Notices
Old 05-31-2013, 07:31 AM   #1
josh_cooper
Member#: 334936
Default Problem with tactrix
I have the new version of the tactrix cable and usrd it a few times with no problems. Recently i went to use it and it seems like it couldnt read the ecu or something. The plug would light up like it was working but nothing would come up on ecu flash. Any one have an idea of what could be wrong?
josh_cooper is offline   Reply With Quote
Old 05-31-2013, 01:18 PM   #2
Undecisive
Member#: 218963
2004 STI
Did they update the definitions files for ECU Flash? Make sure you have the current definitions for your Model ECU
Undecisive is offline   Reply With Quote
Old 05-31-2013, 01:18 PM   #3
mikeyPSF
Member#: 236475
What does it say in the lower right corner of EcuFlash when you have the OpenPort plugged in to the laptop through the USB cable? Do you have another mini USB cable you can try? It's a standard mini USB cable just like the one you might have from a digital camera or GPS or similar device.
mikeyPSF is offline   Reply With Quote
Old 05-31-2013, 02:27 PM   #4
quazimoto
Member#: 70395
Could be a cable issue.
Old 05-31-2013, 03:23 PM   #5
josh_cooper
Member#: 334936
Ill check if they have new definitions and try a different usb thanks for the help
Old 06-01-2013, 11:05 AM   #6
Undecisive
Member#: 218963
2004 STI
Let us know what happens.
Old 06-20-2013, 03:00 PM   #7
JungleFevre
Member#: 260153
2005 Baja Turbo
5-Speed
Mine did the same thing last year, turns out the cable had one of those cheap swivel heads (not sure if this is the cable that came with it). I swapped cables and it works flawlessly.
JungleFevre is offline   Reply With Quote
Old 06-20-2013, 03:08 PM   #8
mikeyPSF
Member#: 236475
If it had a swivel head, it wasn't the USB cable that came with the OpenPort. The problem we have is that most of the USB cables are not all that great. If we could pay a bit more for nicer USB cable to include with the OpenPort, we would, but USB cables are a commodity and they're all sort of mediocre.
Old 06-26-2013, 04:24 PM   #9
josh_cooper
Member#: 334936
Sorry about the delay but it was actually my computer itself. I have the newer cable and it works great ssying that i got everything figured out, thanks for all the help
