Welcome to the North American Subaru Impreza Owners Club Monday May 30, 2016
Old 02-14-2013, 02:47 AM   #26
Originally Posted by meebs View Post
57712?
doh....FFF
fixt
Old 02-15-2013, 02:05 PM   #27
garzdos
Member#: 333423
2012 WRX Hatch
Dark Gray Metallic
OMGHi2U
Curious if anyone has been using a "bad" filter with a matching date code but no failure.
The Fram (manufacturer) document states "the gasket will either immediately fail or fail within 300 miles of operation." I just looked and the filter I installed at the beginning of this year has a matching date code for a "bad" filter but I have not a drop of oil leaking...
Called my service department (I know) and asked if they have had anyone come in with failures. They said they have only had a handful of them but most of the "bad filters" they checked have been okay/functioning properly. They seemed to think it was reasonable at this point for me to just continue to watch since I'm 600+ miles on the filter and it's functioning perfectly.
I know some will say (and I would usually say it as well) "why take the chance?" But I am uber busy these days and I'm well past the "immediate" or 300 mile mark and all is well...so thinking of leaving it on and watching.
garzdos is offline   Reply With Quote
Old 02-15-2013, 02:58 PM   #28
garzdos
Member#: 333423
2012 WRX Hatch
Dark Gray Metallic
OMGHi2U
Plus, if you look at both the Subaru document and the Fram document they contradict. The Fram document is more to the point - if you have these specific date codes, you are effected. The Subaru doc makes it look like it depends on which shift the filter was made (someone in an earlier post made a comment that only 3rd shift manufactured filters were bad) but the Fram document says clearly that it is irregardless of shift. What a pain.
I called Fram directly and they were not much help. Was hoping for some more specific information but they weren't too helpful...nice, but not what I was wanting.
The Subaru doc has a link to a flow chart Subaru goes through to determine if the filter should be replaced. It clearly shows that, if the filter is over 300 miles, irregardless of any other factors, that it does not need to be replaced. Guess I'll go off that...
Old 02-15-2013, 11:57 PM   #29
ringe
Member#: 49998
2007 WRX CT Stg 2
nvm oops!
ringe is offline   Reply With Quote
Old 04-06-2013, 10:30 AM   #30
147_Grain
Member#: 339959
Question Is Oil Filter #15208AA031 Included in the Recall???
Have a 2013 Subaru Outback with the H6 (6-cylinder) engine.
The dealer sold me a case of oil filters for it: Is #15208AA031 included in the recall?
147_Grain is offline   Reply With Quote
Old 04-07-2013, 01:51 AM   #31
garzdos
Member#: 333423
2012 WRX Hatch
Dark Gray Metallic
OMGHi2U
Hmmm...simply looking at the first post of this thread has links to both the Subaru and Fram official documents which would answer your question.
Since I am nice , I will tell you that it is only for filter part # 15208AA12A and not your filter.
Old 04-07-2013, 12:13 PM   #32
dsn112
Member#: 332561
2016 WRX LTD
Just pulled the plastic cover and checked my filter I bought in November. Have 1300 miles on it since the change and it was bone dry. Hope its safe for another 4k
Old 04-07-2013, 03:06 PM   #33
DeadGeneration
Member#: 313753
Dark Gray Metallic
I have to check mines, been running that sucker for nearly 6k already.
DeadGeneration is offline   Reply With Quote
Old 04-10-2013, 08:01 PM   #34
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
I finally dealt with this today at my dealer. I bought 6 of the affected filters in october of 2012. I unknowingly ran one for a full oil interval with no oil loss for 3200 miles. I am currently on 800 miles on another affected filter with no oil loss of any kind.
The subaru tech on hand claims you lose about 1/2 a quart of oil if you just change the oil filter out. Since I run rotella t6 5w40 i was not interested in getting any replacement oil from the dealer.
The parts counter guy offered me 6 brand new filters and 2 crush washers in exchange for the 4 loser filters I brought in, to make me have 6 good filters and 6 crush washers sitting back in my garage. Showed my receipt, and the printed out link at the beginning of this thread. I didnt get any problems and they were more than happy to make me happy. I probably could have gotten more but they are very good to me and I was satisfied with the customer service. Thank you OP for posting this, I wouldnt have known without it.
Old 04-11-2013, 01:43 AM   #35
dead_eye
Member#: 308265
2008 WRX
Thanks for the heads up. I never bother with a factory filter but when I went to pick up parts for my timing belt change I grabbed one. Just my luck.
dead_eye is offline   Reply With Quote
Old 04-11-2013, 06:46 PM   #36
25rsti
Member#: 166324
I'm safe! A23221
Old 04-11-2013, 07:44 PM   #37
jthatch12
Member#: 321715
03 Big 16G WRX
Mine was leaky... This must be why. Switched back to Purolator.
Old 04-11-2013, 09:37 PM   #38
i got a wix 57712 today for $5.xx
Old 04-13-2013, 01:02 AM   #39
subi400
Member#: 216984
1996 Impreza outback
Green
Sometimes I can get my PureOne purelator PL14460 filter for around $5.50 when it is on sale....
The rubber seal on these affected filters must of been from a bad batch of rubber compound...
Old 07-02-2013, 03:26 AM   #40
sWagonRX
Member#: 324522
2005 WRX Wagon
Originally Posted by subiedude676 View Post
Glad i have a stockpile of the black filters!
Sell me some!!!!
sWagonRX is offline   Reply With Quote
Old 07-02-2013, 09:58 AM   #41
cmiovino
Member#: 134005
2004 WRX Premium
I find WIX and OEM tend not to leak. Purolator on the other hand, despite having excellent filtering quality, tends to leak. Out NA Forester, my WRX, even my old OBS and buddy's 2.5i. Even mom's Camry! All leak.
Never had an issue with OEM or WIX. That's funny because WIX is basically a Purolator, though they feel different in the hand... minus different bypass pressures.
Don't care, WIX works.
Old 07-03-2013, 08:28 AM   #42
Scorpion
Member#: 67956
2007 WRX Wagon
I don't think wix is basically a purolator. am I wrong?
Scorpion is offline   Reply With Quote
Old 07-03-2013, 10:00 AM   #43
1wrxtra
Member#: 316364
I have a whole case of 12 (10 remaining) of A2188X's... yay.
Old 07-03-2013, 10:57 AM   #44
1wrxtra
Member#: 316364
Just got back from swapping the old ones... the new ones are still under A2291, they're A2279's, but the package says A37772. Guy at the parts dept. said that their whole stock was recalled and inspected.
Old 08-07-2013, 12:56 AM   #45
slomo222
Member#: 363394
just got a 03, will wix 57712 work? its either that or im going to the dealership
slomo222 is offline   Reply With Quote
Old 08-07-2013, 02:41 AM   #46
DONx3
Member#: 214050
2007 WRX
Wix will work.
DONx3 is offline   Reply With Quote
Old 10-08-2013, 10:13 AM   #47
grimzwrx720
Member#: 337257
2013 wrx
Crystal black silica
A32382 is that an affected one?
grimzwrx720 is offline   Reply With Quote
Old 10-16-2013, 09:57 PM   #48
LethalMonk6
Member#: 294410
2008 Impreza OBS
So I assume that if I've driven about 3,000 miles since my last oil/filter change, that I'm okay? Just checked my oil level and its good. No signs of leakage beneath car. Defective filters should be failing quite immediately around 300 miles right?
LethalMonk6 is offline   Reply With Quote
Old 10-16-2013, 10:35 PM   #49
esteve
Member#: 28716
2006 STI
Yeah, you should be fine.
esteve is online now   Reply With Quote
Old 10-21-2013, 11:57 PM   #50
battlemike
Member#: 191771
2005 Subaru STi
wow, nice post. I need to check my part number. I noticed a leak and I was low on oil...looked like it was around the gasket of the oil filter.
battlemike is offline   Reply With Quote
