Old 04-09-2013, 05:47 PM   #1
Moviemaggot
Member#: 352702
2010 Impreza 2.5i
Default Maintenance schedule for 2010 Impreza 2.5i. Water pump/timing belt?
Hey guys,
Was wondering where I could find a Maintenance schedule for my 2010 Impreza 2.5i.
When are you suppose to do the Water Pump and Timing Belt? at how many miles?
Moviemaggot is offline   Reply With Quote
Old 04-09-2013, 05:57 PM   #2
webster354
Member#: 343343
2014 Impreza 5dr Ltd
webster354 is offline   Reply With Quote
Old 04-09-2013, 09:16 PM   #3
Moviemaggot
Member#: 352702
2010 Impreza 2.5i
I checked my physical owners manual and found the maintenance schedule but it said nothing about water pump or timing belt. I found it odd
Old 06-13-2013, 10:17 PM   #4
Moviemaggot
Member#: 352702
2010 Impreza 2.5i
Definitely not in the owners manual. Anyone?
Old 07-03-2013, 07:36 AM   #5
Roger76
Member#: 361070
2008 Impreza 1.5R
http://www.mytimingbelt.com/
Says 60k miles for 01-06 models
and 66k miles for 07 >
This site also lists additional information about auxiliary drive belts and such. Nothing about the water pump though, but I believe its usually changed at the same time.
Roger76 is offline   Reply With Quote
Old 07-03-2013, 07:56 AM   #6
Zeeper
Member#: 299286
2015 WRX CVT
They won't give you a maintenance schedule for the water pump. Generally, the water pump is replaced whenever you do the timing belt, since it takes a lot of disassembly (in most engines) in order to change the timing belt, and the cost of installing a new water pump is not that much in addition to the other work.
If you don't replace it, and the water pump were to fail, the labor cost to disassemble the engine to replace it is more than the cost of the pump, which is why most mechanics recommend replacing both (you get two new parts for the cost of 1 labor).
Also, of course, a failed or failing water pump can overheat the engine, causing total engine failure.
Zeeper is online now   Reply With Quote
Old 07-03-2013, 08:42 AM   #7
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Interesting web site.
I know that this question is out of scope for this thread, but I notice for the 2012+ Impreza with the 2.0 engine, the site says "N/A" for when to replace the timing belt. I believe that's because the new 2.0 engine uses a timing chain, right? If so, can one assume that the timing chain is good for the life of the engine? And if so, do we just replace the water pump on an as-needed basis?
