Old 06-18-2013, 01:07 AM   #1
sleepysubie
Member#: 81069
1998 ej257 gm6 ewg
A/R .60 Rotated
Default V8 ej207 into 05 sti
So I'm looking to put an version 8 sti motor in my 95 gc with an 05 sti swap. Has anyone done it? I'm assuming ill just install the dbw throttle body, crank sensor, cam sensors and turn off the tgv codes. Any thoughts?
sleepysubie is offline   Reply With Quote
Old 06-18-2013, 07:27 AM   #2
25rsti
Member#: 166324
I'm a little confused but if you're swapping an STi motor and not using the AVCS you leaving alot on the table.
Old 06-18-2013, 09:45 AM   #3
sleepysubie
Member#: 81069
1998 ej257 gm6 ewg
A/R .60 Rotated
I will be you but I'm looking to figure out what I need to do to swap over necessary sensors so I can just use the 05 Sti Ecu
Old 06-18-2013, 09:49 AM   #4
RealDealTarheel
Member#: 142447
06 Outback
IIRC the JDM cams won't work with USDM sensors, so you'll have to swap over the cams as well.
RealDealTarheel is offline   Reply With Quote
Old 06-18-2013, 10:57 AM   #5
sleepysubie
Member#: 81069
1998 ej257 gm6 ewg
A/R .60 Rotated
Nevermind.
Old 06-18-2013, 05:45 PM   #6
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Yeah, there's a lot more to it because the AVCS solenoids and sensors are different.
You need a v10+ engine, but then plug the exhaust AVCS holes. It's more similar to the STi wiring. It's still not as straightforward as a ver7 or ver8 into an 02-05 WRX.
Old 06-18-2013, 11:07 PM   #7
sleepysubie
Member#: 81069
1998 ej257 gm6 ewg
A/R .60 Rotated
So if I put in avcs solonoids and sensors from my 05 it should work right?
Old 06-18-2013, 11:09 PM   #8
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Why not just run the ej257? It makes a ton more torque and has better power potential.
Old 06-18-2013, 11:10 PM   #9
sleepysubie
Member#: 81069
1998 ej257 gm6 ewg
A/R .60 Rotated
Also ill be using my 05 sti engine harness.
Old 06-19-2013, 12:02 AM   #10
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
Its no big deal, swap over throttle body, cams, cam sensors and you are ready to rock. You do not need a V10 swap to make it work.
The 257 intake cams paired with the 207 exhaust cams is a great combo for spoolup and torque. I have tuned a few of these and they have great performance.
Old 06-19-2013, 12:29 AM   #11
sleepysubie
Member#: 81069
1998 ej257 gm6 ewg
A/R .60 Rotated
Thank you Luke. I've built many card and I know it's just a matter of the right combo. Pm me any info you have.
Old 06-19-2013, 12:32 AM   #12
sleepysubie
Member#: 81069
1998 ej257 gm6 ewg
A/R .60 Rotated
Also do I need to swap avcs solonoids?
Old 06-19-2013, 01:43 AM   #13
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
You want to use the JDM solenoids so you can run +40 of AVCS advance, the USDM ones will limit you to ~30 of advance
Look at Ken's build thread for a nice description of how to do the sensor and TB swap, bottom of page 17 is where it starts
http://forums.nasioc.com/forums/show...061849&page=17
Old 06-19-2013, 02:03 AM   #14
sleepysubie
Member#: 81069
1998 ej257 gm6 ewg
A/R .60 Rotated
Have I ever told you your my hero? You're the wind Beneath my wings? Hahahahahah
