Old 06-19-2013, 10:54 PM   #1
BoostBandit
Member#: 351657
'03 Impreza WRX
Default Previous Owner's boost gauge install?
Hey guys,
Is this for a boost gauge? It was installed by the previous owner and there is no gauge, so I'm trying to figure this out. The cable is zip tied onto the other cables and goes in through the firewall towards the top.
I traced it inside but it goes up past the fuse box and then I lose it; there is a hole in the button next to the cruise control so I figure he had it going through there before. If so I'm guessing it was mounted on the pillar.
Reason I'm asking is because I hear the turbo spool and the BOV vents at higher rpm's, yet I don't feel the boost and the car is really weak. This is my first step t o diagnose the problem because I need to get a gauge on anyways to check how much boost I am getting.
Excuse my newbiness, If I missed something and more info is required just let me know.
BoostBandit is offline   Reply With Quote
Old 06-19-2013, 10:59 PM   #2
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Probably for a gauge. If you aren't going to use one right now, unplug it from the t-fitting, and cap off the fitting.
Old 06-19-2013, 11:18 PM   #3
BoostBandit
Member#: 351657
'03 Impreza WRX
Yep, that's the plan for now until I can get a gauge in there. Any idea where I can get a cap for it, Or what the term I can use to look for it would be? Thanks for your help.
Old 06-20-2013, 12:16 AM   #4
ToddMcF2002
Member#: 135007
2014 STi Hatch
Crystal Black Silica
Autozone. Put a cap right on the T and use a zip tie or clamp.
ToddMcF2002 is offline   Reply With Quote
Old 06-20-2013, 12:52 AM   #5
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
That would be after the pill if there is one. Not a good install. Remove the t and install a new hose.
Old 06-20-2013, 10:48 AM   #6
BoostBandit
Member#: 351657
'03 Impreza WRX
That leads me to my next question, how does the pill work and what does it look like? I know that you can't boost over 7 psi without it but that's all I've figured out on my own, can someone elaborate?
Old 06-20-2013, 06:00 PM   #7
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
The pill is like a tiny ball bearing with a precision drilled hole through it.
FYI, auto zone sells the caps, but I would replace the T with a straight through piece. (They sell those also) That way it's one less place for boost to leak.
Old 06-20-2013, 07:56 PM   #8
super_usdm
Member#: 286211
1993 Legacy SS
The pill is in the line between the compressor and the wastegate actuator. Its hard to see visually, if you squeze the line you can feel it.
super_usdm is offline   Reply With Quote
Old 06-20-2013, 08:36 PM   #9
hoffmanEstates
Member#: 122043
04 wagonier
psm
Maybe he had a manual boost controller
hoffmanEstates is offline   Reply With Quote
