Welcome to the North American Subaru Impreza Owners Club Monday December 5, 2016
Old 06-23-2013, 05:54 PM   #1
amnvince88
Member#: 289978
2006 Sti
Default 06 sti carbon hood...install questions
I purchased as CF hood from Carbon Creations. And it didn't come with any instructions or holes drilled. My dumb a$$ didn't take any pictures of the OEM hood before I took everything off.
So, I'm trying to find out how to install the scoop, splitter, washer nozzles and weather stripping. Could anyone that is running a CF hood take some pictures of everything under there, especially the splitter and scoop. Also, If you have any tips on the install it would be much appreciated. Thanks!
*edit*
Any is anyone having trouble running hood dampers with these? I took them off because the drivers side was sitting high.
amnvince88 is offline   Reply With Quote
Old 06-23-2013, 06:27 PM   #2
Jackie leggs
Member#: 249794
02 WRX wagon
atomic orange pearl
I'm running a seibon hood on mine and it didn't have any holes either. So I'm not using any of the rubber seals.
I did reuse the splitter by flipping the hood upside down and centering it. Use a 1/8th drill bit for pilot holes and attach using a handful of small screws.
Jackie leggs is offline   Reply With Quote
Old 06-23-2013, 09:52 PM   #3
sc00by4life
Member#: 97135
There was another thread recently where someone was experiencing the same issue.
Just to ahead and sell it. You don't need or want it anyways.
Old 06-23-2013, 10:21 PM   #4
amnvince88
Member#: 289978
2006 Sti
Well, I just bought it. So....I think I do want it. Thanks for your input though.
Old 06-23-2013, 10:28 PM   #5
subieguy87
Member#: 153412
1998 Impreza wrxRS
You will get alot of flaming for the cf hood, people say the stock aluminum hood is actually lighter.
My gc had a steel hood(unless it's jdm wrx) and the cars' black so my carbon hood is much lighter than my steel one was... But my seibon came with the sprayer nozzle holes drilled and vents/scoop all installed. But no splitter bc it's for a gc :-(
subieguy87 is offline   Reply With Quote
Old 06-23-2013, 10:57 PM   #6
amnvince88
Member#: 289978
2006 Sti
Not every mod has to be for performance. I liked the cf look so I bought it. Thats it. Im sure every thread in this section about headlights, wings, and body kits all revolve around making the car faster...it came with a sticker..if I put that on I get like +5hp right!?!
All I'm looking for is how people with CF hoods mounted all of the "stuff" on the under side, and maybe a couple pictures so I dont fubar this thing up. Thanks in advance!
Old 06-23-2013, 11:12 PM   #7
sc00by4life
Member#: 97135
You don't.
Splitter, scoop, that's it.
Old 06-24-2013, 01:10 AM   #8
Serkan
Member#: 180514
2004 Sti
I never understood why people spend money on warped CF hoods to replace the perfect, light weight factory hood.
Serkan is offline   Reply With Quote
Old 06-24-2013, 01:39 AM   #9
amnvince88
Member#: 289978
2006 Sti
I never understood why anyone mods a perfectly good factory car...I mean like what are we all doing on here..dont we have lives? The car worked just fine when I drove I off the lot...why mess with it?
MODS PLEASE CLOSE THIS...ITS GOING NO WHERE.
Old 06-24-2013, 10:08 AM   #10
prescottn6ft7
Member#: 268918
2002 WRX Wagon
No help to offer installing the splitter, sorry, but I can say this if you do get it installed you should do a write up because this question is asked frequently. Most people with CF hoods have them for looks and are running a front mount intercooler.
prescottn6ft7 is offline   Reply With Quote
Old 06-24-2013, 02:26 PM   #11
Serkan
Member#: 180514
2004 Sti
There are functional mods and stupid mods as Uncle Scotty calls.
Originally Posted by Uncle Scotty View Post
because stupid people do stupid things for stupid reasons and have stupid problems that non-stupid people dont
is that stupid simple
Old 06-24-2013, 06:35 PM   #12
Jackie leggs
Member#: 249794
02 WRX wagon
atomic orange pearl
amnvince88, I'll post up pictures of how I have my splitter mounted this evening. Like I mentioned earlier, it's really as simple as centering the splitter and drilling a few pilot holes, followed up by some small screws.
As for all you out there beating on the idea of a carbon hood, I replaced mine because it was damaged. Seeing as I couldn't find a PSM hood near me, I opted for the CF hood as it was roughly $600 cheaper than buying a new OEM hood and having it painted.
Old 06-24-2013, 08:32 PM   #13
Jackie leggs
Member#: 249794
02 WRX wagon
atomic orange pearl
Here's my take on splitter mounting.
Old 07-01-2013, 08:45 PM   #14
amnvince88
Member#: 289978
2006 Sti
Thanks for the clear picture. The CF doesn't have clips like the aluminum hood. So, I got some fiberglass epoxy and new drill bits.
First i drilled the pilot holes in the hood from the top down
Then I laid a bead of the epoxy and placed the scoop
Took a break and drank a couple beers with the epoxy cured
I started drilling the pilot holes in the scoop from the inside (under hood) out.
Then I stepped the bit size up and re-drilled the holes to match the bolts i got
placed the bolts and called it a night. I'll be mounting the splitter in a couple days.
Old 07-01-2013, 08:47 PM   #15
amnvince88
Member#: 289978
2006 Sti
[IMG][/IMG]
