Old 07-01-2013, 10:42 AM   #1
sourdeeezz
Member#: 359602
2007 WRX STi
Urban Gray
Default Adjusting the headlights
I know that there is a dial to raise and lower the height of the headlights but one of them is significantly lower than the other is there a way I can easily manually raise and lower the height of the lamps?
sourdeeezz is offline   Reply With Quote
Old 07-01-2013, 01:10 PM   #2
tuzzio
Member#: 292532
05 STI
Not sure about the hawkeyes, but I know on my 05 STi I could if I chose to manually adjust them.
There is a dial on the back of your head light you probably have to turn with a screw driver. Make sure all your harnesses are plugged in, maybe one is unplugged and not adjusting with the controllwe
tuzzio is offline   Reply With Quote
Old 07-01-2013, 02:58 PM   #3
RileyD
Member#: 333679
2006 STi
Crystal Gray
I don't know about the 02-07, but I know for sure on the 08+ right behind the headlight there is a shiny bolt, the only shiny bolt there is back there and that adjusts the headlights.
RileyD is offline   Reply With Quote
Old 07-01-2013, 03:15 PM   #4
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
bechta your owners manual shows you where to put the phillips screw driver to adjust
AliBenn is offline   Reply With Quote
Old 07-01-2013, 03:26 PM   #5
Masta Splint
Member#: 189211
2005 18g WRX wagon
^^^^If your model allows you to do it you will find it in your owners manual like stated above.
Masta Splint is offline   Reply With Quote
Old 07-02-2013, 02:45 AM   #6
ChillinAussie
Member#: 288157
2004 WRX
There will be a bolt/screw that you can adjust. On the Peanut model there is a bolt at the back of the headlight right next to the low beam. Should be nearly the same for the hawk
ChillinAussie is offline   Reply With Quote
Old 07-02-2013, 08:10 AM   #7
beware doing this if you don't know what you are doing
you may adjust them so that they blind oncoming traffic
don't do that
Old 07-03-2013, 05:56 PM   #8
emazz104
Member#: 281811
04 WRX
Yeah, there is. It's the same setup, I have an 04 and used to have an 06.
Just look for DIY instructions online, I believe you're supposed to line up the imprinted dot into the headlight with the wall and back the car up 25 feet and match the top of the headlight beam with that.
emazz104 is offline   Reply With Quote
Old 07-10-2013, 12:03 PM   #9
sourdeeezz
Member#: 359602
2007 WRX STi
Urban Gray
Thanks everyone! I'll be checking this out tomorrow to try and adjust, and will let you know how it goes.
