Old 06-29-2013, 01:53 AM   #1
mattesonb
Member#: 139607
DGM Wrapped Satin Black
Default 11 wrx rattle near windshield is driving me nuts!
so there is a rattle directly in front of me at all speeds that is driving me insane!
its not the gauge cluster, a pillar, clock pod, or radio area. i'm thinking it is either the vin plate or something to do with the vents for the defroster.
has anyone had a similar issue?
any fix?
mattesonb is offline   Reply With Quote
Old 06-29-2013, 11:01 AM   #2
JSchell1309
Member#: 321321
2010 Ford SVT Raptor
Tuxedo Black
You don't think it is the A pillar, but it is. It has two tabs that mount the bottom to the dashboard in the corner of your windshield by the VIN plate. Here is a good thread on it. This one is for the passenger side but it's the same thing.
That rattle drive me nuts until I did this.
http://www.iwsti.com/forums/how-inst...x-must-do.html
Old 06-29-2013, 11:39 AM   #3
DC NYC
Member#: 360688
2013 WRX sedan
Plasma Blue Pearl
Thank you!!! This rattle was driving me off the edge too.
DC NYC is offline   Reply With Quote
Old 06-30-2013, 03:08 PM   #4
2subiesinyard
Member#: 139562
2015 Launch Edition
WRBoo
Just did my a pillars. I used denim instead of foam. I'll report back on the first cold day how it worked.
My project blog
http://www.mysubie.com/vehicle?id=857&project_id=2263
2subiesinyard is offline   Reply With Quote
Old 06-30-2013, 03:48 PM   #5
cream1316
Member#: 332279
2012 wrx hatch
dark grey metallic
yepp thats the rattle noise on both a pillars of my car..took the screw behind the airbag cover out and popped out the pillars and foam taped the tabs that clip into the dash...noise be gone forever... goodluck.. very easy
cream1316 is offline   Reply With Quote
Old 07-01-2013, 12:12 AM   #6
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
There are a number of noisy issues with the plastic fantastic dash mostly creak sounds. Start with a-pillars put foam, velvet or felt tape or something similar on the tabs and edge where it contacts the dash. Check the gauge hood, I put a thin layer of felt on the edge of mine, cleared the winter creaks. After that the dash to windshield edge can make noise, best you can do, without taking the dash apart, is slip some foam/felt in the edge between the surfaces. Stupid plastic dash creaks on every part it touches...
Power6 is offline   Reply With Quote
Old 07-01-2013, 06:14 PM   #7
2subiesinyard
Member#: 139562
2015 Launch Edition
WRBoo
Not a single click or pop this morning from the A pillar. Denim works just fine. This should be an easy fix for anyone who's ever cover a sub woofer box.
Old 07-07-2013, 07:53 PM   #8
everywherewego
Member#: 343525
Passenger seat zipper is the worst sound I have in my 2013
everywherewego is offline   Reply With Quote
Old 07-08-2013, 04:41 PM   #9
ixwrxxi
Member#: 334215
2015 Forester
I am trying this.
ixwrxxi is offline   Reply With Quote
Old 08-28-2013, 01:26 PM   #10
theMJF
Member#: 360426
2013 WRX Hatch
Oh I'm totally going to try this. I've been resorting to periodically squeezing the a-pillar to make it go away. Not ideal.
theMJF is offline   Reply With Quote
Old 09-02-2013, 06:29 PM   #11
dzywrx
Member#: 77610
2015 WRX-byebye 04
Sexy
did this yesterday totally worth the 20mins of my time!
I used a thicker rubber electrical tape (what I had handy) and seems to do the job.
dzywrx is offline   Reply With Quote
Old 10-09-2013, 12:10 PM   #12
fawcetteng
Member#: 340212
2004 WRX
i wasnt able to find the source of my "rattle" - more of a knocking sound - at the front of my dash windshield area. I removed the plastic a-pillar and dash piece at the front yet it persisted. Turned out one of the little hood "bumpers" on the support under the front of the hood, that adjust the height of the hood when it is closed, had turned itself down and wasnt touching the hood. this allowed the hood to shake more then normal and knock, the vibration of which was then transmitted up the hood to the hinge, giving me an annoying knocking sound at the front of the windshield/dash area. simple fix to screw the bumper up again!
fawcetteng is offline   Reply With Quote
Old 10-09-2013, 01:27 PM   #13
Augstar
Member#: 354389
2015 WRX Limited
Galaxy Blue
This! When I get some time Im going to wrap the zipper tab in tape or something.
Augstar is offline   Reply With Quote
Old 10-09-2013, 01:33 PM   #14
mattesonb
Member#: 139607
I installed raammat on the a pillar tabs months ago to no avail this rattle is coming from directly in front somewhere far enough down near the windshield that i cant seem to fix it.
next week i am going to drive around with my a pillar out and the gauge bezel removed to see if either of them are doing it
Old 10-09-2013, 03:19 PM   #15
GSXpress
Member#: 95825
2011 WRX Hatch
it might be the plastic cowl under the wipers on the outside.
GSXpress is offline   Reply With Quote
Old 10-09-2013, 11:39 PM   #16
mattesonb
Member#: 139607
that is also a possibility, once i have everything apart i am going to see if i keep hearing it
Old 10-10-2013, 02:33 AM   #17
cp2503
Member#: 292566
2011 WRX ltd GV WRB
anyone knows anything about a small rattling noise from left pass door inner panel?
cp2503 is offline   Reply With Quote
Old 10-11-2013, 03:06 PM   #18
bruuster
Member#: 310131
2013 Impreza Limited
Satin White Hatchback
Default A pillar removal 2013 impreza 2.0
I have the rattle but the articles below show an A pillar with the SRS screw hole.
The 2012-13 does not have an airbag in the pillar. How do I remove it?
Do you know where the tabs are located?
Thanks.
bruuster is offline   Reply With Quote
Old 12-04-2013, 10:35 PM   #19
WTSUPDC
Member#: 362218
2013 WRX
PBP
That cracking noise was driving me crazy. Thanks for this!
WTSUPDC is offline   Reply With Quote
Old 12-05-2013, 01:54 AM   #20
bruuster
Member#: 310131
Default A pillar not making the noise
I took off the A pillar cover 3 times and packed it with foam tape etc. But still heard rattling. So I now have the plastic cover off completely and still hear a noise. However, it seems to be coming from the over head light and switch assembly near the windshield. I'm trying to determine exactly where it's coming from as I drive over a bump in the road.
Is there something behind there I can pad? I can't make the noise by just hitting it with my hand. Only when going over a bump or pothole.
Old 12-05-2013, 04:26 AM   #21
snacku
Member#: 292569
2011 wrx premium
satin white pearl
maybe this? http://forums.nasioc.com/forums/show...php?p=39504289
snacku is offline   Reply With Quote
Old 12-06-2013, 08:37 PM   #22
bruuster
Member#: 310131
Default Pillar noise hopefully fixed
Thanks for all your suggestions and Links.
I did remove the roof light assembly at the windshield and stuffed some foam behind the header. However the noise was still present. My daughter, while riding in the passenger seat, said the noise was still coming from the A Pillar area. Apparently the sound moved up the glass and seemed like it was coming from the light. At this time the speaker grill was removed. I found that the bolt that holds the speaker assembly was tight but the plastic could still move behind it and was hitting the windshield on bumps. I removed the bolt and added an additional washer. This kept the assembly tight. I'll test for a day or so before replacing the A pillar cover.
