Old 06-29-2013, 06:02 PM   #26
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Originally Posted by KzooBaja
I bought the $40 funnel.... Waited about an hour after driving,.... Pulled both caps,..... Topped off the radiator,... Capped it,... Topped off the turbo tank,... Put the funnel adapter, cap & funnel on,.... Filled funnel about 1/3 full,... Took out enough coolant from overflow bottle to leave it at full line........& Started Subaru!....
At first I got a lot of bubbles,..... Then one large bubble every 5 seconds or so,... After 2-3 minutes.... No more bubbles,.... I revved it a few times and held rpms around 3k for 2 minutes or so,..... Fans kicked on,.... No bubbles,.... Milked the upper hose a few times,.... No more bubbles!.....
Turned car off, and put another 1/3 coolant in the funnel,.... Waited for it to cool,... It took almost all of it as it cooled,...... Removed funnel,... Capped & test drove 5 minutes,..... Poped hood & overflow bottle,.... Was bubbling constantly in it!... Looked like a kid blowing bubbles in his green coolaid!...... :-(
Makes no since!.... Does not overheat or run hot untill it boils a lot of water from the coolant,.... A few days of driving!
Are you using premix or concentrate in the system? What are you topping it up with?
i_c_the_light is offline   Reply With Quote
Old 06-29-2013, 06:23 PM   #27
KzooBaja
Member#: 354285
2004 Baja Turbo
Well, I figured it out!..... Mind you, I'm 36 years old, been working in auto mechanics for almost 20 years.... Earlier in life out of nessisaty,... the last 10, as side money & I work my daily job as a welder.... I truly work on a lot of cars week to week, month to month.... I have to say,..... I'm embarrassed!..... I was so busy with all this other stuff that I didn't notice the lower radiator hose was cold!..... Upper,... Hot as hell!.....
I just checked the timing belt & alignments the other day, everything was brand new,... Water pump, timing components, belt and all was Subaru parts...... All this has 11k miles on it but was two years ago when it was done,... Thenit was sold to the guy I bought it from..... The guys boy put less than 11k on it in those two years!.....
It was not overheating, and with the new"er" parts..... I didn't even suspect the thermostat!...... I knew the pump was working and the thermostat is in the pump..... Who would have thought!
KzooBaja is offline   Reply With Quote
Old 06-29-2013, 06:24 PM   #28
KzooBaja
Member#: 354285
2004 Baja Turbo
Mixing green coolant and distilled water to 1:1 ratio......
Old 07-02-2013, 10:52 AM   #29
Nike_Soccer
Member#: 274801
2002 WRX EJ205
Mines at the dealer at the moment
Nike_Soccer is offline   Reply With Quote
Old 07-02-2013, 02:11 PM   #30
Masta Splint
Member#: 189211
2005 18g WRX wagon
Dude the "..." button is NOT a space!! Stop doing this. Read the sticky that says 7 1/2 rukles to posting because yopu are in violation big time!
Masta Splint is offline   Reply With Quote
