine. No big deal.
I used these connectors just in case I want to throw the stock speakers back in when I sell the car (yes they work perfectly in the Impreza):
Amazon.com: Metra 72-8104 Speaker Connector for Select Toyota Vehicles: ElectronicsAmazon.com: Metra 72-8104 Speaker Connector for Select Toyota Vehicles: Electronics
Rememo is offline   Reply With Quote
Old 06-18-2013, 07:18 PM   #30
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
I was referring to the db6501 component set.
Old 06-18-2013, 07:33 PM   #31
BayAreaSubie
Member#: 342924
2013 Impreza Sp Lim
Satin white pearl
No clearance issues with the window? I'm assuming I don't need the spacers that Angelus911 suggested.
Thanks again.
Old 06-18-2013, 09:14 PM   #32
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Thanks again.
Shouldn't
Old 06-19-2013, 09:11 AM   #33
Rememo
Member#: 340728
2013 Impreza 5-spd
Thanks again.
Can't hurt to use them if you don't want to drill, but you don't need them.
Originally Posted by flyboy1100 View Post
Shouldn't
What he said.... There's no clearance issues, I just made sure the speaker wires were out of the way.
Old 06-19-2013, 09:28 AM   #34
Angelus911
Member#: 89967
2012 Impreza Sport
Sorry about suggesting the speaker spacers, I thought I've read of others on here who have used them. I bought them anyways just to make installation easier (so I won't have to drill holes into the door). I think I paid $30 for them and the guy who makes them is a member on this forum, so for peace of mind and installation ease, it made sense to me.
Old 06-19-2013, 12:13 PM   #35
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I made my own spacers, but for mounting reasons rather than needing the extra depth.
Old 06-19-2013, 12:13 PM   #36
Rememo
Member#: 340728
2013 Impreza 5-spd
Nothing wrong with using spacers. This is the first car I've drilled, and it was only because I wanted to get it done NOW, rather than be patient and wait for spacers to arrive.
Old 06-24-2013, 12:17 AM   #37
Impreza 23
Member#: 360373
1996 Impreza
Hope you have no more issues from the speakers
Last edited by Impreza 23; 06-24-2013 at 12:21 AM. Reason: They were not talking about what I thought they were talking about
Impreza 23 is offline   Reply With Quote
Old 06-24-2013, 09:19 AM   #38
foghelmut
Member#: 328414
2012 Impreza SP 5MT
obsidian pearl black
I have tweeters up in the dash, but I don't know if that means I have the upgraded speakers or not. Are the stock speakers coaxial?
foghelmut is offline   Reply With Quote
Old 06-24-2013, 10:07 AM   #39
Angelus911
Member#: 89967
2012 Impreza Sport
Premium trims and above have the 6 speaker package (tweeters in the dash)
Old 06-24-2013, 11:57 AM   #40
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Unless you specifically ordered the kicker upgrade (I did for the tweeters only) they are just the factory installed ones
Old 06-24-2013, 02:48 PM   #41
foghelmut
Member#: 328414
2012 Impreza SP 5MT
So the 6 speaker package is not necessarily the upgraded speaker package?
Old 06-24-2013, 03:27 PM   #42
phenryiv1
Member#: 91212
2011 WRX 5DR
Thanks again.
They make the install much easier, ensure clearance at the window, and don't put the screws at a weird angle like the adapters that come with the Polks.
Old 06-24-2013, 04:56 PM   #43
Strutton
Member#: 329470
2011 Impreza wrx
SSM
Try turning your stereo off pressing an holding the 1&4 button. Double tap tune and it should say through mode. Made my speakers sound a lot better an not crack as hard under bass.
Strutton is offline   Reply With Quote
Old 06-24-2013, 08:32 PM   #44
phenryiv1
Member#: 91212
2011 WRX 5DR
No, not necessarily.
Old 06-24-2013, 08:51 PM   #45
Xafen
Member#: 306398
2012 Impreza Premium
Camellia Red
Btw http://www.subaruaudio.net/subaru-speaker-spacers/
It's $55 for front and rear speaker spacers with the awesome NASIOC discount =)
Just ordered mine! I know they're not 100% needed, but I didn't want to drill into the metal.
Xafen is offline   Reply With Quote
Old 06-27-2013, 02:57 PM   #46
ahnicemarmot
Member#: 355072
2013 Impreza 2.0i
Dark Grey Metallic
I ordered the spacers from him for front and rear as well as a dash tweeter adapter for aftermarket tweeters. I bought all new speakers and the adapters and it still cost much less than buying the speaker upgrade kit. (this was in a '13 btw)
ahnicemarmot is offline   Reply With Quote
Old 06-27-2013, 03:32 PM   #47
Angelus911
Member#: 89967
2012 Impreza Sport
^What's the tweeter adapter like? Is it needed for the Polk DB6501 component install?
Old 06-27-2013, 03:44 PM   #48
phenryiv1
Member#: 91212
2011 WRX 5DR
^What's the tweeter adapter like? Is it need for the Polk DB6501 component install?
I'll try to remember to post a picture tonight.
Old 07-01-2013, 07:49 AM   #49
BajaGuy68
Member#: 127720
2015 WRX
Lightning Red
Doing this made a difference in how my stock speakers sound. I can live with them a little longer till they are replaced with something better! Thanks!!
BajaGuy68 is offline   Reply With Quote
Old 07-01-2013, 01:02 PM   #50
phenryiv1
Member#: 91212
2011 WRX 5DR
They look like this:
Sorry for the delay.
