Welcome to the North American Subaru Impreza Owners Club Monday March 30, 2015
Old 06-19-2013, 11:21 PM   #20426
doeboy23
Member#: 358362
Where can I buy the red and clear tail lights for my 2013 STi? Is it a DIY thing or do they other models have different lenses? I really don't like the full clears they put on the new cars.
Thanks everyone. Subaru virgin here.
doeboy23 is offline   Reply With Quote
Old 06-19-2013, 11:32 PM   #20427
SubieLuvin
Member#: 248202
2013 WRX Sedan
Some people DIY others use vinyl overlays. Blue batmobile makes some good ones I believe !
SubieLuvin is offline   Reply With Quote
Old 06-20-2013, 12:10 AM   #20428
doeboy23
Member#: 358362
Thanks a lot. I'll have my friend that does window tint do it for me.
Thanks again.
Old 06-20-2013, 12:29 AM   #20429
JSchell1309
Member#: 321321
'11 STI Hatchback
Dom 1.5XTR, E85
A little something I'm coming up with to replace the beat up steel delete on my car.
Going to cut from aluminum.
Currently painted steel.
Old 06-20-2013, 12:48 AM   #20430
Trustkevin13
Member#: 259184
2008 Subaru WRX
^^^ right! you can do that! I may have to hit you up soon!
Trustkevin13 is offline   Reply With Quote
Old 06-20-2013, 12:57 AM   #20431
JSchell1309
Member#: 321321
'11 STI Hatchback
Dom 1.5XTR, E85
You can PM me for any questions, but I am not looking to sell on here without a Vendor's license. I will leave it at that.
Old 06-20-2013, 02:50 AM   #20432
RCubed
Member#: 111328
2010 STi
RCubed is offline   Reply With Quote
Old 06-20-2013, 08:29 AM   #20433
Sleeperwagon1
Member#: 138901
2012 WRX sedan
ISM
^A little too busy for me, but all in all, very nice car!
Sleeperwagon1 is offline   Reply With Quote
Old 06-20-2013, 08:42 AM   #20434
CASHxMONEYxMIKE
Member#: 228719
2013 STi
So anyone else had or know how to adjust this issue without resetting anything? As i was driving to work, i made a left turn, didn't go over any bumbs/ glass/ obstructions, etc. I was in second gear at like 15mph and as soon as I came out of the turn my tire pressure sensor light came on. All 4's look fine, couldn't hear or see any leaks. Drove to work another 5 miles or so, checked them again and still fine. Just wondering if our model years have super sensitive or super sh***y sensors in them. Thanks guys
CASHxMONEYxMIKE is offline   Reply With Quote
Old 06-20-2013, 08:48 AM   #20435
Improbus
Member#: 278439
2011 WRX 4dr Stage2+
Mine are pretty sensitive. I believe removing the battery terminals is the only way to reset it without the tool but I could be wrong. Mine are typically really sensitive when the temperature outside changes drastically, like its 60 in the morning and then 95 in the afternoon. Usually my solution has always been to let some air out of them and fill them back to around 32-36 PSI and drive for about 15 minutes and it goes away. Check around the valve stem seals as well sometimes those like to leak.
Improbus is offline   Reply With Quote
Old 06-20-2013, 09:00 AM   #20436
CASHxMONEYxMIKE
Member#: 228719
2013 STi
I'll be sure to check that man thank you. I have to go to my dealership today anyways because I noticed I was missing a plastic clip in the liner and all of this is still under warranty which is good.
Old 06-20-2013, 09:47 AM   #20437
xluben
Member#: 261612
2002 WRX Sedan
10.9s @ 128mph
You should actually check the air pressure in your tires and add if necessary. On a local forum a guy was arguing that his sensors were broken. After a few pages of posts he actually checked the pressure and it was low. Filled them up and the light when away after a few minutes of driving. Just because a tire looks OK doesn't mean it has the proper amount of air in it.
Old 06-20-2013, 09:58 AM   #20438
Scnsaracer
Member#: 319511
2013 STI Sedan
Ice Silver Metallic
My tire light came on and one tire was just a bit low. Once I aired it up, it seemed to take a little while for the light to go off.
Scnsaracer is offline   Reply With Quote
Old 06-20-2013, 11:39 AM   #20439
CASHxMONEYxMIKE
Member#: 228719
2013 STi
Thanks Ben, and everyone else. I don't have a pressure gauge with me, but ill be having it checked out right away. Nothing serious for now, maybe one is just a tiny bit low.
Old 06-20-2013, 11:45 AM   #20440
xluben
Member#: 261612
2002 WRX Sedan
10.9s @ 128mph
It's funny how people assume there is an issue when the system is working exactly the way it should be.
Old 06-20-2013, 11:58 AM   #20441
jjablo6
Member#: 265697
2015 STi
Ligtening Red
dont see any radius or fillet call outs
jjablo6 is offline   Reply With Quote
Old 06-20-2013, 12:07 PM   #20442
jjablo6
Member#: 265697
2015 STi
Ligtening Red
my left turning signal started blinking really fast and the right one is still blinking at the same pace. someone mentioned that they blink quickly because one of the lights burned out. checked the lights and they both still work.. any ideas??
Old 06-20-2013, 12:10 PM   #20443
Celery GT-5
Member#: 98210
2015 WRX Premium 6MT
Mine did that when I first got it, try wiggling the wires around by the bulb
Celery GT-5 is offline   Reply With Quote
Old 06-20-2013, 12:11 PM   #20444
Improbus
Member#: 278439
Turn Signal Bulbs are Dual Filament. If one of the filaments comes loose the light will still work but will blink quickly. The dealer replaced mine under warranty. If not a new turn signal bulb and you'll be good to go.
Old 06-20-2013, 12:13 PM   #20445
JSchell1309
Member#: 321321
'11 STI Hatchback
Dom 1.5XTR, E85
Haha I'm not here to give out all my secrets
I just sent that generic print for quote so I can get a relative cost of material.
Old 06-20-2013, 12:16 PM   #20446
jjablo6
Member#: 265697
2015 STi
Ligtening Red
thanks will look into it
Old 06-20-2013, 01:30 PM   #20447
danns
Member#: 307197
2011 wrx
danns is offline   Reply With Quote
Old 06-20-2013, 01:31 PM   #20448
besthaticouldo
Member#: 279660
^^that looks really good. love the fitment.
besthaticouldo is online now   Reply With Quote
Old 06-20-2013, 02:35 PM   #20449
erik11876
Member#: 275888
2011 WRX Limited
I work in calibration, this is the story of my life Ben.
erik11876 is offline   Reply With Quote
Old 06-20-2013, 03:26 PM   #20450
NWsoobie
Member#: 289516
ISM
Damn Dan. This is clean. I want NT03's sooooooooooo f*****g bad.
NWsoobie is offline   Reply With Quote
('11-'14) 2011-2012 wrx/sti picture thread (for real this time) guamanian_powered Impreza Forum 151 04-29-2014 08:35 AM
01-07 wrx and sti drivetrain? xj bmx Newbies & FAQs 13 01-26-2012 03:30 PM
('11-'14) 2011 wrx/sti picture thread (for real this time) guamanian_powered Impreza Forum 1 11-16-2011 11:51 PM
Anyone have the 06-07 Impreza WRX and STI master part number and picture list STEALTH-WRX Interior & Exterior Modification 0 08-22-2008 02:12 PM
The Official World One STI and SEMA picture thread.. WorldOne Member's Car Gallery 25 11-29-2003 05:21 PM
