Welcome to the North American Subaru Impreza Owners Club Monday May 4, 2015
Old 06-28-2013, 06:29 PM   #1
rap2cme2
Member#: 337905
2013 impreza2.0HB
ice silver metallic
Default oil drain plug air impacted on
2013 impreza 2.0 cant remove oil drain plug, impacted on by dealer I fell for a free synthetic oil change and now I must pay the price. never again, is it 17 mm 5 point socket or 16 mm should i use friends air wratchet afraid of stripping out thanks
rap2cme2 is offline   Reply With Quote
Old 06-28-2013, 06:31 PM   #2
thisisthenewsic
Member#: 156829
05 legacygt,00 OBS
red 95 supercharged nsx
I highly doubt the oil drain plug was impacted on.
Should be a 17mm. I usually use a long 17 wrench n hit my palm on the end til it comes loose if the bolt is tight.
Kinda acts like you are using an impact but can control it unlike an impact where you could cause damage.
thisisthenewsic is offline   Reply With Quote
Old 06-28-2013, 06:35 PM   #3
Ryan321
Member#: 225014
2005 Impreza WRX STI
I thought the same. Unless the dealer did an oil change already, it wouldn't surprise me it is the dealer.
Use a 6 point socket, usually an impact socket (most are 6 point) and a half inch ratchet it should come off. If not I'm sure you can touch it with heat as oil gets to 200+ temp, just touch it or run the car till hot and make sure the oil does not touch you. But that shouldn't be needed.
Ryan321 is offline   Reply With Quote
Old 06-28-2013, 06:38 PM   #4
ryansx
Member#: 324527
2013 wrx
white
Lube boys dont know their own strength a lot of times and just torque way to much. Could try putting box end of wrench on plug then getting a 18mm or so and put the box end of it on the 17mm open end to give more leverage.
ryansx is offline   Reply With Quote
Old 06-28-2013, 06:49 PM   #5
rap2cme2
Member#: 337905
2013 impreza2.0HB
ice silver metallic
thanks i will buy a longer 17mm for more leverage and give a try
Old 06-28-2013, 06:52 PM   #6
rap2cme2
Member#: 337905
2013 impreza2.0HB
ice silver metallic
thanks will give a try
Old 06-28-2013, 08:17 PM   #7
rap2cme2
Member#: 337905
2013 impreza2.0HB
ice silver metallic
im done tried everything now nut is rounded out cant be a 17mm its some weird size wont budge used 1/2 inch drive ratchet i will have to take in and they will blame on me now i will have to get new pan?
Old 06-28-2013, 10:09 PM   #8
RavensFan7
Member#: 346388
2001 Ej205 Impreza L
SRP
Hammer on a slightly smaller socket so it is literally stuck on. At this point the drain plug is sacrificed, and you will use the largest breaker bar or cheater bar you have (maybe both).
I'd go for the 4'-5' steel pipe on the end of your ratchet/breaker bar for maximum leverage. Buy a new drain plug ahead of time and done.
Edit: unless it's really rounded off....
RavensFan7 is online now   Reply With Quote
Old 06-29-2013, 12:21 AM   #9
ryansx
Member#: 324527
2013 wrx
white
It has to be 16mm or 17mm. Wrx I know are 17. Its not going to be standard. If it is beyond tight that a 1/2 impact(even cheap one) can't get it off your pan threads should be fubar.
Two options, 1st being easiest
1) got buy extractor sockets tap the size that fits on and get ratchet/breaker bar and be done.
2)Get a hammer and a chisel(if you have access to an air hammer with the right bit it will be easier) make a small cut into side of plug head(don't hit pan),so you have something to bite. Then angle chisel to where it will spin plug left to break loose.
Old 06-29-2013, 12:44 AM   #10
02redwagone
Member#: 87067
02 Old but tasty
SRP
And then fumoto valve it. One of the best mods I ever made.
02redwagone is offline   Reply With Quote
Old 06-29-2013, 01:01 AM   #11
lavid2002
Member#: 226864
2005 PSM WRX
18.5lb. 93 oct, DP, UP
Hammer on a smaller socket and use a breaker bar or the handle of a jack.
If this doesn't work find someone who can weld and weld something to it and back the bolt out and put a new one on it. No way it can be that stuck. If it was that tight they would just strip it out. Leverage is your friend.
lavid2002 is offline   Reply With Quote
Old 06-29-2013, 12:33 PM   #12
rap2cme2
Member#: 337905
2013 impreza2.0HB
ice silver metallic
thanks guys breaker bar worked !
Old 06-29-2013, 12:36 PM   #13
rap2cme2
Member#: 337905
2013 impreza2.0HB
ice silver metallic
will be getting one now, was afraid of it being caught and torn off, but never want to go through this %^&* again
Old 06-29-2013, 01:21 PM   #14
Supraru
Member#: 23313
99' 2.5Rs
black
The dealer did not put it on with an impact gun. Rookies. We have seen more then a few drain plus for no reason be very difficult to get out and have even used an air hammer to break loose. I've only seen one case where a new pan was needed. You're lucky you got it off. Bringing in a screwed up drain plug would have probably turned into something you had to pay for.
Supraru is offline   Reply With Quote
Old 06-29-2013, 05:23 PM   #15
rap2cme2
Member#: 337905
2013 impreza2.0HB
ice silver metallic
Thanks Your Exactly Right All I could think of the whole time A simple oil change turning into a huge bill. cant get over how frozen it was, dealer tech really gave it a good one didnt want a leak I guess, glad pan threads arent stripped should be good now
