Old 12-24-2012, 02:15 PM   #76
bmxpunk
Member#: 89599
1995 almost 22B:)
red
I got the sparco because I found them for $20. Looks like I need to find some rubber
bmxpunk is offline   Reply With Quote
Old 01-02-2013, 11:02 AM   #77
anders8
Member#: 26658
1 Love Grassroots
NASA Rally Sport FTW!
Check local industrial rubber and gasket companies. There are places that need to make rubber gaskets for pipes that are six feet across, so obviously there's a lot of waste material.
Anders
anders8 is offline   Reply With Quote
Old 01-02-2013, 11:04 AM   #78
sureshot007
Member#: 142405
#716 G2 OBS
I've got conveyor belt on mine. It's embedded with PVC so it really stands up to getting pelted with rocks constantly.
sureshot007 is offline   Reply With Quote
Old 01-04-2013, 10:41 AM   #79
Bullet Bob
Member#: 336370
Where do you plan to compete?
Bullet Bob is offline   Reply With Quote
Old 01-04-2013, 06:41 PM   #80
bmxpunk
Member#: 89599
1995 almost 22B:)
red
Most of this year will be the Colorado Hill Clomb Association events. I hope to make a NASA rally or two but my first kid will be here in a couple of weeks so family will come first.
Is Idaho NASA sanctioned this year?
Next year, sno-drift is at the top of my list and I am going to work toward that starting now.
Old 02-03-2013, 08:04 PM   #81
bmxpunk
Member#: 89599
1995 almost 22B:)
red
New seat mounts move me back quite a bit, coupled with the steering wheel spacer make things a lot more comfortable.
Been learning my way through the ESL software. I had a friend who is proficient with romraider and he was impressed. How does this look for total timing(base plus advance)? This is the stock map by the way.
Old 02-04-2013, 09:00 AM   #82
sureshot007
Member#: 142405
#716 G2 OBS
Top axis is RPM and the side axis is...load? It's hard for me to see the picture.
Old 02-05-2013, 10:53 PM   #83
bmxpunk
Member#: 89599
1995 almost 22B:)
red
Edited. Now you can see, yes RPM across the top, load down the side.
Old 05-20-2013, 11:51 PM   #84
bmxpunk
Member#: 89599
1995 almost 22B:)
red
Quick teaser from the hill climb we did last weekend.
Found things about the car that I love and a few I want to change.
The Guard Transmission front diff worked flawlessly and kept the front end going where it was supposed to be.
The rear of the car is a little less stable than I would like. I know I need new tires but I think it was a combination of brakes, tires, rear suspension, and an open rear diff that had the back end doing who knows what.
I want a quicker steering rack. I know I need to get used to driving again but I felt my hands were swapping too much for the more powerful car, and besides this rack is leaking so why not upgrade.
My gearing is whack. Basically I am running wrx ratios with 4.11 FD. First is way to short and second and third (most likely fourth, and never used fifth) are too long. I was also the only car without a 6-speed and a diff controller of some sort.
I need a tune. I was down on power from the rest of the class. It wasn't a matter of my particular engine but I was on the smallest turbo running only 11-12psi and even then without a good tune I was giving up something in response.
I am trying to figure out what to do about sway bars. Before the event I added a 19mm front and i liked the feeling of the car more than without any bars. I am trying to find the compromise that won't be too much bar for gravel. Has anyone seen a smaller front bar than 19mm for the 05+ sti?
Any other suggestions welcomed.
Old 05-21-2013, 09:19 AM   #85
sureshot007
Member#: 142405
#716 G2 OBS
Power should be last on the list of things to address.
Open rear diff?!! Yeah, I'd take care of that first.
What's wrong with no sway bars on gravel?
Old 05-21-2013, 10:18 AM   #86
bmxpunk
Member#: 89599
1995 almost 22B:)
red
Power is very last on the list. Making sure the engine runs reliably is a main concern though. I was 2 sec out off 3rd and 4 seconds from 2nd and I know exactly where I lifted and could have made that time up. Those are the places that I wasn't confident in what the car was doing under me and that is what I want to rectify first.
Diffs I would like to square away. I have been looking for a center and a rear but its not easy finding anything for the center of the 5 speed still hanging about. It's also not easy to find the factory clutch type rear diff which I would prefer but may have to look elsewhere.
For me at least, I didn't like the feel of no sways, the car never felt consistent without them. I have been trying to get opinion on says or not for months and haven't found much. The rally anarchy guys seem to say no swaybars but the faster cars at the hill climb had them, I saw somewhere that Evan Cline runs swaybars on his car, of course the SRT usa run swabarss. I know none of that should justify but from a first hand perspective my car felt better after just installing the front alone.
Old 05-21-2013, 10:20 AM   #87
sureshot007
Member#: 142405
#716 G2 OBS
What are you running for springs?
And I'd think that a viscous rear from a wrx would be better than nothing.
Chris Atko on sways:
Old 05-21-2013, 10:37 AM   #88
bmxpunk
Member#: 89599
1995 almost 22B:)
red
Lazy is a good way to describe how the car felt. Thanks for that. From what he was saying and what I felt in the old car, I think some smaller bars would be best. I really liked the 17mm fxt bar from our old car. At least I liked how the car felt.
Springs are what jvab specs the the struts with, 250 front and 200 rear. I would almost like to try something softer just to see the difference.
I agree a vlsd would be better than nothing, and with 4:11 I just need to find one out of an older rs or forester.
Old 05-21-2013, 10:39 AM   #89
sureshot007
Member#: 142405
#716 G2 OBS
You really just need an R160 viscous diff. Pull a wrx diff and swap ring gears with the one you have. Done.
Old 06-28-2013, 11:54 PM   #90
bmxpunk
Member#: 89599
1995 almost 22B:)
red
Does anyone have a resource for information about restrictors and restricted engines? Books/articles anything. I have found little snippets here and there but I like information and I have books on everything else like suspension, brakes, engine building procedures, fitness, psychology, etc., but I can't find anything on restrictors and restricted engines.
Pay day tomorrow hoping after daycare, mortgage, I am hoping to knock out new steering rack and a cooler.
Old 07-01-2013, 09:04 AM   #91
sureshot007
Member#: 142405
#716 G2 OBS
Old 11-12-2013, 02:04 AM   #92
bmxpunk
Member#: 89599
1995 almost 22B:)
red
What are other rallyists running for brake pads? Small brake fire in august getting ready for an event ruined the rest of my year. So now I need to replace everything in the back. And what about rotors? Get something nice or go autozone since they probably need replaced all the time anyway?
Old 11-12-2013, 07:42 AM   #93
Aceyduce
Member#: 194449
2011 Mazda, 2003 WRX
Black , WRB
Dtc60s and autozone blanks. No point in spending money on rotors. In the back I run ht10s as there is no pad in 60 compound. Theyve been good at nefr and brs. I had issues ar ESPR but that was my own fault.
Aceyduce is offline   Reply With Quote
Old 11-12-2013, 08:48 AM   #94
sureshot007
Member#: 142405
#716 G2 OBS
I run Napa blanks and whatever track compound I can get my hands on for a decent price.
Old 11-12-2013, 12:51 PM   #95
rallynutdon
Member#: 24568
1993 Impreza, WRX
drive train, Open class
Stock Subaru rotors (which I get for cost) and Hawk HP+ pads
rallynutdon is offline   Reply With Quote
Old 05-01-2015, 12:51 AM   #96
bmxpunk
Member#: 89599
1995 almost 22B:)
red
Been a while since I have even touched the car. My bosses are getting a divorce thus my job is up in the air right now so my plans of rally Idaho are sidelined again this year. I figure I can at least do some no-cost upgrades to the car in the mean time. I started tearing out the radiator support I crushed 12 years ago, hope to finish it tomorrow. I am thinking of making separate radiator support and skid plate mount out of tubing and plating the frame rails. Was nice that things started to snap back once I started cutting bent parts out. I also got a new thicker skid plate last year that I can finally mount.
Is anyone cutting up the metal below the headlights? Would it be ok to place coolers in that area- Powersteering and/or oil? My thought is if they are against the frame rail and back just a bit they would be protected enough that If I were to hit something enough to take them out, I would be taking out the front suspension as well.
Also are their any suggestions for the wiring there at the front that runs along the radiator support?
Not exactly the before pic:
And After the support is cut out
Old 05-01-2015, 02:45 AM   #97
Natoe
Member#: 90353
Sold '95 22T Impreza
'99 EJ205 L, AE86 GVR4
Hey man, glad to see you're still at it! Props to you going the rally route. I just got back in the game, got a screamin deal for a 99 L with a clean 2002 ej205 swap. Having fun exploring the OBDII ease of tuning that we could only dream of 10 years ago. Yes, I think it has been nearly ten years since we realized we were both working on a 22T swap!
Natoe is offline   Reply With Quote
Old 05-01-2015, 08:11 AM   #98
sureshot007
Member#: 142405
#716 G2 OBS
When I'm planning on the placement of anything that has the potential to end my event if damaged, I always do what I can to protect it as much as possible. So, power steering isn't a deal breaker, but it sure does suck to lose it. However, loss of oil would be critical. I consider anything in front of the radiator to be disposable, because once you lose the radiator, you've got big problems. So, as long as you keep everything behind that point, you can stuff it a little and still drive away.
Build for reliability and survivability. Nothing sucks more than paying all of that money to run the event, and DNFing. I'd rather finish last than not at all.
Old 10-05-2015, 10:19 PM   #99
bmxpunk
Member#: 89599
1995 almost 22B:)
red
I am employed again! That means back to work on the car finally even though I won't get to use it much this coming year I hope to make 2 hill climbs in 2016 and I would be thrilled.
Finally received this bent up tube and now I am trying to decide how to use it, either as the radiator support or mount it further back just in front of the oil pan and use it strictly as a mount for the skid plate and use something else (spare 1.25" tubing I already have?).
I also tore out the pedal box in order to stiffen up its mount. The pedestal I made for it before was 16g plate that was bent up and I think my braking issues stemmed from the flex in that plate.
Old 10-05-2015, 10:46 PM   #100
Natoe
Member#: 90353
Good to hear you're still at it!
2007 Subaru WRX Wagon - all JL Audio build chithead Car Audio, Video & Security 8 04-06-2012 02:27 AM
My "taking forever" rallycar build ... Tbagger Member's Car Gallery 20 09-01-2009 09:23 PM
70's Rallycar FengShui Member's Car Gallery 8 04-06-2002 05:06 AM
Where to get rallycar sounds? RallyKid General Community 1 01-31-2002 11:47 AM
Rallycars book by Reinhard Klein stiggy-pug Motorsports 9 05-01-2001 04:15 PM
