Old 06-18-2013, 08:31 PM   #1
DannyLerch
Member#: 353235
Default 100k headgasket change on 02 wrx.
So I've owned a few pre owned subarus. My Wrx is my first turbo'd one. I'm at 92k miles and I'm thinking about doing a head gasket change now before it goes bad. My last two subies blew a gasket right past 100k miles. I waited til it was too late and it coat me a pretty penny. Though they were 2.5l motors. The cost to have the heads machined was expensive. My bill on my old outback was like 2400 bucks. That included timing belt, water pump, head gasket, new pistons, and a re machined head.
If I have the gasket upgraded to say a cosworth head gasket and I get it repaired early before the current one goes, what would the repair cost typically be? $1600 for gasket swap, timing belt, and water pump? Heads should t need re machined if the motor hasnt over heated correct?
I'm tempted to do it myself and I've been reading the stickies. I've recently swapped radiators and I'm super paranoid about blowing my head gasket. I know in the past, subies would blow a HG if the coolant system wasn't burped properly. I was very careful to do this when I swapped rads. Either way I'll be doing this very soon.
I'm just weighing my options. Do it myself or pay a professional? I'm relatively mechanically inclined and do all my own maintenance and mods. I've just never cracked open a top end before so it is a little daunting. Any thoughts?
DannyLerch is offline   Reply With Quote
Old 06-18-2013, 09:50 PM   #2
rdieder
Member#: 257818
2007 STi
Leave it alone unless you know you've overheated at one point or another.
rdieder is offline   Reply With Quote
Old 06-18-2013, 11:23 PM   #3
RScott2.5
Member#: 301010
2002 WRX Wagon
Red
^+1 to this and also the early 2.5l motors had alot of problems with headgaskets.
RScott2.5 is online now   Reply With Quote
Old 06-19-2013, 12:09 AM   #4
bwrex
Member#: 117805
2002 WRX wagon
The Ej205 has 3 layer steal gaskets you don't need to worry about them, the only reason why your headgaskets leaked on your outback is because they are crappy thin single layer gasket. Subaru's don't have head gasket problems this is a misconception. the early EJ251 motors have issues with them, and lots of people bought cars with this motor. This is when Subaru started to really take off as a company, and that's why people think they have problems with headgaskets. You would not be able to boost these motors if they used the same gaskets.
bwrex is offline   Reply With Quote
Old 06-19-2013, 12:24 AM   #5
DannyLerch
Member#: 353235
Thanks guys. That put my mind at ease. Now I can channel funds to other projects with the car. Thanks!
