Old 06-14-2013, 12:09 PM   #1
Subilover06
Member#: 344208
2006 Wrx limited
Steel grey
Default clutch issue
so here is the issue and I really need some help I have an 06 wrx limited I replaced the clutch about 10000 miles ago with an exedy stage 1 and yesterday when I was driving the car the pedal got soft usually the pedal is very stiff so it got soft and start repeatedly popping on my foot when I would push it in so today I started to bleed it and I got a lot of air and then nothing now I have no pressure in the pedal and I cant get air or fluid out of the line
Subilover06 is offline   Reply With Quote
Old 06-15-2013, 12:52 AM   #2
cameronxt
Member#: 305971
2004 WRX STi
Wold Rally Blue
Your master or slave cylinder or possibly your clutch line (the soft one) has a leak that is letting it suck in air and not let it build pressure. Once youve figured out which is your problem, i had to keep bleeding mine through several cyles after i was not getting anymore out of the hose before it started to build presure
cameronxt is offline   Reply With Quote
Old 06-15-2013, 10:26 PM   #3
DTJ01Dan
Member#: 359581
2008 Subaru WRX
Default Same issue
I have an 08 wrx and i have the same problem so i went to bleed the slave cylinder and the master cylinder and had some air in the lines. But my clutch is still very soft and when i drive and get up to about 3500 RPM it slips into neutral, Im guessing i have a bad master cylinder because i don't have any leaks.
DTJ01Dan is offline   Reply With Quote
Old 06-19-2013, 11:47 PM   #4
Subilover06
Member#: 344208
2006 Wrx limited
Steel grey
Bump!!!!!!
Old 06-19-2013, 11:48 PM   #5
Subilover06
Member#: 344208
2006 Wrx limited
Steel grey
So replaces the clutch master cylinder and slave cylinder and problem continues the car drives but when I press in the clutch it's very soft and the peddle pulses on my foot helpppppp plz!!!!!!!
Old 06-20-2013, 12:02 PM   #6
Subilover06
Member#: 344208
2006 Wrx limited
Steel grey
Afternoon bump
Old 06-20-2013, 12:02 PM   #7
Subilover06
Member#: 344208
2006 Wrx limited
Steel grey
Bump bump bump
Old 06-20-2013, 01:06 PM   #8
RoadKillDMD
Member#: 284792
2011 STI
Blurple
Bump!!!!!!
Afternoon bump
Bump bump bump
Follow the steps starting about halfway down post #2 through post #3.
http://forums.nasioc.com/forums/show....php?t=2419445
RoadKillDMD is offline   Reply With Quote
Old 06-27-2013, 11:13 PM   #9
Subilover06
Member#: 344208
2006 Wrx limited
Steel grey
I actually went ahead an pulled the transmission for the second time the clutch that I just put in the car was an exedy stage 1 racing clutch my recommendations is that they blow after 10000 miles the diaphragm on the pressure plate broke and four of the fingers were bent in causing the issue I was having so went and ordered a spec stage 2 plus clutch
Old 06-28-2013, 10:08 AM   #10
mneste8718
Member#: 51562
2004 WRX Sedan PSM
EJ205 [email protected] 300whp
SPEC Stage 2... is that the Kevlar disc? If so, good luck with the constant clutch chatter. It is awful. And if you ever launch the car once. The clutch will fuse itself with the flywheel at will, as if daily driving it wasn't difficult enough.
mneste8718 is offline   Reply With Quote
Old 06-28-2013, 06:29 PM   #11
ryansx
Member#: 324527
2013 wrx
white
Mine doesn't chatter nor has it fused to my flywheel. Now it's not on my wrx, but on my 240 that I autox(launch it there), clutch kicks, and just straight out abuse it, then drive home. Drove it daily for 3 years before wrx. Still no issues. Also if you haven't replaced rubber section on clutch line, you should consider what others said about replacing it
ryansx is offline   Reply With Quote
