Old 06-19-2013, 09:42 PM   #1
The Phenx
Member#: 95823
2003 Imprezza Wrx
WRC BLUE
Default Oddball cooling ?
'03 wrx 260,000 miles... Prodrive St III and a buncha other junk
So upper radiator hose took a crap on me (got a pinhole), and I replaced it... no biggie took about 20 min. Topped off fluids.
But afterwords it was being a lil odd to my mind so I thought id ping you guys.
SO I let it idle for 10 min. Fan never came on, engine temp rose slowly to normal never went above normal.
Too it to the street did about 4 launches... came back home.
Let it sit. Fan still never came on. Temp never went above normal.
Hit ac.. both fans come on and run just fine.
Upper hose has lots of pressure in it... so I will assume the t-stat opened.
Nothing is wrong.. but.... thoughts?
The Phenx is offline   Reply With Quote
Old 06-20-2013, 06:44 AM   #2
hoffmanEstates
Member#: 122043
04 wagonier
psm
Purge system of any air, coolant level ever drop or news to be topped off at any point. If all good then you should be good also
hoffmanEstates is offline   Reply With Quote
Old 06-20-2013, 07:11 AM   #3
PSBeachBum
Member#: 279870
2005 WRX Wagon
I dont see anything wrong either. My fans rarely come on. Your car will let you know if its overcooling via CEL and undercooling via Temp Gauge.
I got the overcooling one i.e Car not reaching operating temp quick enough and discovered a piece of my drain valve stuck in thermostat (thankfully)
PSBeachBum is offline   Reply With Quote
Old 06-20-2013, 08:20 AM   #4
The Phenx
Member#: 95823
2003 Imprezza Wrx
WRC BLUE
Purged and topped off again last evening. Got a after market radiator so all I gotta do is take off both caps and fill.
Just figured that the fan would eventually come on.... But all is still well
Old 06-20-2013, 09:18 AM   #5
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Watching the fans to determine if the system isn't functioning right is the wrong way to go about it.
Old 06-20-2013, 10:17 AM   #6
The Phenx
Member#: 95823
2003 Imprezza Wrx
WRC BLUE
And the right way is? Least helpful moderator comment ever.
The system was fine except for the fans not cycling on while I was watching for 5 min. Thermostat opened, water pressure was fine, contact temp readings on the block, hoses and radiator were all in spec.
I was more curious if the system used two temp senders, one for the fan, one for the gauges... as I have seen this in several vehicles.
But drove 38 miles this am... temp was spot on, and other than some spillage burning off everything was spot on.
