Welcome to the North American Subaru Impreza Owners Club Monday June 27, 2016
Old 06-20-2013, 11:14 PM   #1
storm-chaser
Member#: 354009
1998 Forester
Default HELP! Broken Cam Journal Bolt!!
Well title pretty much says it all. I had my torque wrench set to 7ft-lb per the manual for this cam journal bolt but it lightened up before I got it torqued, and I went a littler further and snap. The bolt sheered about 1/4" below the head surface. What do you guys think? I really don't want to take the head out again. ARG! Ez out? I just don't have a lot of room to work with...
storm-chaser is offline   Reply With Quote
Old 06-22-2013, 11:35 AM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
Carefully drill into it and try an EZ out. The force should be relieved from the threads, so it should back right out.
Good luck,
Jay
Old 06-22-2013, 11:22 PM   #3
storm-chaser
Member#: 354009
1998 Forester
Good luck,
Jay
Thank you. That's exactly what I did. I found a little drill, the Skill iXo was perfect for the job. It has a 90* adapter that gave me just enough room to work with. A normal right angle drill adapter would not have worked. So $40 bucks later and the broken bolt is out! Dealer didn't stock em though, so I have to wait until Tuesday before they get here. I'm at a standstill until then.
Old 06-23-2013, 09:39 AM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
Good deal. FWIW, use the appropriate torque wrench that reads in INCH-LBS for those 8 bolts. Get 8 by the way, because you have no doubt compromised the other 7. I remember years ago, a misprint in the FSM cost many folks some money by breaking these bolts. The caps closest to the cam pulleys have a lower torque value than the other caps. Go back and confirm it before tightening.
Personally, I don't torque these caps....I have done enough of them over the years to go by feel. I still torque the other cam cap bolts though.
Good luck!
Jay
Old 06-24-2013, 01:44 PM   #5
storm-chaser
Member#: 354009
1998 Forester
Good luck!
Jay
The 4 on the right side were only torqued down once, and that worked just fine. I had to swap some shims and buckets on the other side, and I think that's partially to blame for the bad bolts. Since I torqued them, removed them, and then installed them again.
Old 06-24-2013, 09:51 PM   #6
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
I had this happen on my wrx rebuild. Luckily the bolt broke with a little thread showing above the surface and I got it out no problem.
Stupid manual said to torque it the same as the other cam caps. I should have known that was false since the bolt is so much smaller.
geronimo81 is offline   Reply With Quote
