Notices
Old 05-25-2013, 04:38 PM   #1801
IAG Performance
Member#: 158123
Originally Posted by scby rex View Post
How far back is the shift linkage repositioned?
Back about 8" and up about 4" from what I can remember. I'll double check on Monday if you like.
IAG Performance is offline   Reply With Quote
Old 05-25-2013, 04:50 PM   #1802
Scargod
Member#: 260314
2008 STI hatch
Couple of questions/comments:
Really clean, nicely thought out and well-executed work.
Why the NACA ducts under the engine? With the splitter and other aero work, I thought the object was to reduce pressure under the car. Aren't you spilling air out of these ducts when air should be coming out the top (hood area and perhaps top of fenders)?
Why no use of Dzus fasteners? I'm seeing what look like captive bolts.
Lastly, After all the fancy custom fab work that's been done why cheap-out on the steering wheel shaft support with stacked pieces of square tubing? Not adjustable? Will it be hidden?
Really, I'm very jealous. Hope mine is half as nice when I'm done.
Scargod is offline   Reply With Quote
Old 05-25-2013, 05:42 PM   #1803
Bansheeboy11
Member#: 182415
1999 RS
Is IAG gonna bring this to OCAWD meet again this year?
Bansheeboy11 is offline   Reply With Quote
Old 05-25-2013, 06:25 PM   #1804
Camelbacksubaru
Member#: 178924
602. 776.6400 Direct
Your home of Subaru Parts
SOLID update IAG!
That undertray is insane. Looking forward to seeing the sideskirts that will work with that! Any reason you guys didn't go with tunnels?
Anxiously awaiting more updates!
-Markos
Camelbacksubaru is offline   Reply With Quote
Old 05-25-2013, 08:59 PM   #1805
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
Originally Posted by IAG Performance View Post
What are you guys using on the bottom for heat mitigation?
cucamelsmd15 is offline   Reply With Quote
Old 05-25-2013, 09:46 PM   #1806
yaya20
Member#: 130354
2011 535i
Wow!!
yaya20 is offline   Reply With Quote
Old 05-26-2013, 09:37 PM   #1807
vicious_fishes
Member#: 158864
2003 SOHC destroker
with the amount TIC have been harassed about their flat-bottom i can't help but think if you were to make one that bolts up to the stock body/exhaust setup it would sell like hotcakes.
Old 05-26-2013, 10:26 PM   #1808
SubieEngineer
Member#: 208152
2007 STI LTD #576
UGM, FOR SALE!!!
That. Is awesome!
SubieEngineer is offline   Reply With Quote
Old 05-28-2013, 10:23 AM   #1809
boost junkie
Top Scoob 009
Member#: 68273
GD Race Car in progress
The naca ducts in the splitter are to allow air coming through the radiator to escape. Since it's mounted low and tilted downward, that air isn't going to want to travel up out of the hood. There are vents in the hood to allow engine bay pressure to escape but additional venting is needed down low. Dzus fasteners aren't strong enough for the aero pieces but they are being used for the bumpers. Steering column support gets the job done, and it'll be hidden behind the dash.
Originally Posted by Camelbacksubaru View Post
SOLID update IAG!
-Markos
Tunnels are much more complicated to design and get proper aero balance based on guesswork. Also more difficult to integrate into the car with clearance everywhere. Flat bottom made a lot more sense.
It's some sort of aluminized barrier.
Most people who would want a flat bottom are probably using nothing close to stock parts so an off the shelf piece doesn't make a lot of sense. There are a lot of other things you have to do to keep things cool if you want to do it so it will require a lot of custom work anyway.
boost junkie is offline   Reply With Quote
Old 05-28-2013, 10:34 AM   #1810
Abnormal
Lil Curious
Member#: 149626
2005 CGM FXT
Rocket Box! :D
SOLID update IAG!
-Markos
Oh heyyyy Markos
Abnormal is offline   Reply With Quote
Old 05-28-2013, 11:53 AM   #1811
leonbmx
Member#: 82864
2005 MPS Wagon HTA35
Domtuned Stage $$$$$
Loving the NACA ducts! I have been looking for that size and style for a while now, but I can never seem to find them without a hose attachment, unless I get the APR ones.
Where would one get these?
leonbmx is offline   Reply With Quote
Old 05-28-2013, 12:00 PM   #1812
boost junkie
Top Scoob 009
Member#: 68273
http://secure.chassisshop.com/partlist/6015/
They don't always have them in stock though, I had to wait several weeks for mine.
Old 05-28-2013, 12:10 PM   #1813
bettner12
Member#: 56179
05 LGT 407hp/372tq
Tuned by [email protected]
Also take a look at www.hrpworld.com
bettner12 is offline   Reply With Quote
Old 05-28-2013, 12:12 PM   #1814
Camelbacksubaru
Member#: 178924
Originally Posted by Abnormal View Post
Oh heyyyy Markos
oMghi2u Abnormal on This Tuesday morning.
-Markos
Old 06-02-2013, 12:48 AM   #1815
buddo_007
Member#: 269250
Hey I just clicked through the 73 pages of this impressive build.
Just thought I'd suggest something about your v-mount. Due to the angle of your intercooler and radiator the air will most probably have trouble going through the fins on both cores, the only reason I suggest you look at this, is processwest did the same setup on version 1 of their v-mount setup and had troubles with high temps, after thought they made the stepped radiator to bring temps right down with great result on their version 2 v-mount setup.
Just a thought before you throw it on the track and have to come back for more r&d because of temperature issues.
Good luck with the rest and hope its on the track soon.
buddo_007 is offline   Reply With Quote
Old 06-02-2013, 12:56 AM   #1816
mppricematt2011
Member#: 357932
2004 Wrx
Platinum Silver Metallic
Awesome build!!good luck!!
mppricematt2011 is offline   Reply With Quote
Old 06-03-2013, 09:37 AM   #1817
boost junkie
Top Scoob 009
Member#: 68273
Angled fins really aren't necessary, the key is using efficient cores and properly ducting air into them. For example, take a look at the radiator on a daytona prototype. It's mounted almost horizontal but uses straight fins and well designed entry/exit ducting.
Old 06-04-2013, 11:28 AM   #1818
mykrrrr
Member#: 733
'16 Fiesta ST
Platinum white metallic
Bah...what do they know.
mykrrrr is offline   Reply With Quote
Old 06-06-2013, 11:14 PM   #1819
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Starting to take shape! Looks awesome, can't wait to see it again, hopefully it will be done next time I'm down there
Old 06-09-2013, 08:50 PM   #1820
buznee
Member#: 358992
fantastic clean up for the bottom of the car!
buznee is offline   Reply With Quote
Old 06-11-2013, 02:26 PM   #1821
nickflow
Member#: 358934
i wonder how much has he spend so far.....mantastic work btw
nickflow is offline   Reply With Quote
Old 06-28-2013, 06:31 AM   #1822
obsidianwrex
Member#: 293374
2011 wrx
obsidian blaxk pearl
This is an amazing build! A lot of questions and concerns about my 2011 wrx build are being answered, and some more being made Haha. I have no doubt it wont end too short of this level of insanity. And I can't wait! I look forward to seeing this finished, its so beautiful... Brings a tear to my eye..
obsidianwrex is offline   Reply With Quote
Old 07-01-2013, 04:32 PM   #1823
decodeddiesel
Member#: 64102
Spent the whole morning reading the entire 73 page build. Outstanding read, probably the best GD racecar I have ever seen.
decodeddiesel is offline   Reply With Quote
Old 07-01-2013, 07:17 PM   #1824
mykrrrr
Member#: 733
'16 Fiesta ST
Change your page settings and it's only 37 pages.
Old 07-01-2013, 10:31 PM   #1825
decodeddiesel
Member#: 64102
You would have thought after 9 years here I would have figured that out lol.
Turn in Concepts 2010 Track Car Build Turn in Concepts Press Releases 372 03-21-2012 10:48 PM
My GC Race car build rrsettgast Member's Car Gallery 3 04-27-2010 12:19 PM
Came out to my car... belt on the ground and this (pic). Padge Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-11-2009 10:36 PM
Getting my car closer to the ground BluScopion Vancouver Impreza Club Forum -- VIC 12 02-02-2007 02:30 AM
got car back from the shop, now lights are messed up X2.5RS01X New England Impreza Club Forum -- NESIC 1 02-21-2005 09:41 PM
