Welcome to the North American Subaru Impreza Owners Club Tuesday June 30, 2015
Old 07-02-2013, 09:56 AM   #351
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Phatron tuned
Originally Posted by NSFW View Post
No creep at all on mine (GT3076). I was running 23 peak, and it was tapering to 21 or so with an MBC.
However the metal tab that operates the wastegate just broke. It now makes 2-3psi total. I guess you could call that "creep" since I would have expected no boost at all with the WG flapping in the breeze.
I think a spot-weld should fix it.
That sucks. I'd weld and go external at that point
wrxsubiemod is offline   Reply With Quote
Old 07-03-2013, 03:36 AM   #352
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
That's the most likely outcome... I've been wanting to clock the turbo 90 degrees for a long time (for one less bend in the turbo-to-FMIC pipe) but the IWG actuator is in the way. And I haven't changed anything in over a year now, maybe two years even, so it's time to do something.
Thing is, I want to hold the wastegate closed with a bracket mounted where the actuator is now, and that requires a working arm. I'm not real keen on the idea of welding the door closed from the inside, and I don't know that I'd trust a weld on the outside to properly seal the door shut.
Old 07-03-2013, 03:46 AM   #353
NSFW
Member#: 140444
05 Stage Free LGT
Originally Posted by LittleBlueGT View Post
Stock block still?
Yep.
Old 07-03-2013, 04:07 AM   #354
SwedeSTi
Member#: 308847
Good news on the performance of the IWG, not so much the broken tab though.
SwedeSTi is offline   Reply With Quote
Old 07-03-2013, 11:23 PM   #355
NSFW
Member#: 140444
05 Stage Free LGT
Yeah, I have no complaints about the IWG performance, other than the busted arm.
I think the IWG linkage might have had too much tension from the factory (I never adjusted it).
Old 09-04-2013, 04:30 PM   #356
WhatTurboLag?
Member#: 243992
2006 WRX TR
Talked to them toda about building me a gtx2867, they said no problem. I love this idea, but I don't love the turbine housing size. So rotated ill have to stick to.
Old 12-29-2013, 01:30 AM   #357
NSFW
Member#: 140444
05 Stage Free LGT
Is anyone using a PTP (or other brand) turbo blanket with the ATP 3076, internally wastegated?
If so, which blanket did you get, and how well does it fit?
I want to get a blanket, but I'm not sure which one. I have one of those DIY fiberglass-and-foil blankets right now, but after ~5 years and pulling/reinstalling the turbo a few times, it's getting a bit ragged.
Old 12-29-2013, 05:34 PM   #358
acheung
Member#: 118389
I use a PTP turbo blanket for my ATP 3076 stock location IWG
acheung is offline   Reply With Quote
Old 12-29-2013, 06:23 PM   #359
NSFW
Member#: 140444
05 Stage Free LGT
Which model did you get? PTP makes a few...
Old 12-29-2013, 06:41 PM   #360
acheung
Member#: 118389
nothing special... just used the subaru wrx turbo blanket.
Old 12-29-2013, 07:27 PM   #361
NSFW
Member#: 140444
05 Stage Free LGT
Thanks. I thought people were using the T3 blankets, and I was wondering if the WRX turbo blanket would be big enough.
Old 01-04-2015, 04:48 PM   #362
johnmx3ze
Member#: 291213
2009 wrx
swp
anyone have feedback or running a atp stock location gtx3576r?
johnmx3ze is online now   Reply With Quote
TurboXS knock light, review and discussion PDXTuning UTEC 185 08-19-2013 06:03 PM
FS: (Irvine) ATP GT3071R Ball Bearing Stock Location Turbo and KSTech 73mm Intake ntbass SCIC Private Classifieds 12 11-27-2009 05:44 PM
FS/FT: (Irvine) ATP Stock Location GT3071R Ball Bearing Turbo ntbass SCIC Private Classifieds 5 11-14-2009 08:36 PM
FS: (Socal) ATP Stock Location GT3071R Ball Bearing Turbo ntbass Engine/Power/Exhaust 5 11-13-2009 05:45 PM
Wtt: Atp Gt3076r Stock Location titoune Private 'Wanted' Classifieds 3 09-27-2008 09:07 PM
