Old 06-23-2013, 04:39 PM   #1
fmars62
Member#: 290517
2008 Impreza 2.5i
Dark Grey Metallic
Default Options for 08 2.5i Header?
So idk how but my stock header has a crack in it and is leaking, pretty bad. For a new oem one is gonna be about $700, what can I do about that? I cant find any ebay headers, rallisport racing is a helluva wait. Do i got any other options?
Thanks.
fmars62 is offline   Reply With Quote
Old 06-23-2013, 09:38 PM   #2
gettle70
Member#: 312825
2011 Impreza 2.5i
blue
modify a wrx header there are threads of guys that have done it.
gettle70 is offline   Reply With Quote
Old 06-24-2013, 06:31 AM   #3
blk6s
Member#: 200057
2013 Impreza 2.0i
RalliSported RomRaided
There are two more options: simply have someone repair your factory header or look for a used one.
Used ones can be pretty hard to come by but I do have one I'd be willing to part with. I (RalliSport) can also fix your cracked one, if you can't find someone local.
Its quite a shame that so many have experienced cracked factory headers, but maybe I should be thanking Subaru for sending business my way
blk6s is offline   Reply With Quote
Old 06-24-2013, 08:05 AM   #4
PA-Outback2000
Member#: 161832
2000 Outback Limited
borlas will fit. i'd do a high-flow cat or test pipe also.
an aftermarket header needs to be mated with a high-flow car or track pipe of the earlier generation to fit nicely. you can modify the flanges and connections if you only do the header.
PA-Outback2000 is offline   Reply With Quote
Old 06-24-2013, 08:21 PM   #5
fmars62
Member#: 290517
2008 Impreza 2.5i
Dark Grey Metallic
I cant find borlas anywhere, tried lookin for them
now a quick question, if i get borlas (if i find them) with no cat, can i just put them on and have a tuner code out the cat cel?
Also i see uel headers but for older imprezas, will those fit or no?
Old 06-24-2013, 08:23 PM   #6
fmars62
Member#: 290517
2008 Impreza 2.5i
Dark Grey Metallic
And i really want your headers but i cant afford to wait, my leak is bad! Killing my mpg. I ordered them before but had to cancel due to i needed the money for family purposes
Old 06-24-2013, 10:33 PM   #7
alt14
Member#: 271928
2014 WRX Limited
Crystal Black Silica
I'm not sure but I think romraider can tune out the code, as for the headers, you would need borla pre 06 back and an older cat pipe section along with relocating the afr/o2 sensors, your best bet is to have Rallisport or some other company/shop fix yours now, Mike might be able to give you some sort of a discount to if you were to buy a set of his understanding that you needed something now.
Alternatively with so many people buying Rallisports headers I'm sure someone is willing to sell you theirs if Mike can't get them to you soon enough
alt14 is offline   Reply With Quote
Old 06-25-2013, 08:05 AM   #8
PA-Outback2000
Member#: 161832
borla.com... or are you looking for used ones? borla part# 17183 will fit your car. that part# fits across the board of most of the n/a subarus. the only thing is that the connection between the new header and stock cat will have to be modified. if you do a new cat (random technology, and the like), or a plain test pipe (like from stromung) with the header, it should all bolt together. you can probably just leave the code there as it is an efficiency code.
Old 06-26-2013, 08:04 PM   #9
SoarerJZ
Member#: 339635
mmmmm borla
SoarerJZ is offline   Reply With Quote
Old 07-03-2013, 04:32 PM   #10
fmars62
Member#: 290517
2008 Impreza 2.5i
Dark Grey Metallic
so, i get that borla header, and then the stromung intermediate pipe? is that what i am looking for?
will everything just bolt up?
also, i will throw a cel code because of the no cat, how do i get rid of it so i can pass inspection?
Old 07-03-2013, 05:05 PM   #11
Steve2.5i
Member#: 293006
2015 Subaru WRX
WR Blue
forums.nasioc.com/forums/showthread.php?t=1445402
Good source of info, not sure if you've looked it over.
