Old 06-19-2013, 05:30 PM   #2051
dylanisco0l
Member#: 347674
2013 wrx
blue pearl
Rota Gravel 18 x 8, 5 x 100, e+42 to +48
Rota Gravel 18 x 8.5, 5 x 100, e+48 to +52
what's the better performance size,and wheel size for pilot super sports
dylanisco0l is offline   Reply With Quote
Old 06-19-2013, 07:11 PM   #2052
dirtyjerseymotors
Member#: 358649
Just read through most of this thread and didn't find my answer.
Stock 2011 wrx, fifteen52 Tarmacs 18x8.5 w/+40 offset fits fine.
Thinking of going with a 235 40 18 but the stock sti wheels are 245 40 18. I see no issue unless someone else does?
dirtyjerseymotors is offline   Reply With Quote
Old 06-19-2013, 07:58 PM   #2053
J_Maher_WRX
Member#: 290307
Originally Posted by dylanisco0l View Post
Rota Gravel 18 x 8 5 x 100 e+42 to +48
Rota Gravel 18 x 8.5 5 x 100 e+48 to +52
You're going to run the same tire size regardless... The one with the lower offset will theoretically give a 'wider' stance and give more overall grip. Will you notice it? Nope.
J_Maher_WRX is offline   Reply With Quote
Old 06-19-2013, 09:15 PM   #2054
dylanisco0l
Member#: 347674
2013 wrx
blue pearl
really? the 18x8.5 and 18x8 would be the same tire size?
Old 06-19-2013, 10:35 PM   #2055
J_Maher_WRX
Member#: 290307
You certainly could. Lots of people run a 245 on an 8" wheel or a 235 on a 8.5" wheel no problems at all. Honestly what will make more of a difference would be the tire choice, but if you want the wider tire , it'll help you fit it slightly better with the 8.5" wheel.
Old 06-19-2013, 11:51 PM   #2056
MrImprezaWRX
Member#: 277139
2011 Impreza WRX
Satin Pearl White
Just wanted to see if you would need any fender work before I go install my new wheels setup:
Enkie NT03+M 18x9.4 +40 with a 255/40/18 tire. I am currently on swift spec R Springs.
I went with 40 because I kind of wanted more rubber protecting the wheels from potholes.
MrImprezaWRX is offline   Reply With Quote
Old 06-20-2013, 12:06 AM   #2057
J_Maher_WRX
Member#: 290307
Still too tall a tire IMO, a 35 would have been better. You're going to need to roll the rears..
Old 06-20-2013, 01:12 AM   #2058
MrImprezaWRX
Member#: 277139
2011 Impreza WRX
Satin Pearl White
Oh okay im going to try to see if i could change my tires to 35's then. Do you think ill still need to roll my fenders with the swift springs?
Old 06-20-2013, 12:10 PM   #2059
theEZV
Member#: 324205
2014 335i; 2016
Crosstrek; 2013 WRX(sold)
I have the 18x9.5 +40 Nt03s on my WRX. 265/35/18. You will need a roll in the rear for sure. A slight roll up front might also be a good idea.
I had a have all 4 corners rolled, but I am a bit lower that you are.
theEZV is offline   Reply With Quote
Old 06-20-2013, 12:59 PM   #2060
TarmacDaddy
Member#: 327056
2016 WRX Limited
Originally Posted by theEZV View Post
At that size an offset somewhere around 40 is the way to go. There's a pretty good chance you'll have to roll up front as well.
My setup is 18x9.5 +40, 265/35/18. Needed a roll front and rear.
If you had a +45 offset so you think you'd still need a roll up front?
TarmacDaddy is offline   Reply With Quote
Old 06-20-2013, 01:18 PM   #2061
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Its a good possibility u still might need to roll the rear fenders cuz don't forget the wider the tire, the taller the tire will be.
Old 06-20-2013, 02:10 PM   #2062
theEZV
Member#: 324205
2014 335i; 2016
With my setup, I could get enough camber (from the stock camber bolt) to avoid rolling, but the tire was rubbing against the spring perch. So we had to raise the car a bit and roll.
18x9.5 +40, 255/35/18 and lowered - you will have to roll the rears. Period.
Old 06-20-2013, 02:35 PM   #2063
YYC_ScoobNoob
Member#: 359817
Dark Grey Metallic
Anyone ever used TSW?
I am in love with these...
http://www.1010tires.com/Wheels/TSW/...+Stainless+Lip
They'll fit with out an issue afiak
YYC_ScoobNoob is offline   Reply With Quote
Old 06-20-2013, 02:38 PM   #2064
TarmacDaddy
Member#: 327056
2016 WRX Limited
Thanks for the reply
I have 18x9.5" +45 and 245/40 Michelin Pilot Super Sports. Cobb springs. No rubbing or rolling or pulling.
Thought of doing 265/35R18 with the same tire but only expected a slight roll for the rear. I seem to have enough room in the front on the inner strut area.
Old 06-20-2013, 02:39 PM   #2065
TarmacDaddy
Member#: 327056
2016 WRX Limited
Also what is your front camber? Mine is -1.5
Old 06-20-2013, 05:39 PM   #2066
dylanisco0l
Member#: 347674
2013 wrx
blue pearl
Rota G-Force 18x8.5 +48
Rota G-Force 18x9 +35
so they are out of rota gravels in gold in the USA now haha so between these 2 which will have better performance, +35 seems like a very aggressive fitment and since it's a 18x9 id probably run 265/35 vs 255/35 on the 18x8.5s
Old 06-20-2013, 06:32 PM   #2067
sc00by4life
Member#: 97135
With a 265 you'll definitely run into strut clearance issues.
Old 06-20-2013, 08:04 PM   #2068
WrxPower1
Member#: 314207
2012 Wrx
Red
I'm running a 265/35 Michelin super sport on a 18x9.5 et45 and have no strut rub or problems.
WrxPower1 is offline   Reply With Quote
Old 06-21-2013, 04:33 AM   #2069
sc00by4life
Member#: 97135
Height/alignment settings?
Old 06-21-2013, 11:02 AM   #2070
TarmacDaddy
Member#: 327056
2016 WRX Limited
That's I'd exactly what I was expecting to hear.
What suspension are you on though? Stock?
Old 06-21-2013, 11:09 AM   #2071
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg 2+ 310/370, 6sp R180
umm, height makes almost no difference to strut/tire/wheel clearance....
the only thing that will change that is how much camber is (or isnt) dialed in with the camber bolts.
less neg camber @ bolts = more clearance
more neg camber @ bolts = less clearance
Old 06-21-2013, 02:06 PM   #2072
WrxPower1
Member#: 314207
2012 Wrx
Red
Eibach springs. .8in drop all the way around. Front camber - 1.3 rear camber -1.6
Old 06-21-2013, 02:09 PM   #2073
WrxPower1
Member#: 314207
2012 Wrx
Red
I posted pics on page 82 of car and wheels. I'm on eibach springs
Old 06-21-2013, 07:17 PM   #2074
sc00by4life
Member#: 97135
Height effects camber.
Old 06-22-2013, 02:24 AM   #2075
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
It doesn't change the angle of the hub to the strut.think about it.
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L acetmi Private 'Wanted' Classifieds 0 06-14-2006 01:43 PM
need somewhere to get wheels and tires asap bubba03wrx Southern California Impreza Club Forum -- SCIC 22 04-02-2004 10:14 PM
Wider wheels and tires in the rear SilveRexy03 Tire & Wheel 14 11-04-2003 05:49 PM
WEre is a good place to buy wheels and tires MilfordSubaru Mid West Subaru Owners Club Forum -- MWSOC 4 05-25-2002 02:14 PM
Where to buy wheels and tires? wilddave1 Brakes, Steering & Suspension 4 03-21-2002 03:20 PM
