Old 06-13-2013, 10:50 PM   #2601
LoOped
Member#: 307678
2007 WRX
Obsidian Black Pearl
I'm Looking into getting some 18x8.75 +33.
As for tires im not into the stretched look so I was wondering if I should get a 235/40 or a 245/40
What would I have to do to my 2007 WRX Sedan TR to get them to fit?
I like functionality and i'm not looking to slam it. Maybe half an inch wheel gap. Seem reasonable? I need to know what kind of things I need to do to my fenders for these to fit.
LoOped is offline   Reply With Quote
Old 06-13-2013, 10:56 PM   #2602
the silver subie
Member#: 216662
05 STI
Originally Posted by dburgoon View Post
Will work. You need a good roll maybe a slight pull. A little camber as well. I was running these same specs but with a 245/40 on my bugeye
Thanks dude. How do you guys keep your fender liners from just sagging once the front is rolled? Would like to avoid doing the pull as I don't know how to do that also
the silver subie is offline   Reply With Quote
Old 06-13-2013, 10:57 PM   #2603
dburgoon
Member#: 310366
03 vf37'd WRB
Bugeye
I just take mine out and make a piece of sheet metal and weld it up there
dburgoon is offline   Reply With Quote
Old 06-13-2013, 10:58 PM   #2604
dburgoon
Member#: 310366
03 vf37'd WRB
Bugeye
How stiff is your suspension? I would run the 245/40 personally but you will have to do a roll on the fenders
Old 06-13-2013, 11:05 PM   #2605
LoOped
Member#: 307678
2007 WRX
I have BC BR Coils, i'm thinking -2 to -2.5 camber all around and a roll with 245/40? Does that sound about right?
Old 06-13-2013, 11:12 PM   #2606
dburgoon
Member#: 310366
03 vf37'd WRB
Bugeye
Sounds about right. I'm worried about when turning aggressively though, they might rub. What sway bars? I ran my 18x9 et20 w/ 245/40 at -2.5 but I also had 27mm sway bars on the tightest they would go
Old 06-13-2013, 11:20 PM   #2607
LoOped
Member#: 307678
2007 WRX
Stock, I can see a problem with +20, but you think ill have a problem with +33's?
Old 06-14-2013, 09:57 PM   #2608
wrxblackness
Member#: 309129
2010 Wrx
Epic springs/ koni yellows
Rota rt5 17x9 +42
235 or 45/40/17
Will this fit without fender mods?
wrxblackness is offline   Reply With Quote
Old 06-16-2013, 11:48 AM   #2609
actACCORDingly
Member#: 347086
18x9.5 +35 with a 235/40/18. stock struts with H&R sport springs. They rub in the rear. I pulled the 1/4 panels out at least an inch. How can i get more camber to fit these without rubbing with people in the back?
actACCORDingly is offline   Reply With Quote
Old 06-16-2013, 12:23 PM   #2610
themaus
Member#: 321211
RCE Black Springs
Koni Yellows in 2010 struts housing (supposed to make the drop a bit lower).
I want to run 18x9.5 with a 265/35/18. Open to ideas on what offset to run and if I am going to have problems with the front fenders? I know the rears will need to be rolled.
themaus is offline   Reply With Quote
Old 06-16-2013, 01:01 PM   #2611
sc00by4life
Member#: 97135
You haven't trimmed the rear bumper bracket I bet.
And at those sizing a and offsets you're gunna rub with people in the back. Period.
Old 06-17-2013, 04:57 AM   #2612
Ozo
Member#: 281992
2013 WRX
CBS
year: 2006
model: WRX Sedan
wheel model: OZ Ultraleggerra
wheel size/offset: 17x8 +48
tire brand/model: Bridgestone Potenza S-04 Pole Position
tire size: 235/45/R17 or 225/45R17
suspension: Stock (for now, see below) alignment: -1.2 camber F and R
fender
mods: None
spacers: No
From looking around Im pretty sure these should both fit at stock ride height. However, would I rub with a mild drop, maybe 1 to 1.25" on Mach V springs or something similar?
Thanks, just want to confirm before buying.
Ozo is offline   Reply With Quote
Old 06-17-2013, 07:51 AM   #2613
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
There shouldn't be any reason that those rub.
flat4LGT is offline   Reply With Quote
Old 06-18-2013, 12:06 AM   #2614
Ozo
Member#: 281992
2013 WRX
CBS
Old 06-18-2013, 11:00 AM   #2615
Iownit4
Member#: 358947
13 Wrx
Default what about 17x9 on stock suspension
If I buy 17x9 rota grids for my 2013 wrx with stock suspension what offset will I need and tires size to have a wider look with out modify the fenders, also with the fronts stick out more then the rears , I don't want that ..lol thanks rob nyc
Iownit4 is offline   Reply With Quote
Old 06-19-2013, 12:20 PM   #2616
subienoobie2029
Member#: 260706
2015 WRX Sedan
^I'm curious about that as well
subienoobie2029 is offline   Reply With Quote
Old 06-19-2013, 03:31 PM   #2617
blown ION
Member#: 301307
2011 WRX sedan
^^ i just put on 18x9 +38's with a 245/40, stock height(only sways/endlinks). i haven't rubbed yet but i've been driving like a skirt and i'm getting the rears rolled tomorrow out of precaution and so i can run a 255 in the future.
blown ION is online now   Reply With Quote
Old 06-19-2013, 05:55 PM   #2618
CollinGPhoto
Member#: 358968
2012 Subaru
Satin white pearl
Originally Posted by prescottn6ft7 View Post
This is what 18x9.5 et22 would fit like (thread also lists what modifications you would need for fitment): http://forums.nasioc.com/forums/show....php?t=2358565
18x8.5 with a 22mm offset would not fill up the wheel well nearly as much on your body style as it would on a GD chassis.
Was there any pulling to achieve this look? or just a roll
CollinGPhoto is offline   Reply With Quote
Old 06-19-2013, 11:00 PM   #2619
sc00by4life
Member#: 97135
HEAVY pulling and -4*+ of camber....
Old 06-22-2013, 09:16 PM   #2620
STi Wagon
Member#: 222151
2006 WRX STi
It's probably been asked before,
I just picked up a 2008 STi It's sitting on stock suspension at the moment, I'm eventually picking up Coils but for now I've been looking at wheels. XXR 522 18 x 9.5 +38 offset Am I going to have any fitment issues? With the offest or anything? Also, what tire do you guys reccomend for a 9.5" wheel with little to no stretch. Thanks in Advance.
STi Wagon is offline   Reply With Quote
Old 06-22-2013, 09:25 PM   #2621
dburgoon
Member#: 310366
03 vf37'd WRB
Bugeye
^ I'm not extremely knowledgable on that body style, but a buddy of mine had the same specs lowered quite a bit and he was running 235/40. We had to do a good roll but no pull, but for a meaty tire you will likely have to pull
Old 06-22-2013, 09:45 PM   #2622
ghoyos89
Member#: 316412
2002 wrx sti
i have 18x9.5 +40 offset varrstoen wheels, my car is on stock shocks and dropped on tein springs. i Know my fenders need to be rolled. I'm not sure whether to go with 225/40/R18 or 235/40/R18 I don't want to rub
Thinking of going with Falken tires as well
anything else I might need to do ?
ghoyos89 is offline   Reply With Quote
Old 06-22-2013, 09:53 PM   #2623
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Yes, mention your car.
Counterfit is online now   Reply With Quote
Old 06-22-2013, 10:08 PM   #2624
dburgoon
Member#: 310366
03 vf37'd WRB
Bugeye
This..as well as you can run a 255/35, not as stretched and your tires will last longer
Old 06-23-2013, 10:21 PM   #2625
ghoyos89
Member#: 316412
2002 wrx sti
sorry i have a 2002 bugeye
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 03:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 01:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 01:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 03:54 PM
