Old 06-21-2013, 11:16 PM   #26
end_of_silence
Member#: 85565
2005 Saab 92x Aero
DSM
In my case, I had both codes but only disabled P0420. The other code cleared itself out after I removed the spacer and reset the ecu. YMMV
end_of_silence is offline   Reply With Quote
Old 06-22-2013, 12:04 AM   #27
PA-Outback2000
Member#: 161832
2000 Outback Limited
My bad. I just read the post and missed the username. Thought u meant for me not to use one.
PA-Outback2000 is offline   Reply With Quote
Old 06-22-2013, 03:16 AM   #28
05SubieRS
Member#: 359930
That seems like a good plan. What is the rest of your exhaust setup? I'm curious if this fix would work for me as well.
05SubieRS is offline   Reply With Quote
Old 06-22-2013, 12:40 PM   #29
kaotiklivin4eva
Member#: 299202
2002 Impreza
Blue/Black plastidip
kaotiklivin4eva is offline   Reply With Quote
Old 06-27-2013, 04:37 PM   #30
naCAnItihS
Member#: 259481
2002 WRX STI Wagon
MBP
Tsudo UEL Header
Tsudo HFC pipe (Both $330)
OBX Catback $300
naCAnItihS is offline   Reply With Quote
Old 06-28-2013, 08:12 PM   #31
end_of_silence
Member#: 85565
2005 Saab 92x Aero
DSM
Well, I had the stock headers, HFC and an Injen cat back with resonator/ muffler. I just put on some Borla rep headers and still no codes for the rear sensor, with the exception of an intermittent P0133 (front) that clears itself out after a trip. My car seems to be happy after the ecu reset so I am going to give it a couple of weeks to see if it learns how to run the new reps without throwing the P0133.
Old 07-01-2013, 01:10 PM   #32
RecoveringSaabaholic
Member#: 250265
2006 Impreza 2.5i
Correct! And I know that because in '05 for the RS, the ECU uses the rear sensor for more than just checking for a healthy cat, and using a spacer would mess up the fueling.
So... Given that... What is someone with an '05 to do?
I know that you are primarily looking at UEL, but for what its worth, my exhaust setup has never given me the p0420 code. Only once have i gotten the p2096 code, and that was after a 8 hour straight highway blast. Reset the ECU, and haven't seen it since. Have had the exhaust on the car almost a year now in weather ranging from 90+ days to subzero winters, and in all sorts of different driving conditions. I have CNT EL headers w/HFC and OBX 2.5" catback. Had to buy O2 extension for the rear sensor, and everything bolted right up. No fitment issues. The sound is not quite as nice as the UEL guys, but far from a honda rasp.
RecoveringSaabaholic is offline   Reply With Quote
Old 07-01-2013, 02:21 PM   #33
silverton
Member#: 331131
2001 2.5RS
STM
If the '01 legacy manifold is anything like the 01 impreza manifold, it's pretty damn close to being equal length. But it's a horrible design. The passenger side runners meet the driver side after a 90* bend, and then immediately have to make a 180* bend. That's why there is a slight "rumble" in the exhaust note when adding a higher flowing muffler.
Here is stock manifold and cat pipe with a 2.5" muffler shop special
and here is the same 2.5" cat back with a Borla replica and stock cat pipe
silverton is offline   Reply With Quote
