Old 03-04-2013, 09:15 PM   #1
spokenlastchance
Member#: 310930
Default Exedy Organic Stage 1 non HD vs HD
So after looking around I think my car just needs a stage 1 clutch however there is even apparently a difference between the stage 1 clutch.
I'm honestly not sure what toque my car is running at. I'm running a v39 in a 2.0 and hitting about 21 PSI under max throttle although that was before the clutch started going. I bought it about 10k miles ago, and it was already starting to go when they tuned it they had to back it off because of clutch slip. They got it to around 269 whp. I don't honestly plan to do anymore engine modifications the E-85 in my area is horrid, I suppose I might get a G18, but that's way down the road.
The car is at 144k before any flaming on my use of the clutch I think it might be on it's second clutch although like I said not 100% sure.
http://www.aptuned.com/15802
Has a really good price on their non HD looks like it's holding about 278 vs the HD holding 319.
I suppose the HD goes for 70-80 more any advise would be greatly appreciated.
spokenlastchance is offline   Reply With Quote
Old 06-25-2013, 12:28 AM   #2
bacalhau75
Member#: 156053
2005 Impreza WRX STI
white
Hi,
did you ever find out what the difference is, other than higher torque rating?
I have a somewhat stock 05 STI, but i'm always beating on it... making videos for Youtube where I made my money on ads for this new clutch ... the non HD seems to handle the stock torque... but I would think something with higher torque would handle the abuse... let me know. thanks.
bacalhau75 is offline   Reply With Quote
Old 06-27-2013, 11:16 PM   #3
rocketperson7
Member#: 283968
MBP
stock will handle both of your cars just fine, and not ruin the OP's 5-speed
cheers
Old 06-28-2013, 08:12 PM   #4
bacalhau75
Member#: 156053
white
my stock clutch was fine until I got the COBB state 2 map. I dumped the clutch a few times... possibly 3 times where at the third time the clutch spun but the car didn't move right away... therefore previously I dumped the clutch a bunch of times on dry pavement on the stock setting and had no issues... but once I gave it more power, the clutch went dead... i'm afraid to put a stock one and it's only going to last a couple of months.
I rather upgrade the stock exedy OEM clutch to state 1 if I have the chance, but wondering the difference of the HD... is the pedal much harder to push? chattering? i'm leaving the fly wheel alone.
Old 07-03-2013, 09:30 AM   #5
spokenlastchance
Member#: 310930
If you're dumping the clutch you're going to wear it out either way.
Old 07-04-2013, 07:39 AM   #6
mhoerath
Member#: 131379
2003 354 [email protected] rpm
justablue hatch
ya all should read this
http://forums.nasioc.com/forums/show...775679&page=10
oem is designed to give a bit to limit shock loading the 5 spd.
