Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 06-19-2013, 02:40 AM   #1
TXblackSubie
Member#: 359437
Default can someone please tell me what this sound is
For some reason I'm only running 7lbs of boost so I was checking for leaks and I heard this. Someone please shed some light for me.
http://static.photobucket.com/player...ps505d147d.mp4
TXblackSubie is offline   Reply With Quote
Old 06-19-2013, 01:45 PM   #2
jthatch12
Member#: 321715
03 Big 16G WRX
Oh wow, that sounds like metal on metal scraping.... How does your oil look?
Old 06-19-2013, 06:40 PM   #3
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
ewww. belt tensioner? AC Compressor? Can you tell where it's coming from?
Old 06-19-2013, 07:09 PM   #4
TXblackSubie
Member#: 359437
Oil looks clean I will remove the cover tonight and look and the tensioner ect. That's where it sounds like its coming from.
Old 06-19-2013, 08:33 PM   #5
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
did you pull crank pulley to get a look at tensioner?
Old 06-19-2013, 11:55 PM   #6
Cupofnoodles
Member#: 352574
02 WRX
sounds like the tensioner bearings are bad.
Cupofnoodles is offline   Reply With Quote
Old 06-20-2013, 10:22 PM   #7
bsuby
Member#: 347520
02 wrx
midnight black
I had a real similar sound an ended up up a bad pulley bearing on the a/c tensioner
bsuby is offline   Reply With Quote
Old 06-21-2013, 09:23 AM   #8
Coopsubaru
Member#: 348662
2006 WRX
AW
^^^Agreed with Bsuby.
Coopsubaru is offline   Reply With Quote
Old 06-21-2013, 12:32 PM   #9
Goatcrapp
Member#: 64289
2004 wrx wagon
wrb
definitely pulley bearings.. can't tell which from the vid, but when you get that cover off, should be pretty apparent.
Goatcrapp is offline   Reply With Quote
