Old 06-29-2013, 05:30 PM   #1
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
Default 2013 wrx dash air temp sensor
Already searched with no results. It's 106 degrees out and the temp gauge says 73 degrees. Drove around for about 20 minutes no change. Turned off the car then back on no change.....any ideas?
Subyroo2.5 is offline   Reply With Quote
Old 06-29-2013, 07:04 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Well I would first check for a faulty connection to the sensor which is usually up in front of the radiator. The sensor is near the bottom of the front end. The sensor itself could be bad also but I would more suspect a wiring problem between the sensor and the module.
Cougar4 is offline   Reply With Quote
Old 06-29-2013, 07:26 PM   #3
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
Solved.... Was after I washed my car....at least an hour after. By 3 or 4 hours later temp gauge working fine.
