Old 06-26-2013, 11:59 PM   #1
lavid2002
Member#: 226864
Default Oil clearances off... What are my options?
Rods seem OK. Crank bearings seem very small though with a lot of out of round measurements.
I have been very meticulous about zeroing my tools. I think my measurements are very accurate. I zeroed the dial bore gauge off the same micrometer that I used to measure the crank to minimize error.
I think my values are spot on. I search the threads for oil clearance threads. I found this
http://forums.nasioc.com/forums/show...=oil+clearance
These are almost the exact same bearings i have, except my bearings read
4b8296H-STD (No X after the H)
I don't think I have extra clearance bearings 0.o
I had my rods reconditioned, and I had my crank polished (It never spun a bearing, I just wanted it polished)
DD car with 300WHP goals.
10mm oil pump
Ideas?
I think I should be shooting for .002" on the mains and .0015" on the rods right???
Thanks guys
-Dave
lavid2002 is offline   Reply With Quote
Old 06-27-2013, 01:55 AM   #2
lavid2002
Member#: 226864
I think I need to split my block and re torque.
Old 06-27-2013, 12:55 PM   #3
lavid2002
Member#: 226864
Bump...
Old 06-27-2013, 01:06 PM   #4
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Maybe get some .001" extra clearance and swap some bearing halves around. Should be able to get close to what you want.
I would shoot for the opposite BTW, .002" rods and .0015" mains, but that is just me.
aboothman is offline   Reply With Quote
Old 06-27-2013, 01:18 PM   #5
JayMeagher
Member#: 187911
03 WRX
Redish
+1
That tight rod concerns me a bit. .0005 is a decent spread for the same size housing bore and bearing.
Thanks.
JayMeagher is offline   Reply With Quote
Old 06-27-2013, 03:16 PM   #6
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
So what number is the rod clearance and main clearance for 90* from centerline of the cases? You have them numbered but what number would be your centerline measurment? And why are you using averages on each journal? Since the bearings are eccentric your most important clearance is at the center of the bearing. You need to check the journal for out of roundness with no bearing shells in the journal.
fastblueufo is offline   Reply With Quote
Old 06-27-2013, 07:41 PM   #7
lavid2002
Member#: 226864
I was wondering why there was so much deviation in the bearing. I read some articles about eccentricity. This is great to hear because my measurements at 3 o clock to 9 o clock position were the ones that were the spot on measurements.
If my bare block measures out good, do I have to mic all around the bearing? I don't like dancing around on that bearing with the bore gauge more than I have to.
The numbers that read front 9 / rear 9 are the 3 o clock to 9 o clock measurement on the main bearings.
Old 06-28-2013, 01:58 AM   #8
lavid2002
Member#: 226864
Re-measured my rods now that I have a few hours behind the dial bore gauge. Here's what I got measuring only from the 12 o'clock positon (No averaging mess)
Also, re torqued the block and took my measurements again. I got more garbage. I pulled the block apart, pulled the bearings, and re-torqued it up again. Here's what I got.
See all the error in the thrust bearing? (Bearing 5)
I thought this was big enough of a deal to warrant a quick video.
I appreciate everyones help
-David Brandt
Old 06-28-2013, 08:35 AM   #9
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
I didnt notice the torque sequence or procedure you used to tighten the block halves together. Did you just do the 4 on one side and 6 on the other or did you also do all the case bolts going up and around? are we using a std X torque setting or doing it by one of the 4 manuals configurations. I would bet that this will have a lot to do with the actual numbers your getting. Just curious :-)
Bamofo is offline   Reply With Quote
Old 06-28-2013, 02:58 PM   #10
lavid2002
Member#: 226864
I thought I was torquing them properly. But now that I look at the manual, it's very different. Let me split it again and do it exactly like this
Also, I'm using all the bolts except the 10mm by the coolant o-ring.
Old 06-29-2013, 12:11 AM   #11
lavid2002
Member#: 226864
Alright, I torqued everything up using the correct torque procedure. Followed it to a T. I knew it made a difference... but now I know it makes a difference! A big one! Wow...
I also plasti gauged my rods and mains. Results are as follows. Looks like I am at a stand still here until I receive my ACL HX (+.001") bearings. I will have to half shell a lot of these since the clearances are so close to being right.
-Dave
Old 06-29-2013, 09:38 AM   #12
JayMeagher
Member#: 187911
03 WRX
Redish
-Dave
That looks pretty normal, the front and rear grow a bit with some heat.
You're not planning on splitting up the main bearings are you?
Old 06-29-2013, 02:00 PM   #13
lavid2002
Member#: 226864
Could you elaborate on how the front and rear grow with heat?
I just ordered some .001"+ bearings (same mfg, same style). Since these values are close, I planned on adding one shell of the +.001" to journals 1,4, and 5 to see where it gets me.
I thought I wanted 1.5 thou on the mains? .8 is close to half that...
Old 06-29-2013, 04:25 PM   #14
Serkan
Member#: 180514
2004 Sti
How do you get 0 clearance. Those charts you make doesn't make sense to me.
Serkan is offline   Reply With Quote
Old 06-29-2013, 05:56 PM   #15
JayMeagher
Member#: 187911
03 WRX
Redish
Because the block changes dimension as it heats up. I'll see 4-6 tenths before 120f.
I don't recommend swapping bearing halfs in the case. While I appreciate your approach I think your searching for a unicorn. The front and rear mains expand more than 2-4 do, Put the crank in the block and turn it, with the measured clearance you have if the crank turns well let it ride. In a perfect world your crank would have zero run out, depending on run out you may have to run more clearance even though there is some flex in it once it's riding on the oil.
Pay attention to how it turns and starts to turn with the rod journals in the 3 and 9 position VS how it feels at 6 and 12 o clock.
Old 06-29-2013, 09:18 PM   #16
lavid2002
Member#: 226864
It doesn't matter what the dial bore gauge is zeroed at. I zeroed the dial bore gauge and measured the rod journals with no bearings in them. That chart is simply to check for taper and round.
Why not? I read that it was alright if I used bearings from the same manufacture.
I'll torque the block back up tonight with some oil and see how the crank spins.
I appreciate the help and advice.
_Dave
Old 06-30-2013, 11:18 PM   #17
lavid2002
Member#: 226864
This makes me feel a bit better about my specs.
I am going to go see how the crank rotates.
-Dave
Old 07-10-2013, 09:18 AM   #18
JayMeagher
Member#: 187911
03 WRX
Redish
How did this work out?
Old 07-10-2013, 10:32 PM   #19
lavid2002
Member#: 226864
I have been out of town. I am coming back on the 12th and my +.001" bearings will be in. I will bolt the block halves up and plasti-gauge it when I get back. I don't think I want to swap bearing halves, but I may pick the best set of bearings for each journal from the +.001 or regular sized bearing sets.
-Dave
Old 07-16-2013, 10:24 PM   #20
lavid2002
Member#: 226864
Slapped my bearings in the block and followed the torque sequence to a T.
Here are my results.
Black = regular bearings
Blue = extra clearance bearings
Orange = My bearing selection from each set.
If I am shooting for .0015 I think these are the bearings I should use.
What do you guys think? I expected +.001" bearings to actually be .001" larger all around.
My factory manual says that main bearing clearance should be .0004~.0012 with a maximum of .0016
I know if I clearance the bearings too small I risk spinning a bearing, and if I clearance them too large I will get lower oil pressure, less oil at the rods, and the crank will effectively touch a smaller portion of the bearing since the curvature is larger.
Why does everyone on the forum shoot for larger clearances? Is this ideal for a performance build? I have seen some builds where they gap the mains and the rods at .002"
Input?
Thanks Everyone
-Dave
Old 07-17-2013, 05:00 PM   #21
lavid2002
Member#: 226864
Just plasti gauged the rods.
Rods 1,2,and 3 are all right on the money at 2 thousandths.
I plasti gauged rod 4 three times. First time, 1.7~1..8 thou, second and third times I got 1.5 thousandth of an inch.
I don't think 1.5 is anything to write home on. It isn't a little smaller than the 1.5 if anything it's right on it or just a bit smaller (Remember plasti gauge the clearance is larger if it's smaller. I don't want to confuse with my wording)
So I think the rods are good, and I read a few articles on the web about how subarus specs from the factory are conservative. I'd rather run my bearings at 1.5 ish mains and 2 thou rods than use the specs from my first set of bearings. .8 thousandths is tight...
Any input is appreciated. Thanks guys
-Dave
Old 07-20-2013, 01:09 AM   #22
lavid2002
Member#: 226864
Bump.
Old 07-23-2013, 10:45 AM   #23
lavid2002
Member#: 226864
Piston pins were a little snug in the rods, I sent them back to the shop and had them honed out a bit.
I built the block last night, it spins like butter all the way around. Very happy
Slugs go in today. Thanks for the help everyone!
-David
