Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 05-19-2013, 11:52 AM   #1
oZ Killasubaru Zo
Member#: 279128
Rally blue
Default P0340 keeps coming back
Hey whats going on guys.
Heres my issue, I have an 02 WRX stage 2 set up(M2 TBE, Mugan Up pipe, Grimspeed Boost control, and a tune by Tach Motor Works. Im boosting 17psi out of a stock turbo.) Recently I spun a bearing in my motor so I sent out my motor to a machine shop and got it rebuilt. Replaced the the pistons and rods with Mahle forged Pistons and eagle forged rods. bored out the block if I am not mistaken The compression ratio is 8.2 to 1. After the motor was put back in and I started it up, I got the PO340 (Camshaft sensor A bank 1 or single sensor). So I did my research and found just replaced it. But I am still getting that code but it isn't consistent. Sometime it turns on the check engine light, sometime it just flashes or sometimes it doesn't even come on( I keep reseting the check engine light). I don't know if this affects my boost because my turbo has a hard time boosting. I was just thinking Would I have to get a retune? or is it something else? any advise would help guys thanks!!
oZ Killasubaru Zo is offline   Reply With Quote
Old 05-19-2013, 01:52 PM   #2
oZ Killasubaru Zo
Member#: 279128
Rally blue
bumpppp
Old 05-19-2013, 05:35 PM   #3
oZ Killasubaru Zo
Member#: 279128
Rally blue
Bumpppppppp
Old 05-20-2013, 07:13 AM   #4
quazimoto
Member#: 70395
There is no need for you to make 4 threads on the same subject. Stick to 1.
quazimoto is online now   Reply With Quote
Old 05-20-2013, 03:20 PM   #5
oZ Killasubaru Zo
Member#: 279128
Rally blue
Thumbs up
Oh im sorry. Next time I will do that. Just for you
Old 06-26-2013, 02:19 PM   #6
Doc Frankenstein
Member#: 358027
One of the cams is a tooth off, tear down the timing cover and check your timing marks
Doc Frankenstein is offline   Reply With Quote
