Old 04-10-2013, 01:48 AM   #1
manys
Member#: 265277
1999 Outback
Legacy
Default 02 WRX Hybrid motor-TD05/TD06H ported
Event: road dyno pull
Ambient Temp: 55
Elevation: ~700
Weather: dry evening
Track and Conditions: ----
Tires: brand, model, size Goodyear Eagle GT 225/40/18
Car: 2002 WRX
Tuner: Unknown
Dyno Info: Virtual Dyno Dynojet setting
Transmission: Stock 5 spd
Gear: 3rd
Peak HP at RPM: 382 @6112rpm not SAE corrected
Peak Torque at RPM: 382 @4360 not SAE corrected
Baseline hp/tq for a stock on same dyno: ~230?
Target Boost: 19.5 psi
Target AFR: rich ~10.6, needs work
Fuel: 93 oct
Engine/Power Modifications:
Stock 2.5 block
Stock 2.0 heads with chambers matched
Slightly higher compression than stock STI
TurboXS big topmount
no-name TD05 18g/TD06H ported
1000cc Five-O EV14's
TGV deletes
aftermarket catless uppipe
TurboXS 3" exhaust(DP catted)
lightweight crank and alternator pulleys
Driveline Modifications:
ACT HD plate and disc
ACT Streetlight flywheel 13lbs
Group N engine mounts
Perrin 23mm rear swaybar with Vivid CNC endlinks
Stock struts /Cobb lowering springs
Other Modifications: ----
Bought the car with a spun bearing with the
turbo installed already and car tuned by unknown tuner.Tune looks very good with no knock and nice smooth
torque delivery so save the 5 spd trans. Timing to my knowledge is also pretty conservative.
TD05 18g compressor wheel with TD06H turbine wheel in 7cm ported hot side housing. Airboy is 352/346. Comments?
manys is offline   Reply With Quote
Old 04-10-2013, 09:34 AM   #2
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Unknown tuner is kinda scary to me, post a log?
Subian is offline   Reply With Quote
Old 04-10-2013, 01:46 PM   #3
manys
Member#: 265277
1999 Outback
Legacy
Of course I went trough the map before driving the car and made sure everything is good
Code:
time	Load   RPM     FBK      IAM    Timing   IDC%	PSI   MAF(g/s)  Throttle
32:16.1	1.38	2613	0	16	20	13.94	0.73	60.96	100
32:16.1	1.4	2613	0	16	20	14.35	0.73	62.92	100
32:16.2	1.43	2691	0	16	20	14.35	0.87	65.63	100
32:16.2	1.45	2710	0	16	20	15.03	1.16	65.63	100
32:16.3	1.47	2724	0	16	20	15.11	1.45	67.47	100
32:16.3	1.51	2760	0	16	19.5	15.9	1.6	70.91	100
32:16.4	1.54	2760	0	16	19.5	16.6	1.6	72.49	100
32:16.5	1.57	2780	0	16	19	16.6	1.89	75.17	100
32:16.5	1.6	2804	0	16	19	17.34	2.18	75.17	100
32:16.6	1.63	2833	0	16	18	17.53	2.47	77.02	100
32:16.6	1.66	2828	0	16	17.5	18.1	2.76	79.39	100
32:16.7	1.69	2828	0	16	17	19	2.76	82.27	100
32:16.7	1.73	2872	0	16	16.5	19	3.05	85.77	100
32:16.8	1.78	2891	0	16	16.5	19.74	3.48	85.77	100
32:16.8	1.8	2935	0	16	16	20.66	3.92	89.49	100
32:16.9	1.82	2984	0	16	15.5	21.65	4.21	91.85	100
32:16.9	1.87	2984	0	16	15.5	22.13	4.21	94.13	100
32:17.0	1.9	2964	0	16	14.5	22.13	4.79	97.2	100
32:17.0	1.94	3016	0	16	14.5	23.16	5.08	97.2	100
32:17.1	1.99	3070	0	16	14.5	24.23	5.66	102.53	100
32:17.1	2.02	3075	0	16	14	25.58	6.09	105.42	100
32:17.2	2.06	3075	0	16	13.5	26.68	6.09	109.35	100
32:17.2	2.13	3126	0	16	13	26.68	6.67	113.93	100
32:17.3	2.17	3147	0	16	13	27.53	7.4	113.93	100
32:17.3	2.22	3200	0	16	13	29.35	7.98	118.64	100
32:17.4	2.28	3220	0	16	12	30.91	8.56	124.8	100
32:17.4	2.34	3220	0	16	11.5	31.76	8.56	129.43	100
32:17.5	2.4	3237	0	16	11.5	31.76	9.29	135.1	100
32:17.6	2.49	3323	0	16	11.5	34.02	10.16	135.1	100
32:17.6	2.56	3336	0	16	11	35.58	11.17	142.64	100
32:17.7	2.63	3394	0	16	10.5	37.65	12.04	148.91	100
32:17.7	2.71	3429	0	16	10.5	40.24	12.91	161.08	100
32:17.8	2.82	3429	0	16	10	40.24	12.91	169.98	100
32:17.8	2.91	3470	0	16	10	42.2	13.78	169.98	100
32:17.9	3	3531	0	16	9.5	45.2	15.38	179.86	100
32:17.9	3.08	3580	0	16	9	46.58	16.4	186.22	100
32:18.0	3.18	3575	0	16	8	48.81	17.41	197.1	100
32:18.0	3.24	3575	0	16	7.5	48.81	17.41	205.11	100
32:18.1	3.31	3674	0	16	7.5	50.95	18.28	205.11	100
32:18.1	3.33	3704	0	16	7.5	52.15	18.86	210.35	100
32:18.2	3.31	3788	0	16	7.5	53.33	19.44	211.18	100
32:18.2	3.31	3788	0	16	7.5	54.12	19.44	216.36	100
32:18.3	3.31	3844	0	16	7.5	54.12	19.44	215.55	100
32:18.3	3.3	3844	0	16	7.5	54.12	19.59	215.55	100
32:18.4	3.28	3951	0	16	8	54.79	19.44	218.62	100
32:18.4	3.24	4010	0	16	8	55.61	19.3	216	100
32:18.5	3.22	4010	0	16	8	55.52	19.3	215.55	100
32:18.5	3.18	4004	0	16	8.5	55.52	19.01	217.71	100
32:18.6	3.17	4125	0	16	8.5	55.44	18.57	217.71	100
32:18.7	3.14	4092	0	16	8.5	55.86	18.43	216.81	100
32:18.7	3.09	4254	0	16	9	55.36	17.99	217.26	100
32:18.8	3.09	4223	0	16	9.5	55.85	17.85	221.34	100
32:18.8	3.07	4223	0	16	9.5	55.85	17.85	221.34	100
32:18.9	3.07	4325	0	16	9.5	56.28	17.56	221.34	100
32:18.9	3.05	4394	0	16	10	58.11	17.41	224.97	100
32:19.0	3.01	4435	0	16	10	56.77	17.27	221.8	100
32:19.0	3.02	4435	0	16	10.5	58.55	17.27	227.23	100
32:19.1	3.01	4499	0	16	10.5	58.55	16.83	227.23	100
32:19.1	2.99	4515	0	16	10.5	57.79	16.83	226.78	100
32:19.2	2.98	4568	0	16	10.5	58.46	16.69	229.05	100
32:19.2	2.98	4568	0	16	10.5	58.3	16.69	229.05	100
32:19.3	2.95	4632	0	16	10.5	58.3	16.54	229.05	100
32:19.3	2.96	4699	0	16	11	58.14	16.54	230.89	100
32:19.4	2.93	4738	0	16	11	58.62	16.4	230.89	100
32:19.4	2.93	4738	0	16	11.5	59.33	16.4	236.56	100
32:19.5	2.93	4795	0	16	11.5	59.33	16.25	236.56	100
32:19.5	2.92	4817	0	16	11.5	59.6	16.11	236.08	100
32:19.6	2.92	4931	0	16	11.5	59.96	15.96	235.6	100
32:19.6	2.91	4931	0	16	11.5	61.01	15.96	242.34	100
32:19.7	2.91	4931	0	16	11.5	61.01	15.96	242.34	100
32:19.8	2.91	5023	0	16	11.5	62.15	15.82	242.34	100
32:19.8	2.9	5023	0	16	12	62.74	15.82	246.68	100
32:19.9	2.9	5071	0	16	12	62.74	15.67	246.68	100
32:19.9	2.89	5119	0	16	12.5	63.34	15.53	249.04	100
32:20.0	2.91	5176	0	16	12.5	64.04	15.38	250.59	100
32:20.0	2.93	5176	0	16	12.5	64.04	15.38	250.59	100
32:20.1	2.93	5274	0	16	12.5	65.26	15.24	254.71	100
32:20.1	2.92	5274	0	16	12.5	65.26	15.24	257.07	100
32:20.2	2.94	5312	0	16	12.5	65.72	15.24	257.07	100
32:20.2	2.95	5384	0	16	12.5	66.61	15.09	260.01	100
32:20.3	2.95	5384	0	16	12.5	66.61	15.09	260.01	100
32:20.3	2.94	5396	0	16	13	67.91	15.24	265.31	100
32:20.4	2.93	5396	0	16	13	67.91	15.24	265.31	100
32:20.4	2.95	5478	0	16	13	67.78	15.24	269.38	100
32:20.5	2.92	5478	0	16	13	67.78	15.24	269.38	100
32:20.6	2.9	5555	0	16	13	68.74	15.38	270.83	100
32:20.6	2.91	5555	0	16	13.5	68.74	15.38	271.19	100
32:20.6	2.91	5643	0	16	13.5	69.82	15.53	271.19	100
32:20.7	2.92	5643	0	16	13.5	69.82	15.53	275.73	100
32:20.8	2.89	5729	0	16	13.5	70.89	15.38	275.73	100
32:20.8	2.9	5729	0	16	13.5	71.11	15.38	277.81	100
32:20.9	2.87	5747	0	16	13.5	71.11	15.53	277.81	100
32:20.9	2.87	5747	0	16	14	70.7	15.53	277.12	100
32:21.0	2.85	5814	0	16	14	70.7	15.38	277.12	100
32:21.0	2.85	5814	0	16	14	71.58	15.38	281.97	100
32:21.1	2.86	5887	0	16	14	71.58	15.38	281.97	100
32:21.1	2.85	5887	0	16	14.5	73.01	15.38	284.83	100
32:21.2	2.84	6004	0	16	14.5	73.01	15.53	284.83	100
32:21.2	2.84	6004	0	16	15	73.9	15.53	287.75	100
32:21.3	2.84	6078	0	16	15	73.9	15.53	287.75	100
32:21.3	2.81	6078	0	16	15	73.44	15.53	284.34	100
32:21.4	2.8	6147	0	16	15	73.44	15.53	284.34	100
32:21.4	2.81	6147	0	16	15.5	73.44	15.53	290.19	100
32:21.5	2.79	6162	0	16	15.5	73.62	15.53	290.19	100
32:21.6	2.77	6162	0	16	15.5	73.62	15.53	290.19	100
32:21.6	2.74	6224	0	16	17.5	73.03	15.53	287.27	100
32:21.7	2.72	6224	0	16	17.5	73.03	15.53	287.27	100
32:21.7	2.73	6378	0	16	18	73.47	15.53	287.75	100
32:21.8	2.7	6378	0	16	18	73.47	15.53	287.75	100
32:21.8	2.68	6378	0	16	18	74.16	15.53	286.78	100
32:21.9	2.68	6438	0	16	18	74.16	15.53	286.78	100
32:21.9	2.66	6438	0	16	18	74.16	15.53	286.78	100
32:22.0	2.63	6527	0	16	18.5	73.8	15.67	285.8	100
32:22.0	2.64	6527	0	16	18.5	73.8	15.67	285.8	100
32:22.1	2.62	6602	0	16	19	73.24	15.67	284.83	100
32:22.1	2.63	6602	0	16	19	73.24	15.67	284.83	100
32:22.2	2.59	6602	0	16	19	73.24	15.67	284.83	100
32:22.2	2.58	6660	0	16	19	72.47	15.96	282.66	100
32:22.3	2.57	6660	0	16	19	72.47	15.96	282.66	100
32:22.3	2.55	6660	0	16	20	72.59	15.96	285.31	100
32:22.4	2.55	6672	0	16	20	72.59	16.11	285.31	100
32:22.4	2.52	6672	0	16	20	72.59	16.11	285.31	100
32:22.5	2.51	6812	0	16	20	72.66	16.11	284.83	100
32:22.6	2.5	6812	0	16	20	72.66	16.11	284.83	100
32:22.6	2.48	6812	0	16	20	72.66	16.11	284.83	100
Old 04-10-2013, 05:20 PM   #4
snake32
Member#: 167338
02 Silver dollar
looks good to me! awesome powerband, congrats!!
snake32 is offline   Reply With Quote
Old 04-10-2013, 06:21 PM   #5
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
I loved the 18G on my hybrid. Enjoy the power.
Old 04-10-2013, 06:45 PM   #6
manys
Member#: 265277
1999 Outback
Legacy
Thanks. It's pretty quick for now and kicks in nicely even with slow torque delivery because of the 5spd-safe tune.
Could anyone with more experience than me chime in on the timing?
What is considered really low,in the middle, and aggressive on 93 oct at this boost?
Old 04-10-2013, 08:33 PM   #7
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
I'm no tuner, but that sure does look like a boost spike.
Old 04-11-2013, 03:53 AM   #8
rexblake
Member#: 178426
2010 S4
Gray
Boost spike at the end? It does go up a little, which is odd, but there certainly isn't much of a "spike".
You should hit up a dyno day, I'm curious how it would look on one.
Old 04-11-2013, 10:10 AM   #9
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
I'm not a tuner, but only thing I would be worried about is the load columns for timing/fuel. Make sure they're scaled out far enough to give you a "buffer" since you're hitting 3.3x load in the mid-range. Timing also looks conservative in the mid-range, probably to help with the 5-speed.
Old 04-11-2013, 05:59 PM   #10
SkateAndDestroy
Member#: 133893
JBP 04 Forester XT
PSM 02 WRX Wagon
You pretty sure its only an 18g? It seems like a lot of power from an TD05 7cm 18g, especially seeing you are running 10.6~ and are only holding 16psi from 5000-redline. Looks like a fun car!
SkateAndDestroy is offline   Reply With Quote
Old 04-12-2013, 12:39 AM   #11
manys
Member#: 265277
1999 Outback
Legacy
I'm pretty sure that stock ECU just interpolates the values from the last cell or uses the same values from the last column.
So if your map is scaled to 3g/rev of load the ECU will use values(or interpolate) from 3g/rev column for an anything over 3. Right now I'm scaled to 3.2 and although I've seen 3.5 in my logs with 21psi I don't think that scaling past 3.2 is really necessary.Someone correct me if I'm wrong though.
Only thing to worry about is MAF g/sec which only could be scaled to 300 and you can't go past that(unless you do the MAF mode)
I'm pretty sure. Keep in mind that those are not-SAE corrected numbers plus they are little skewed by bumps in road. It looks like everyone posts uncorrected dynojet VD #'s so I did too for the sake of comparison to others. SAE corrected pull on really flat road should show ~340whp/360wtrq dynojet which is pretty realistic.
Anyway 20psi by 3750rpm from a ebay 18g turbo is pretty nice. Well see how it will perform after a rebuild. I have a rebuild kit ready and should be able to do it next week.
Old 04-12-2013, 10:42 AM   #12
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
You can measure the inducer/exducer on the wheels to confirm the size of the turbo.
Old 07-02-2013, 10:37 PM   #13
manys
Member#: 265277
1999 Outback
Legacy
Finally got time to rebuild the turbo.
It had like 1 inch of front/back play and compressor wheel was damaged due to rubbing on the housing.
After measuring compressor and turbine wheels I confirmed that the compressor wheel is a standard Td05 18g but the turbine wheel was a surprise because it's a TD06H wheel. 67/58.7mm inducer/exducer compared to 55.8/49.1mm on standard TD05 wheel.
