Old 06-18-2013, 02:39 PM   #1
BlackWagonCampbell
Member#: 343453
Default My sad story
Last night I was driving and went through a bit of a pothole. As I entered where my wheel was getting air, my engine revved up, and then I heard a loud metal clunk...never a good sign. I am unable to stay in gear as I hear a noise ALMOST similar to a dying clutch, except I think it's the transmission. My engine is shaking a lot at idle, which now shakes the car. And I can't really get past 2nd gear til the issue becomes much worse. I need advice my NASIOC brethren, what is it? Is it my tranny? Can I just buy a used one? Is it possibly my rear differential? How do I check without going to a shop? Sorry if I should've posted in the noob section...
To make matters even worse...........brace yourselves.......I have to drive my parents Prius til I get it fixed
Thanks,
Chris
BlackWagonCampbell is offline   Reply With Quote
Old 06-18-2013, 02:44 PM   #2
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
Can't get past 2nd gear
Are you driving an Automatic? Or you mean that while shifting up the gears, it isn't that bad in 1st, gets a little worse in 2nd, and is god awful in 3rd and up?
Also, define "a bit of a pothole" Did you go in enough to damage an axle/knuckle, suspension part?
I'm a bit confused why your engine would have revved up with just one wheel in the air over the pothole. The other 3 wheels should not have allowed that.
Loyale93 is offline   Reply With Quote
Old 06-18-2013, 02:56 PM   #3
BlackWagonCampbell
Member#: 343453
Well, I punched in my clutch then let off it as I entered the hole. I guess you could call it an accidental "launch"? I'm sure it has to be my tranny or diff/:
Old 06-18-2013, 02:57 PM   #4
BlackWagonCampbell
Member#: 343453
Manual tranny btw
Old 06-18-2013, 04:24 PM   #5
fivestringslinger
Member#: 200455
2004 WRX Wagon, WRB
06 Triumph Speed Triple
That all sounds really unusual. I can't really imagine what type of transmission or differential damage would cause a shake at an idle. When you say it 'revved up', did you nail redline with it? Any CEL codes?
Maybe a broken motor or transmission mount? That would certainly cause a loud metallic clunk, some weird noises and vibration and make it difficult to shift. Just throwing that out there off the top of my head.
Can you maybe post a video of the noise you're hearing?
fivestringslinger is offline   Reply With Quote
Old 06-18-2013, 04:45 PM   #6
some dude
Member#: 100300
06 WRX
CGM
Do you have a good shop you take it to? Do you do all your own work? Obviously, something is wrong. You should limit the amount of driving and get it in to a shop to have it diagnosed.
some dude is offline   Reply With Quote
Old 06-18-2013, 04:50 PM   #7
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
Thanks,
Chris
You're getting way ahead of yourself here. The way I see it, you have two options.
1. Get the car on a lift and find out if anything is damaged. Suspension, transmission, etc. If you're not comfortable with doing this yourself or don't have the resources, go to option 2.
2. Get the car to a Subaru specialist and have that specialist examine the car. That will cost money. If you don't have money to have a specialist examine/repair the car, go to option 1.
Gallo2011 is offline   Reply With Quote
Old 06-18-2013, 06:45 PM   #8
Masta Splint
Member#: 189211
2005 18g WRX wagon
Def. bring it to a knowledgable shop and get it checked out because this does sound very weird and you dont wanna ruin something. Def dont drive it till its looked at and fixed.
Masta Splint is offline   Reply With Quote
Old 06-18-2013, 07:22 PM   #9
DannyLerch
Member#: 353235
World Rally Blue
Thanks,
Chris
Could be a motor mount, could be a tranny mount, could be a lot of things. If you can't put the car on jack stands to find out, tow her to a good subie tech. Diagnostics aren't expensive.
DannyLerch is offline   Reply With Quote
Old 06-18-2013, 11:45 PM   #10
d_r0ck
Member#: 259253
2011 Impreza WRX 4dr
This may sound silly, but is it possible it's just an alignment or wheel issue? If a big chunk of pothole got in the wheel it could cause it to go off balance and the car would shake very badly at 45-50mph.
d_r0ck is offline   Reply With Quote
Old 06-18-2013, 11:51 PM   #11
bobturismo
Member#: 42145
6-4 jockin da bish-
es and slappin the hoes.
At idle what happens when you push in the clutch?
Need more info, but it sounds like your clutch disc broke.
bobturismo is offline   Reply With Quote
Old 06-18-2013, 11:53 PM   #12
BlackWagonCampbell
Member#: 343453
I got just two CEL codes. They were P0102 and P0113
P0102- MAF or VAF A Circuit Low Imput
P0113- IAT Sensor 1 Circuit High Input
These two codes were also repeated with a "Pd" at the end, if that means anything. Yes my engine shakes a lot at idle and causes my car to. I could post a quick video of it, do you think that I should risk hurting it more for the sake of a video though? *not trying to be sarcastic
Keep the suggestions coming please. Hopefully it's just a mount.../:
Old 06-19-2013, 12:03 AM   #13
bobturismo
Member#: 42145
6-4 jockin da bish-
Sounds like you're intercooler dislodged, check all your intake hoses
Old 06-19-2013, 12:13 AM   #14
bobturismo
Member#: 42145
6-4 jockin da bish-
Make ssure your maf plug didn't come loose, you might have a bad maf.
Old 06-19-2013, 12:34 AM   #15
04IncreasedWRX
Member#: 325135
2004 Impreza WRX
Bad idle can mean something as small as an 02 sensor... and also a MAF sensor as bob pointed out. Where did you hear the cluck, right or left side?
04IncreasedWRX is offline   Reply With Quote
Old 06-19-2013, 03:49 PM   #16
BlackWagonCampbell
Member#: 343453
Would that explain the grinding metal sound? It seems like its my tranny. It also grinds a little as I'm in neutral.
Old 06-19-2013, 03:52 PM   #17
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
you
NEEEEED
a
MECHANIC
until then...we are just pissing in the wind here
Old 06-19-2013, 06:03 PM   #18
BlackWagonCampbell
Member#: 343453
Just changed my Diff fluid, and it seemed fine. I'm guessing its the tranny
Any idea on pricing of a new tranny?/:
Old 06-19-2013, 06:12 PM   #19
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
Stop. You have no idea what is wrong with your car.
Start listening to our advice and take it to someone who knows what they're doing. Those two CELs have abso****inglutely nothing to do with your transmission.
mechatricity is offline   Reply With Quote
Old 06-19-2013, 08:26 PM   #20
Uncle Scotty
OK buy Nates beans
the only thing SAD about any of this is that the OP is an idiot
Old 06-19-2013, 09:03 PM   #21
BlackWagonCampbell
Member#: 343453
Alright, guess ill have it towed down to a mechanic this weekend. Thanks guys.
Old 06-19-2013, 09:16 PM   #22
chrispy0
Member#: 318071
07 STi E85 Stage 2
ahhh bummer
chrispy0 is offline   Reply With Quote
Old 06-19-2013, 09:45 PM   #23
OneManArmy
Member#: 36154
2004 WRX Wagon
If it's thumping like that at idle...
my bet... motor is toast.
Keep us posted.
OneManArmy is offline   Reply With Quote
Old 06-19-2013, 09:52 PM   #24
dnorris89
Member#: 302666
2013 Wrx
If you legitimately hit a pot hole and it caused this much damage you can submit an insurance claim and just pay your deductible....
dnorris89 is offline   Reply With Quote
Old 06-20-2013, 02:43 PM   #25
bugeye829
Member#: 81995
2008 Impreza
02 WRX 247k RIP
worst thing you can do is ask random people on a Subaru forum to diagnose your car
bugeye829 is offline   Reply With Quote
