Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 06-24-2013, 10:12 PM   #1
HOSTILEDUTY
Member#: 311218
2006 Impreza Wrx TR
Steel Gray Metallic
Default Data log help 2006 stage 2 wrx 1/4 run
Stage 2 run 1/4 mile I ran a 14.3. The last time I was at the track I was stage 1 and ran a 13.9. Pretty close to the same conditions as last time. It just seemed it was falling on its face out the hole but felt pretty good the rest of the run. Any help would be appreciated. Im just thinking boost leak somewhere but I don't know.
OK I fixed it for real this time lol
https://docs.google.com/spreadsheet/...kE&usp=sharing
HOSTILEDUTY is offline   Reply With Quote
Old 06-25-2013, 01:54 AM   #2
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Hopefully i posted the link right.If not let me know. Thanks!
https://mail.google.com/mail/u/0/?ui...f_hicfwlzn0&zw
Didn't post it right.
ProfessWRX is offline   Reply With Quote
Old 06-25-2013, 08:43 PM   #3
Bryan621
Member#: 360557
2006 WRX
Is your MAF clean? Launching same RPMs?
Bryan621 is offline   Reply With Quote
Old 06-26-2013, 12:25 AM   #4
HOSTILEDUTY
Member#: 311218
2006 Impreza Wrx TR
Steel Gray Metallic
Should work now. Thanks
Old 06-26-2013, 12:26 AM   #5
HOSTILEDUTY
Member#: 311218
2006 Impreza Wrx TR
Steel Gray Metallic
Yes and yes.
Old 06-26-2013, 06:42 PM   #6
HOSTILEDUTY
Member#: 311218
2006 Impreza Wrx TR
Steel Gray Metallic
Fix link now. Help please.
Old 06-27-2013, 05:50 PM   #7
HOSTILEDUTY
Member#: 311218
2006 Impreza Wrx TR
Steel Gray Metallic
The pass starts around block 848 on the datalog.
Old 06-27-2013, 06:50 PM   #8
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
It does look like you have a vacuum leak of some sort.
Old 06-27-2013, 07:45 PM   #9
HOSTILEDUTY
Member#: 311218
2006 Impreza Wrx TR
Steel Gray Metallic
Could that be caused by an aftermarket bov? Its the gfb hybrid one I had it on full recirculation like stock.
Old 06-27-2013, 10:18 PM   #10
nmlittlebigman
Member#: 321409
2003 Big Effing Van
Yep...
http://forums.nasioc.com/forums/show...67&postcount=7
Old 06-28-2013, 12:23 AM   #11
HOSTILEDUTY
Member#: 311218
2006 Impreza Wrx TR
Steel Gray Metallic
Ok thanks I'll put the stocker back on and do a pull this weekend and see if anything changes. Is it safe to drive it with a vacuum leak or could it mess something up?
Old 06-28-2013, 08:43 AM   #12
nmlittlebigman
Member#: 321409
2003 Big Effing Van
Reset ecu and do some normal driving for a few days. Avoid boost for now. You don't need to do a wot pull to see if was corrected. Pull up the stored values for A/F learning 1 A,B,C,D. They should all be +/- 5% across the board.
Old 06-28-2013, 11:13 AM   #13
HOSTILEDUTY
Member#: 311218
2006 Impreza Wrx TR
Steel Gray Metallic
Ok thanks I'll do that.
