Welcome to the North American Subaru Impreza Owners Club Sunday May 29, 2016
Old 06-21-2013, 11:13 AM   #1
teufel_4
Member#: 355745
2013 Impreza Sport
Venitian Red
Default 2.0 and 2.5
I have a 2013 Impreza Sport, and there are no aftermarket performance parts to be found. Is it possible to put parts i.e, intake, for a 2.5 onto a 2.0 engine if is for the same year.
For example, if I find a intake for a 2013 wrx 2.5l could I buy it and instal it onto a 2013 sport 2.0l?
teufel_4 is offline   Reply With Quote
Old 06-21-2013, 01:14 PM   #2
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
Many have said the intake for these cars is excellent. You will not be adding horsepower by swapping.
Best performance mod is to upgrade to the 19mm STi rsb. Check out the 2012-13 threads for some other ideas, but as far as engine performance theres not much.
Try for better tires, suspension, and visual mods. Its just not a performance car.
Old 06-21-2013, 02:21 PM   #3
cmiovino
Member#: 134005
2004 WRX Premium
A WRX intake of any year will not work what-so-ever.
I agree with the above... suspension, brakes. And no, you don't need to slam it to the ground or make it uncomfortable. Swaybars, brakes, maybe exhaust are a nice starting point for NA Subarus.
Also keep in mind, even if you were to add an intake, any engine related warranty claims would most likely be denied.
Old 06-21-2013, 06:38 PM   #4
teufel_4
Member#: 355745
2013 Impreza Sport
Venitian Red
Very true. Now with everything said how different are the body styles between a na impreza and wrx impreza of the same year?
Old 06-25-2013, 03:05 PM   #5
myrt1987
Member#: 323103
2012 Limited 2.0i
Very different. Wait for the redesigned 2014 wrx, its anyones guess as to how much will be interchangeable.
Old 06-27-2013, 12:44 PM   #6
cmiovino
Member#: 134005
2004 WRX Premium
Probably nothing intake related for the 2.0i. Turbos are always setup completely different than NA with intakes.
Old 07-03-2013, 08:59 PM   #7
teufel_4
Member#: 355745
2013 Impreza Sport
Venitian Red
So, a cf hood for a 13 wrx and 13 sport would not line up? Anyone local near Lebanon, Pa with a wrx cf hood wanna do a "test fit"? Ha ha
Old 07-05-2013, 07:32 AM   #8
Filthy_Mchaggis
Member#: 275489
2011 2.5i Premium
The body style of the NAs diverged completely from wrx after 2011. It would only fit if you had a 08-11 impreza.
Filthy_Mchaggis is offline   Reply With Quote
