Go Back   NASIOC > NASIOC Technical > Pre-2002 Factory Turbo Powertrain
Old 01-10-2013, 09:29 PM   #26
SteveTC
Member#: 118552
2010 JuSTI
Originally Posted by jrmsti View Post
i'd like to know how i can do this, do you have to use 2.5l sohc cam gear? cause i have the older metal timing gears from a ej20g if it can be modified
It took some creativity on my milling machine with a 2 step plug and an indexing pin, but i was able to get it to work using the metal 2.5 SOHC pulley. i did hae to remove the sheet metal ring to position the belt because DOHC belt is wider.
SteveTC is offline   Reply With Quote
Old 01-11-2013, 01:22 PM   #27
jrmsti
Member#: 103675
I see seems like not a easy task, the thing is its not so much that i want to run a usdm wrx ecu, my problem is i have the ej20r engine harness but i cant find a diagram or matching dash harness for it, that's why i was thinking if i run a wrx harnesses if would be easier for me to go standalone.
Anyway you think if I send you some pictures of my gear you'd be able to let me know if it can be done?
jrmsti is offline   Reply With Quote
Old 06-26-2013, 01:20 AM   #28
OregLegacy
Member#: 348956
Default Sorry..
Hate to bring back an old thread but unfortunately this one seemed to be the one that seemed to be most on topic so here goes. Im a new member to Nasioc here and joined due to a little project ive got going on currently, namely an EJ20R swap into a 1996 Legacy Brighton wagon. I picked the engine up VERY cheap a few days ago and the car came from out in BC, so it had next to no rust on it. now before i go about ripping the EJ22 thats in the car already i need a bit of help locating some parts: namely the black box of doom and i believe i read i also need a vacuum canister of some sort, neither of which came with the engine. beyond that i know ill need a higher powered fuel pump (looking at a Walbro 255, as it seems to be the go to pump for most of these applications) and i believe also a WRX front subframe/cross member. Is there anything im missing? and does anyone have some suggestions on where to look for those black boxes and vacuum canisters? any help would be much appreciated
OregLegacy is offline   Reply With Quote
Old 06-26-2013, 06:11 PM   #29
iamianoliver
Member#: 215839
2002 Impreza WRX
Sedona Red
The black box of death will be hard to locate, and i believe you need a modified wrx sub frame. For the driver side up pipe, and you then need to modify that to miss the steering linkage and brake booster.
Unless you convert to single turbo. Then everything usdm wrx bolts up on the exhaust side and no need for the black box of old vacuum tubes and valves.
iamianoliver is offline   Reply With Quote
EJ20R help needed, ECU pinout and vacuum lines. 72RSbug Pre-2002 Factory Turbo Powertrain 14 09-23-2009 10:51 AM
TurboXS bov info needed WRX Power Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-04-2001 02:50 PM
ATTN: Subapooh - White bulbs info needed! RallyGuy2k Texas Impreza Club Forum -- TXIC 2 11-03-2000 06:10 PM
Info Needed Re: Lowering a '95 Legacy LS AWD Sedan, Plz! :o) Fred C Legacy Forum 25 10-07-2000 12:51 AM
PSX2 info. needed joostin420 General Forum Archive 8 07-25-2000 11:49 AM
